Electric Inverter Run off Tractor
/ Electric Inverter Run off Tractor #1
Joe1
San Luis Obispo, CA
1998 JD 770 & 2004 Toro LX417
I have a 770 John Deere with a 20 amp alternator. I want to be able to run an electric pole saw (8 amp) and some other small electric tools by hooking up an Inverter that would develop probably 1,500 watts continuous power. I know the 8 amp 110 volt motor will draw about 960 watts ac or about 80 amps DC. The saw would only run for a minute or two at a time. A 1,000 watt inverter would be close to the max draw and would probably not last too long at that rate.
I also do not want to hard wire the inverter to the tractor if I can avoid it. I would like to be able to place the inverter in the front of the tractor with alligagtor clips to the battery thru the grill opening (which I would remove or open). I don't want the inverter full time on the tractor as it will only get dirty and fail earlier, hence the alligator clips.
I would be running the tractor at rated rpm while using the saw because I would also be running my 5" capacity bearcat chipper/shredder at the same time.
In theory it should work, but it seems like a heavy draw on the engine battery. I've also be unable to find alligator clips large enough to handle the wiring for an inverter. The only thing I though would work would be to buy a set of jumper cables, cut them to about 2' lengths and add "eye" attachments at the othe end to connect to the inverter.
Internet research doesn't seem to come up with any reliable inverters under about $300.00.
I'm trying to avoid buying yet another implement with a gasoline engine and still be able to use the electric power for drills, etc.
Any suggestions would be a great help, so thank you in advance.
/ Electric Inverter Run off Tractor #2
I'd probably replace the 'current' battery, with an RV or electric boat battery to ease the draw down.
I run all my high current electric stuff (including 220v stuff, off the outlets on my PTO alternator. For example I have a Stihl electric pressure washer which makes a great tree sprayer. I hook up the alternator, put a 140 gallon horse tank in the front bucket with a drain line into the pressure washer.
Only complaints so far are from mosquitoes and gypsy moths. I used to run my 110v hedge trimmers out at the road this way too. Then I bought a 24v battery powered one because other members of the family got into it.
A decent inverter to handle your load may be as expensive as a new 12 - 15kw pto alternator. Used farm grade alternators around here go for $800 - $1500 at auction or on Craigslist. I got my 50kw Winpower at an auction. You have enough power to run it (in spite of what 'they' will say). In fact, I made an adaptor to run my 540 rpm Winpower off of the front 2200 rpm pto shaft of my JD-F935 diesel lawnmower. I believe its about the same motor as you have in your 770 (22 hp ?).
Thanks for the response. I've got about 25 hp and 20 at the PTO. I was unclear in my message about the set up. I run a PTO driven chipper and would use it at the same time as the tree trimmer, thus the rated HP rpm while using the trimmer.
I certainly wouldn't need anything as large as you described. At that price, I'm into a new 2kw Yamaha or Honda generator.
Good point about the battery. There is room for a size 27 or evan a 30 under the hood.
I need to do more research. I'll look into PTO generators.
/ Electric Inverter Run off Tractor #4
I have been using an inverter setup for over 6 years now. It meets the same power requirements you stated you will need. I have a barn far away from the house without any power, so I hook it up whenever I need to run the grinder, blower, or a small air compressor for tire inflation. The battery used is the one for my Kubota L3400. I can use the grinder to sharpen the bush hog blades along with the blower to clean the tractor and Bush Hog without running the tractor to keep the battery charged up. It's a big plus for me to have power without the drone of a generator, not to mention yet another piece of equipment to maintain.
Here's what I have and the current cost is less than $300.
- TrippLite PV1000FC (non longer in production), current equivalent - PV1000FC (Tripp Lite PowerVerterョ 1000W Compact Inverter with 4 Outlets (PV1000HF)). The difference physically is the PV1000FC uses a copper coil and the PV1000FC is electronic. So the difference in weight is 20 lbs vs 6 lbs
- 100 Amp Alligator Clips and cover - Automotive Clips, Battery Clips
- 4 AWG, 10ft length, cable kit - [ame=http://www.amazon.com/gp/product/B001550DVU/ref=oh_o03_s01_i02_details]Amazon.com: Cobra CPI-A4000BC 4-AWG Heavy-Duty AC Power Inverter Cable Kit: Automotive[/ame]
/ Electric Inverter Run off Tractor #5
You might consider a deep cycle battery hooked up to the alternator with a one way switch so it's isolated from the tractor battery system.:)
/ Electric Inverter Run off Tractor #6
HF has cheap, big inverters.
you can get large 2 pole DC to DC molex type plugs for quick connection..
storage battery will handle the load.. alt won't like it.. but... i imagine you will get plenty of use out of it before an early failure would occur.
soundguy
/ Electric Inverter Run off Tractor #7
If you are doing what you want Put a larger Alternator on your tractor.
