Building an ecconomical two-wheel farm wagon
/ Building an ecconomical two-wheel farm wagon #1
Verticaltrx
VA
Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I've long used a little 4x6 utility trailer around the farm for a variety of tasks. It was a little $300 cheapo from TSC, and while it has served me well it is both falling apart and inadequate.
Biggest drawback is it is too short at 6' long. You can't haul much firewood on a trailer that size, and most of all 8' fence posts put it way off balance. Also being a tilt trailer, the axle is centered giving no tongue weight. Lastly, it just isn't built for going through the woods, across creeks, over rough fields, etc. Every light is busted out, the wiring harness is a mess, both fenders long ago ripped off and the whole thing is slightly tweaked.
Awhile ago I found this old ad for a Ferguson 3/4 ton two-wheel farm wagon online. Looks about like what I need and very simple to build. (ad attached at bottom)
Mine will have a 45" x 97" x 14" bed (pressure treated), a frame and cross members made of 3" 4.1# channel, and a 3500lb axle. Tires will be 215/75R15s until I can get some 16" wheels for a set of 7.50-16 tires I have. It will have a pin hitch and no lights. While it won't necessarily be street 'legal' it will be highway towable and it might be used on the road between farms and such. Primary uses will be hauling firewood, fence posts, ear corn, square bales, two 4x4 round bales, and other misc stuff around the farm.
I got started on the frame tonight but didn't have my camera, so the pics will have to wait. I had all the metal already from some pallet racks that I bought for $20 CWT. Axle was one from another project that I'll have to shorten. Got a pile of 2x10-12's that I'll use for the bed that were leftovers from a fencing project. So far all I'll have to buy is some axle u-bolts, paint, hardware and a jack.
Might get a chance to work on it again tomorrow, pics forthcoming.
/ Building an ecconomical two-wheel farm wagon #2
Looks fun to build but consider this. I wanted a trailer recently about the same size. I went digging on Craigslist. Old Jet-Ski trailers are selling really cheap. I picked one up for 225 bux, it only had I think a 600# axle but I didn't, at the time, think I needed more. What I am getting at is there are tons of Personal Water Craft (PWC) trailers for sale for outdated, lastyears flavors of PWC trailers. There easy to modify...I cut out the 2 "u" shapped crossmembers that the bunks attached to and welded in some thinwall 2" x 2" and Viola...
Be sure to post pics whatever you do!
Sounds like a good idea, but I think I need something a little heavier. Hoping to be able to haul about 3000lbs on this one.
:thumbsup:
/ Building an ecconomical two-wheel farm wagon #4
Did you ever consider getting a surplus military trailer? You can find them fairly cheap on govliquidation.com. I bought one and I use it as a dump trailer (I'll save that for another thread). Some are older, some are 80's or early 90's models. Mine is a 1968 M101A1 3/4 ton trailer but it will haul more than 3/4 ton. I won the bid on it for $430. It measures 8' long and 45" between the wheel wells. The 1.5 ton M105 trailers are longer and wider but don't dump. Depending on the site where they are being sold, they are sometimes sold in pairs and I've seen pairs go for $500. You could buy one and sell the other, or cut them up and make a pretty hefty dual axle trailer.
Mine's rusted in places but I don't care since I abuse it anyway. It had brand new tires on it when I bought it and it works like a charm. Plus it's far more durable than any of them you'll buy at a farm store, for a lot less money. And you can pull one through the woods or across a plowed field like nothing. Just a thought...
/ Building an ecconomical two-wheel farm wagon #5
I have one of these as well. Makes a great farm trailer. I use it for everything including hauling water with a 325 gal tank and gas pump. At the moment I am loading it up with scrap iron to haul off and sell.
/ Building an ecconomical two-wheel farm wagon #6
I hear you! For what I paid for mine, I just can't say enough good things about it. I have modified a couple of things that I might show in another thread because I don't want to hijack this one. I swear, I load mine down to the point where it squats and pull it all over my property. They might not work perfect in every single situation but for the small price you get a very heavy duty trailer.
Thanks for the replies. I'm mostly building this just as a fun project that will also be useful. I like the vintage style of the trailer I pictured so that was my basis. It will fit well behind my Ford NAA and also be the right size for my little 'bota.
