Let's see your modified box blades!
/ Let's see your modified box blades! #1
deezler
Elite Member
Southeast MI
Cub Cadet 7305, Kioti CK3510seh TLB
Or otherwise modified rear 3-pt implements for enhanced practicality!
I don't even have a box blade yet, but it is very high on the desired-implements list. It sounds like a lot of folks here keep it on the rear of their CUTs almost all the time. I am in the process of breaking ground on an overgrown parcel of land, so a box blade is an obvious choice for ground shaping and root tearing, etc.
However, I still need to be able to tow around a trailer, skid logs, etc. And taking off the box blade every time I want to do any of this seems like a major pain. And it's always good to have more rear ballast weight by keeping it mounted.
So, I thought I saw a picture once of a box blade with a tow hitch. How about a log skidding boom / chain hook? What about a tool box, battery box, or winch mount? Maybe a chainsaw holster?
Seems like a box blade with accessories could be the ULTIMATE rear 3-pt attachment. Anyone have pics or experience to share? Thanks in advance!
edit: found one: http://www.tractorbynet.com/forums/...47845-checkout-my-combo-boxblade-trailer.html
/ Let's see your modified box blades! #2
Here is a 5.5 Woods/Gill box blade that has the best varation ever made to a box. Rollover! Ken Sweet
/ Let's see your modified box blades! #3
Where would you mount your trailer hitch on a rollover?;)
I'd like to see how folks have reinforced a regular 550lb 6' box blade as it seems I missed my chance at a 7' hyd. gannon box blade of doom...:(
/ Let's see your modified box blades! #4
When I use a chain or cable for towing with the box blade installed, I just raise it and hook to the tractor drawbar.
Bruce
Bruce
For towing... a log? Trying to think what else you would tow with a "chain or cable". I know I have some log skidding in my future. I do NOT want to tow them flat on the ground, as I understand it makes a mess of things and dull chainsaw blades in a hurry. So I need to get the front end of the log elevated somehow.
My concern for towing a trailer is that a box blade is not going to be able to be raised high enough to safely couple a trailer under it to the drawbar. Nor would that be at all convenient, if it could.
/ Let's see your modified box blades! #6
I would go into those 2 scarifying slots in the center rear and make a QD plug in and out hitch. Ken Sweet
/ Let's see your modified box blades! #7
I tow mostly stumps, rocks, and bundles of treetops or brush.
I plan to add a receiver hitch tube from front to back of the box blade for other uses.
A hook on the top rear of a rear blade center frame or box blade would seem to be a good place to tow a log from, if not too heavy. Hook it up tightly with blade down, lift the blade and log, and go. Or put a block under the end of the log before final hitching to get it higher. The blade shields the end of the log kind of like the logging winch attachments. The implement prevents a rear rollover if the log snags somehow.
Bruce
/ Let's see your modified box blades! #8
Ken, great idea on mounting up a hitch on a rollover. I got a used Gannon just as pictured but like new though. I will have to add the hitch idea to the "WIGATIL--when I get around to it list." So who made it and who put there names on it if you happen to know? Was just wondering.
Good luck Deezler with your boxblade search. I you have patience used is the way to go. Most people buy and only use a couple of times then it sits till they sell it.
/ Let's see your modified box blades! #9
A great mod I made about 9 yr ago, was mounting 1 scarifyer on the end of my box blade plate with 2 bolts and adjustable height. Perfect for putting low voltage electric lines in and small PVC water feed lines to the goldfish pond used for filling after water evaporation. I almost forgot, I ran a Cat 5 Internet cable 300 ft about the same time with this setup and worked perfectly. Working depth was 2-6 inches. You can also do this mod on the side plate of your front loader bucket. Ken Sweet
/ Let's see your modified box blades! #10
Here is what I did to add weight not fancy but its 350# extra in a small area its a harmonic balancer off a big natural gas compressor engine.
Bruce
Exactly what I am thinking.
Now, not only do I not yet have a box blade, but also no welding equipment. :(
So I may have to beg someone at work to hook me up with some welding on the side.
Been trolling my local craigslist's for months now, nothing but crusty old junk with no scarifiers. Or other people who think that a beat up old box blade has only depreciated $100 or so. I am also being kinda picky on size, I want a 5' (60") unit, only.
New King Kutters seem pretty affordable. And so shiny! Might have to go new.
Wow CarDoc, that is a lot of extra weight. Does it make the front end get light at all?
I think that looks right at home how you mounted it!
/ Let's see your modified box blades! #14
No not really it is about what my tiller is or a bit less maybe 750ish lbs roughly?
Thanks yeah it isn't going to be going anywhere its too heavy to man handle if it did move so I fixed that. :laughing:
In all reality I only need that much weight for the rippers and once the dirt is tore up I have to watch how deep I cut with the blade. But its smooth I give it that not much chattering of the road surface going on back there.
/ Let's see your modified box blades! #15
Bolted on two 1" steel plates 60 lbs each.
/ Let's see your modified box blades! #16
You know Deezler hang in there if you can. It seems like you put in about as much time as I did. I ended up finding one on ebay that wasn't too far away. $600 for Gannon 66" roll over about an hour away. I think I did good compared to the new ones cost as I was looking towards TSC professional series with hinged gate. Anyway I am happy and it sure works good.
Ken thanks for the side scarifier idea, yet another one to add to my list.
/ Let's see your modified box blades! #17
Sure about the weight? Looks like one is 12"x18" (60 lbs) and one is 12"x24(80 lbs) more like 140 lbs. Visually that is what I would guess anyway for 1" plate.
/ Let's see your modified box blades! #18
They are 10 x 22, the steel shop wieighed them at just over 60 lbs each.
/ Let's see your modified box blades! #19
Well guess I was WRONG:laughing: At any rate I was at the steel shop Monday and since plate is selling for .56/lb that is a good way to weight your box imo. I like the fact that it is out of the way and centered over the blade too.
/ Let's see your modified box blades! #20
That picture makes it hard to tell, look at this one.
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64194)
2021 Mercedes-Benz...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
