Deere 110 with BB1284 box blade, not working properly?
   / Deere 110 with BB1284 box blade, not working properly?
Don't have a hose, where could I find one?
   / Deere 110 with BB1284 box blade, not working properly? #22
Just need 2 male QD's on 2' of hyd hose. You gotta have at least 4 on your TnT cylinders. The kicker will be on the threaded end to the cylinder - need the right connector for the QD.
AKfish
AKfish
I wouldn't want to take the hoses off the cylinders, just to much work to get them on and off and I'd be would be worried about the cylinders leaking afterward. I'm going to talk to the dealer and try and find a hose with the disconnects.
I really think it's beyond air now. I was just out tinkering and although it seems the TL cylinder works fine, the side link doesn't retract all the way, though I don't know if it is all the way extracted. See the picture it doesn't come back to level. I haven't had any issues with the FEL or when I had the BH on. Also the JUST the rear 3 ports bleed down like crazy, in about 15 minutes of being off, the side link cylinder dropped about 3 inches. After where this cylinder is it would just load the tractor. I will be stopping by the dealer a little later.
And now I just realized that the box blade is leaking fluid!
   / Deere 110 with BB1284 box blade, not working properly? #26
Tractor Supply. Might be worth having a guage too, that you could plug into your hydraulics for diagnoisis.
   / Deere 110 with BB1284 box blade, not working properly? #27
I would make sure the fittings are tight on the boxblade cylinder. This may be part of the problem, one direction it is leaking and the other it is sucking in air.
I would lower the scarifiers and shut off the engine to check these fittings. Be careful about high pressure fluid it can easily penetrate the skin.
Martian, the cost of this hose and couplers is cheap compared to dealer service rates. Air may not be your problem but it is in my thinking the most likely cause. I would ckeck over all the lines to make sure they are tight and not leaking. Remember trouble shooting can be a process of elimination as well as identification and verification. In this case you need to eliminate the chance of air in the lines by purging them. If this doesn't solve the problem you will need to proceed further, checking the pressure to the ports as suggested above.
   / Deere 110 with BB1284 box blade, not working properly? #28
Please don't take offense, but sometimes we over look the obvious. Is your hydraulic fluid at the right level? A lot of what is going on sounds like you have air bubbles in the fluid and that can be from a low level of fluid.
Just a thought
   / Deere 110 with BB1284 box blade, not working properly? #29
Steve and Mtnview are both making logical suggestions. I'd be looking at the couplers and level also. Is it just one circuit? Have you swapped cyclinders to see if the problem follows?
Matt
Just a thought
I'm really not very educated on the hydraulics stuff, so no offense taken, and I haven't looked at it. Before I ever touched it I had the dealer do a complete service, to try and avoid my stupidity, they said all looked very good, so I assumed they meant what they said. I'll check it out though. Thanks for the help.
Matt
I did not swap the cylinders. I did try all of them on the 3120 and both worked fine. It may just be air in the lines, who knows. I was so frustrated with it yesterday I took it off and put the BH on and dug up some trees:D, but I plan on putting the 3PH back on today and trying everything out again today. And at first it seemed to only be the box blade circuit, by yesterday the tilt cylinder wasn't working correctly. I had the box blade on the top circuit, the tilt on the middle and the top on the bottom circuit.
My biggest problem right now is I don't have an owners manual, so I don't know what to look at/for. I did get one off eBay. Couple years old but about $150 cheaper than the only new one I found. So I'm trying to delay a little while until I can know what I'm doing and not screw anything up worse than it may already be.
I'm going to go fishing in the engine compartment, but does anyone know where I can look for the hydraulic fluid level. It's probably right out in the open, but I haven't looked yet so I'll go look and see what I can come up with.
Thanks for the help everyone!
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2021 Chevrolet Silverado Pickup Truck (A51039)
2021 Chevrolet...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
DRIVELINES (A50854)
DRIVELINES (A50854)
