battery overcharging
/ battery overcharging #1
marler
I have a LK2554. I am getting 17.5 volts while the tractor is charging. I just replaced the alternator. Still getting 17.5 volts or better. Where else can I check?
/ battery overcharging #2
If the battery has a shorted cell it can cause an excess voltage draw so alternator would be put out extra volts trying to keep up.
/ battery overcharging #3
What is the battery voltage while the tractor is off?
/ battery overcharging #4
I had to jump my tractor. This was a few years ago but seem to recall that the charging voltage was way high. New battery and the charging voltage was fine. I would not put a new alternator on without having the old one bench tested. Way too much money to toss around.
I just put my 2nd battery in two years in. The Alternator is brand new. I am getting 13.3 volts with the tractor off
/ battery overcharging #6
Most battery chargers now have a battery and alt test mode. I would look into one before a battery or alt. They are much cheaper and can be used on about any thing.
17volts does seem a little high. Should be more like 14/15volts.
no more ideas?
/ battery overcharging #8
If your measuring voltage at the battery you should have 12.5 to 13.5 with engine off. Fire up engine and your voltage should jump to 15.5 or so volts. As the engine runs the voltage should drop to 12.5 to 13.5 volts. If your voltage does not drop after engine is running for a bit your voltage regulator is not working.
/ battery overcharging #9
17.xx is way too much output- enough to cause the battery to explode and throw acid all over you and everything else around it. While wearing safety glasses, long sleeved shirt and gloves, CAREFULLY remove the negative battery terminal and then the positive and place the battery in something safe, (HD plastic or wood crate or something similar, with a blanket or some such thing to cover it during transport). Have it load tested at a local facility after explaining what its been reading at 17.xx volts. Evidently the alternator is not your issue. By load testing the battery and checking the specific gravity of each cell you will be able to rule out the battery or find that it is indeed the problem. Report back results, and be careful; no one wants to experience a battery explosion under any circumstances.
When the engine is reved up to about 1500 rpm I am getting 17.5. At idle it is 15.3. This is after letting the motor run for about 5 minutes.
/ battery overcharging #11
your voltage regulator is not working......:(
is this attached to the alternator or is it a seperate part?
Is this something a parts house could check?
/ battery overcharging #13
some are and some are not. check your manual or have it tested.
/ battery overcharging #14
Your voltage regulator should limit output voltage to 14.25 Volts MAX. Anything higher is too much, regardless of load/RPMS etc.
If your voltage regulator is external to your alternator then just replace it. If its part of the alternator then you should have a qualified alternator repair shop check out both the original AND the new one to verify what they are outputting on a test bench. It is possible both the old one and the new one are defective, but highly unlikely. You still need to have your battery checked too.
BTW, Don't run the tractor anymore until this issue is resolved- because of the battery being overcharged.
One step at a time.
in the wiring diagram there is a part called regulator. is this what I am looking for?
/ battery overcharging #18
me thinks you need to take the voltage meter your using and go test a few other batteries (car, boat) and see what readings your getting. Ive had bad meters before. Do this first before throwing out the battery.
/ battery overcharging #19
Does it show it as integral to the alternator or as a separate item?
You could test your multimeter to verify it is functioning properly, but I doubt it is faulty. Usual self test is to test for ohms reading with the leads opening and closing the circuit on that scale. What made you change out the alternator in the first place?
The print is very small on the wiring diagram. I could not find the voltage regulator. So I ordered a alternator thinking the regulator was built in. I got the magnifying glass out today and found the regulator on the wiring diagram.
2016 Jeep Grand Cherokee 4X4 SUV (A64557)
2016 Jeep Grand...
2003 Dodge Ram 1500 Pickup Truck (A64194)
2003 Dodge Ram...
2000 Chevrolet Astro Passenger Van (A64194)
2000 Chevrolet...
REDDICK 300 GALLON SPRAYER (A64278)
REDDICK 300 GALLON...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