Only had about an hour to work on it this evening, but got most of the main frame welded up and the plates for the hitch made. Having all the cross members already cut to length makes it too easy. All told it would be equal to two full sticks of channel plus about another 4'.
I'm welding the frame with my little Lincoln sp175 welder using flux core wire. I'll probably stick weld (7018) the hitch plates on as well as the axle. Drilled the hitch plates with a 1" hole saw. Top plate is 3x1/2", bottom is 3x3/8".
Attached are a few pics of the progress. The pic of the frame is what I got done yesterday. Finished welding all the cross members in today as well as the frame joint.
/ Building an ecconomical two-wheel farm wagon #8
You are on your way to a very nice trailer.
/ Building an ecconomical two-wheel farm wagon #9
I have a customer that comes to thelandfill for shavings. He has a farm built trailer thats made from 4 inch pipe and an old u shaped axle. Its ballanced when I load 7 yards of shavings on it that a person cna one handed pick the tongue up. Its a neat looking trailer no suspension and has a nice stake bed on it. I like looking at the old farm trailers and wagons around.
/ Building an ecconomical two-wheel farm wagon #10
Hey! It looks like you have a pretty good plan and are making good headway. I'm actually working on a similar project right now. If I can figure out how to post pictures they will appear below.
I'm working with a 4" channel iron frame that is from a trailer my dad built 30 years ago and a front axle from a Dodge delivery van that my grandfather salvaged 40 years ago. When completed it will be a 4'x8' dump trailer, with 235/85R16 tires, and a 2" ball hitch. The dump will be cable operated and it will have 2' tall removable sides. In the pictures the tires are just set into place. I am having a welding shop make some custom rims because the originals were not salvageable.
Good luck on your project, please keep us posted on your progress.
Thanks for everyone's input, sounds like there are many of like minds on here. :thumbsup:
Made some good progress last night. Finished welding the axle plates in, cut the axle down, finished all the welding on the frame, installed the jack and rear hitch. The rear hitch is to pull my log splitter when I go to the woods.
The axle was a 72" Dexter 3500lb that I bought for another project and never used. To cut it down I simply measured how much needed to be cut out and cut it in my bandsaw for a nice square cut. Then I beveled the ends, cleaned off the paint and clamped it into the V of a piece of angle iron to keep it straight. Tacked around it four places, removed the angle iron and made one continuous weld all the way around. Since it is only a 4' long axle now I didn't feel the need to keep the camber in it.
The jack was just a little 2000lb pipe mount jack I picked up from TSC. I like the pipe mount jacks because you can swivel them up out of the way or take them off completely. Tires were some old 215/75R15 BFG AT's I had laying around, mounted on 15x6 wheels from TSC. This tire and wheel combo will ultimately go on another trailer, but will work here till I get the tires/wheels I want.
All in all it is going along pretty quickly. All that is left is to put the angle iron uprights on (to mount the sides to), paint it and install the wood.
/ Building an ecconomical two-wheel farm wagon #12
Looking good!
Thanks
Finished all the metal work today. Made the uprights and got them installed. Ready for paint, then wood.
Here's the final product, I think it turned out pretty well:
/ Building an ecconomical two-wheel farm wagon #15
I would have to agree. That turned out pretty nice.
/ Building an ecconomical two-wheel farm wagon #16
Great idea to make it a dump trailer. That is very handy.
/ Building an ecconomical two-wheel farm wagon #17
Great job!
Thanks for the compliments. I used it this afternoon to haul a load of rubber stall mats (about 700lb) to our new farm 70mi away. It towed great on the highway despite not having any suspension. Tomorrow I'll haul off some building debris at the new farm and bring home a load of wood chips, this weekend a load of firewood. Maybe get some more pics with a good load on it.
When I get a chance I figure up a list of materials and prices for anyone that might be interested in building something similar. It might be a couple days though, I've been pretty busy lately. :thumbsup:
/ Building an ecconomical two-wheel farm wagon #19
... It might be a couple days though, I've been pretty busy lately. :thumbsup:
Of course you've been busy. You have to tackle all the projects that have been waiting for an economical two-wheel farm wagon.
1989 Fontaine Flatbed Trailer (A64912)
1989 Fontaine...
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
2000 Terex D50 (A64911)
2000 Terex D50...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
