Buying Advice case or mahindra
/ case or mahindra #1
tdw2676
millbrook
kubota
help me guys.i have 3.5 acres to mow and a 600 ft. driveway to keep up.i can buy a brand new case farmall 45a for $12000,or i can buy a 2005 mahindra 3525 with 490 hours on it for $6500.the used tractor seems to be in pretty good shape.
/ case or mahindra #2
Why are you having trouble deciding which one to buy?
/ case or mahindra #3
The 3525 is a good basic tractor, simple and gets the job done with no frills.
/ case or mahindra #4
I see 5500 resons why you should give the Mahindra serious consideration ... more than enough tractor for you... of course you also inherit the first owners issues's if any and how close is the Mahindra dealer?
/ case or mahindra #5
That $5500 difference will buy a very nice mower & box blade and still leave cash in pocket for other things if needed.
/ case or mahindra #6
I don't have any experience with the Mahindra your looking at but did just buy a Farmall 45A and I love it so far. If you can try to compare how the Mahindra is set up compared to the standard features on the Farmall. The 3pt hitch is set up the exact way it should be, telescopic stabilizers and lower links. Makes hooking and unhooking 3pt implements a breeze. And the seat is very comfortable. I was really impressed with the tractor as a whole. Its very quiet and just very well put together.
The price you got on the Farmall is a very good price. Is that a cash price?
/ case or mahindra #7
How much warranty is available on the Mahindra? Will you be happy with 2wd instead of the D45's 4wd? Does 8x2 transmission meet all the requirements you'll have or would the D45's 12x12 shuttle transmission make more sense? Is the live PTO of the Mahindra better than the fully independent PTO of the D45? How about the D45's 4-cylinder engine over the Mahindra 3-cyl?
From my viewpoint, the Mahindra beats the D45 in two major ways. It is heavier by almost 1000 lb and it is cheaper because it is a used tractor.
/ case or mahindra #8
The D45 is a completely different unit then the farmall 45A. His price for the 45A has to be for the 2wd version. Here is my 45A before it got dirty
/ case or mahindra #9
Ah yes! Caught again by the new model designations.:eek: That new 45A is really an LS isn't it? A new D45 for $12k would have a line around the block waiting to buy it.:D
/ case or mahindra #10
That tractor should not be an LS. The specs on the Farmall 45A shows that it has a Shibaura N844L engine. So it is either a Shibaura tractor or it is a true CNH designed tractor, which is why Robert's new Farmall 45A runs so well/smooth.
/ case or mahindra #11
It has CNH cast into all the major parts i noticed so i don't think it has anything in common with LS other then the fact its a tractor. They really are a great value though and I'm finding that I'm fighting the urge to buy a second Farmall A series tractor.
/ case or mahindra
thanks guys was just able to check the responses.it is a 2 wheel drive,and yes it is a cash price.just wasnt sure of the quality of the mahindra.
/ case or mahindra #13
What are you planning on doing with the machine outside of the 3.5 acres of mowing and 600' driveway maintenance? Do you have additional property to maintain, do you need to run a snow blower? More info about your needs will help us help you.
If you are only doing mowing on those 3.5 acres and the driveway maintenance, the 45A would be way overkill in my opinion. I have 12.2 acres, 1/4 mile driveway, mow about 3 acres of lawn, bushog another 4 acres, and need the tractor for snow removal and dirt work. A 45hp utility would be way too much for my needs, and too big to mow the yard with.
/ case or mahindra #14
Well, before I put out anymore bad info,:eek: I decided to check the specs. It looks like the 45A is different from the D45, but it still has an 8x8 transmission and may have an independent PTO. I haven't seen anything about a dual clutch. What type PTO does your's have, Robert? The standard single remote is also a nice feature and the 11.6 gpm main pump is impressive. It sure seems to be a nice machine. My guess is that it is a pure Shibaura tractor, but I don't know that for sure.
/ case or mahindra #15
I don't think it is. As I said, the major castings I have noticed all have CNH cast right into them. So the base of the tractor would appear to be CNH.
I have not used the pto yet but I believe it is independent. I read your post while using the tractor today and decided to shift the pto lever while moving and it didn't yell at me. It engages just like my TN does.
/ case or mahindra #16
The Farmall A brochure states that the PTO is fully independent.
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61572)
2025 Hydraulic...
2022 John Deere 1795 Planter (A63111)
2022 John Deere...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
