DIY Ratchet Rake
/ DIY Ratchet Rake #21
I'd just paint it whatever you have plenty of. Sooner or later it gonna chip off completely from heavy use. :thumbsup:
/ DIY Ratchet Rake
Orange tractor... Orange bucket......paint her blue!! No No No paint it orange!!!! :laughing:
Like I said, Kubota orange is definitely a consideration, but kinda expensive to just rub in the dirt. :confused:
High Compression,
Great job! How did you know i wanted one? My bucket is kinda a blackish color, so black will be fine. You should recieve the paint in the mail shortly :laughing: :laughing: :laughing: . . .again great job .. .John
Hey thanks! Blackish??? So is it black or isn't it? :laughing: I'll be lookin for that paint. Are you offering to be a paint sponsor???:laughing::laughing::laughing:
/ DIY Ratchet Rake
Very true. That's kinda what I was thinkin. I have $8/can Kubota paint or $.97/can black Wal-Mart paint. I'm leanin toward Wally World paint. Or free paint from another TBN'r. :laughing:
/ DIY Ratchet Rake #24
Great job on the Ratchet Rake!!!:thumbsup:
/ DIY Ratchet Rake #25
Awsomeness! I am taking notes...
How hard would it be to pop off those blade bolts and put in anew perhaps, then weld RR-Charlie to the blade and re-attach? Buy a new straight blade so when you take Charlie off you can go back to normal?
OR
Remove blade and attach RR directly to those holes? (looses a lot of strength)
If that were feasable you could trash the straps and washers, all for the price of drilling some holes and some new bolts?
The Vine-Ripper on the ends is a great idea, if she holds...:) I predict your
going to want to leave the V that is pointing rearwards out, do not cut it, for reinforcement.
Do a u-tube! Great Job! Sub'd
BLACK
(ps, I hope I don't sound like a Monday morning quarterback...did you think about my suggestions? inquring minds what to know! )
/ DIY Ratchet Rake #26
PAINT COLOR suggestion:
Paint it RUST COLORED so it will always look the same, even after heavy use. :)
/ DIY Ratchet Rake #28
Is the ratchet rake better than a root rake? Or just more economical?
Nice job on your diy project.
/ DIY Ratchet Rake
OR
BLACK
Ya know, that thought crossed my mind, but two straps are way easier and quicker to attach and remove with no tools than 7 bolts that need an impact. I toyed with the idea of a quick pin on version versus straps, but haven't gotten anywhere yet. I'll let you know if I come up with a better way to attach it.:D You tube ain't a bad idea. Next job I have to use it, I'll try to video.:thumbsup:
/ DIY Ratchet Rake
:laughing: :laughing: Then it would match a lot of my other attachment. They are already that color.:laughing: :laughing:
Yup. Just like your answer. Simple "Black". I'm a fan.:thumbsup:
/ DIY Ratchet Rake
Well...
They are kinda different and kinda similar. The root rakes I know of are mounted from your 3 point and can drag some stuff out. However they are pretty flexible compared to the Ratchet Rake and you wouldn't want to try and tear out small trees, roots and all with the Root Rake. At least not the ones I've used. Plus with the Ratchet Rake mounted on the FEL you can reach limbs and vines up high. So, they are kinda different. If was clearing a lot of brush, I would use both. The RR to reach in and get the tough stuff. Then use the root rake to drag all the loose stuff that I removed with the Ratchet Rake, over to a pile to burn, haul off, etc.:cool2:
/ DIY Ratchet Rake
I can't believe how fast you work. Wow.
When I set my mind to something, I can't hardly sleep until it's done. So I guess it might seem fast to you, but it took me about 14-15 hrs. :laughing:
/ DIY Ratchet Rake #36
Great lookin' job!!!... Black always looks good!!:D
Thanks for sharing!!
/ DIY Ratchet Rake #37
High Compression said:
Black won!
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=254735"/>
Looks Great! I suppose you need my shipping info now? ;-)
/ DIY Ratchet Rake #38
That looks great! I might have to get you to make me one one day since I only live 20 miles from DeSoto! I'll furnish the beer and steel plus throw in a few bones for you.
/ DIY Ratchet Rake
Very true. That's why buy it by the case from Wally World to keep on hand at the shop.:thumbsup:
Your welcome!
:laughing: I suppose so. Guess I'll have to get more steel. :D
Right On! You'll have to come by the shop. I'm always tinker'n make'n somth'n! :thumbsup:
/ DIY Ratchet Rake #40
Black won!
Black and orange ... go Bengals ;)
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2013 Kuhn Krause 80-40 Vertical Tillage Tool (A63116)
2013 Kuhn Krause...
CASE 610 Sprayer System 2000 Gallons (A63118)
CASE 610 Sprayer...
Spray King Pull Type Sprayer (A63116)
Spray King Pull...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63118)
2023 Kubota L3560...
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
