Deere 110 with BB1284 box blade, not working properly?
   / Deere 110 with BB1284 box blade, not working properly? #31
Little curved dipstick with a yellow handle - right above the pto shaft and arms.
AKfish
   / Deere 110 with BB1284 box blade, not working properly? #32
No OP manual... ouch! :D Many of the Deere manuals are online at the JD site. I know the 4000 series and the one for my 5075M is on there.
You could just print out pages you need - quickly.
AKfish
It's on it's last 'X' but says its good enough. I could add a little, though.
Without the OM it has been a lot of trial and error. Luckily not to many nor to big of errors. I haven't tried anything besides what you guys have recommended, because without the OM I want to make sure I'm not making it worse. I still have to get a hose, though, I'll do that tonight or tomorrow at the latest and see if it helps any.
Again, thanks for all the help. I can't imagine it's to complex and once it works it will be one of those, why didn't I think of that earliers...
Thought I should update. I put the 3ph and box blade back on and the tilt cylinder was working just fine. I think it must be air. In going to check out TSC tomorrow morning for a hose.
   / Deere 110 with BB1284 box blade, not working properly? #35
Martian, switch the quick connects around. Switch the top link with the rippers. If you have a problem with the top link, then the problem is in the valve. The ripper bar should work with the normal top link valve.
Thanks Brian. Just did that and sure enough, all the way, all the way down. Excuse my stupidity on hydraulics, but does this fairly well guarantee air? This is my first tractor with all these extra hydraulics. The 3120 had 1 remote that I had never used till I got the box blade and the 5410's are only used for the loader. Never had any problems like this before.
Thanks for the help, and I will be going in the am to get a new hose.
   / Deere 110 with BB1284 box blade, not working properly? #37
Did the top link work to full retraction and extension? Lets hope that air is all that it is-was. ;)
The top link was working perfectly. I'm thinking it must have just been air in the top set of remotes, hoping at least. I'll find a hose tomorrow and be sure though! Thanks for the help Brian.
   / Deere 110 with BB1284 box blade, not working properly? #39
I know that it was working properly with the remotes controlled by the loader joy stick, but does it work properly hooked up to the valve that had been giving you trouble with the ripper bar? :confused: Trying to confirm just air in the lines or is there some sort of problem with the valve? :confused3:
   / Deere 110 with BB1284 box blade, not working properly? #40
Martian, sometimes you just have to trust us. :p:laughing:
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
Kawasaki Mule 3010 UTV (A49461)
Kawasaki Mule 3010...
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
2015 Chevrolet Silverado 2500HD (A51039)
2015 Chevrolet...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
