Remotes coupler help
/ Remotes coupler help #1
ENG18LT
Syracuse and Warsaw, NY
Mahindra 5530 4wd
Has anyone here seen female couplers on their remotes that do not have a collar to slide back allowing the "bb's" to retract? Stumped could use some help
/ Remotes coupler help #2
Did you ever see a collar on the QD?
Maybe the sleeve keeper broke and the collar got lost.
Are the retaining balls still there?
Do you have a picture?
Will get picture this weekend. Remotes were installed brand new (OEM, Mahindra) last fall. Haven't used yet. They are solid, no moving parts except valve pin. Balls are all present, but no external sleeve to pull back and allow balls to retract. Very confused.:confused:
/ Remotes coupler help #4
I have seen some where the locking ring stays back, so all you have to do is push the male end in, and the look ring snaps foreword. When you pull the ring back to unhook, it stays back. I don't know if that's what you got, because I've only seen them once in hydraulics, and I don't think they worked too well.
I will look again when out at the farm this weekend. I don't need them right away, but it will drive me nuts not knowing. By the way, the retaining balls are not retracted and don't seem to want to either.
/ Remotes coupler help #6
With these OEM female QDs you just take the 1/2" male AG end and just push it in. When you go to remove the male end, you push in and then pull out all in a quick motion. Waaaaaaaaaaaay better than anything with the collars. I believe that all the Mahindra OEM female ends are this way. I know that mine on my 7520 and 3215 are.
That is similar to what I was thinking, just never seen it before. I am used to QD's on air lines, and can't picture how these work. I will give Lawalls a call tomorrow morning. Galen is very helpful, more then the dealer I bought it from.
Thank you all for the responses.
/ Remotes coupler help #8
Kubota OEM is the same way. The sleeve is fixed into the block that the remote mounts into.
One advantage is that if you forget to pull the hydraulic lines before you drive off, they just pop out, no harm done.
Aaron Z
/ Remotes coupler help #9
Aaron Z
Correct, and again waaaaaaaaaaaaaaay better than any of the units with collars IMO. ;)
/ Remotes coupler help #10
The ones with collars (at least the ones I have gotten at TSC can be used as the breakaway style.
It takes:
Double Breakaway Clamp: Pioneer Double Breakaway Clamp - 1824481 | Tractor Supply Company
2 double acting sleeve quick couplers: Pioneer Quick Coupling, 1/2 in. Double Acting Sleeve Set - 1824407 | Tractor Supply Company
The sleeve part of the couplers goes into the clamp and is locked in place so that the inside moves (not the outside sleeve).
Aaron Z
/ Remotes coupler help #11
It takes:
Aaron Z
So in essence you have a sleeved set of quick connects that are designed to be break away connectors used as a collarless set as long as you are using all of the correct stuff. :cool: While this is great, :thumbsup: aren't you really buying a collarless set up that can be used as a std setup? After All the setup doesn't allow you to use any std type sleeved QD in their special clamp. All semantics I suppose. ;)
/ Remotes coupler help #12
LOL. I was mounting them as remotes on the baler (to allow me to use the cylinder from the plow to aim the kicker on the baler) so I wanted them to act as breakaway connectors. Being as they were only a couple of bucks more for this type, it seemed like a good idea.
Aaron Z
16ft T/A Enclosed Trailer (A61569)
16ft T/A Enclosed...
2018 Trail King Lowboy (A63118)
2018 Trail King...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
UNUSED WOLVERINE PT-16-01C UNIVERAL ATTACHMENT (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 2012 Jaguar XJ Passenger Car, VIN # SAJWA2GE5CMV37496 (A61165)
INOP/NON-RUNNING...