60 or 80 Amp Alternator would keep the charge and then extend the life of the battery in the long term. (second hand from a wrecker )
Or you could go the other way and get a transformer for your generator.
If you try to run it with a 20 Amp Alternator you will chew through batteries.
Mark:
Sounds good to me. I knew I came to the right place asking on this net. As I read your post, you can use the grinder and blowe, etc off the inverter without starting the tractor. What is the size of the battery on your Kubota and what is the alternator output?
How do you attach the inverter to the tractor? I was thinking of making a wooden bracket that would slip into the suitcase weight hanger. That way the inverter is near the battery for a short run and out of the airstream for the tractor engine and not in the way of the loader so it would be mobile. I would imagine the electronic inverter should be cooler running than the copper wound one. Any idea the amperage draw on your grinder and blower?
Thanks.
Joe
/ Electric Inverter Run off Tractor #9
Not sure what your consider to be "reliable" but here is a listing of 1500W inverters - many around $125. As an example, there is a Xantrex brand on sale at a local auto store this week for $109 reg $ 179.
1500 Watt Power Inverter - Compare Prices, Reviews and Buy at Nextag - Price - Review
For your load I'd suggest going at least 1500W. Even for the 1000W size look at hard wiring to the battery, including a suitable fuse. If you don't want a permanent mount look for a suitable quick disconnect. Be aware many inverters will be in 85% range for conversion efficiency, so you need to factor that in when considering size.
A larger battery would probably be better, however, a lot will depend on how long you intend to run the tool and how long between duty cycle.
It's pretty much a math exercise based on battery capacity, load, duty cycle and charge, whether it will work for you. Keep in mind if the battery has 100 amp hour capacity only approx 1/2 that amount is usable. Part of your problem will be that starting batteries are made for high amp short time application, whereas inverters work better off deep cycle battery such as Golf Cart batteries or others designed for lower amp / longer time.
/ Electric Inverter Run off Tractor #10
got a pto gen ? :)
Sound guy:
I don't have a pto gen but can't run a pto gen and my chipper/shredder at the same time. I'll be running the chipper while tree limbs are being cut with the saw. Thanks for the input.
/ Electric Inverter Run off Tractor #12
could 2 step it if you had the pto gen....
here's one I say.. not same setup as you.. but similar.
guy hooked a 50$ 90a gm alternator to a frame he built on an implement. he could pto power the implement and it also ran the alt.. that charged a big 4dlt bat on the implement that was hooked up to a 2500w inverter. Inthis case it was a pto cement mixer for a small construction sidte. guy had a lil SCUT tractor with loader and that pto cement mixer witht he alternator :) inverter ran his power tools off the huge tractor battery.. gm alt kept it charged up..
another one i see alot at tractor shows is people taking old push lawnmowers, removing the blade and putting a gm alt on it and a small car battery, and then they have a push around 'jump starter' for tractors needing a boost. quick pull start and then a good jump.
neat lil rigs.
I plan on making one when my push mower gets a lil too old to do the job.. :)
use that to power an inverter with a bat combo.. etc.. :)
/ Electric Inverter Run off Tractor #13
It is important to minimize losses in the DC feed. A battery clamp with a stud you can use a butterfly nut on would make a much better connection than alligator clips or clamps. You want clean and tight or itll starve the invererter of voltage and it will kick off.
larry
/ Electric Inverter Run off Tractor #14
larry
How about some Anderson Powerpoles. I use smaller versions for my Ham Radio eqpt. but they make them big enough to run an electric forklift, and some in between.. Mount them so that they are out of the weather under the hood. and good direct permanant connection to the battery thru a heavy duty fuse of course., put them on the inverter, so you now have a good high current low resistance connector that is self cleaning due to their nature, and your inverter is easy on and off. I have used dozens of the smaller ones, and I really like then. Most APC UPS's will have the larger ones inside to hook up the batterys. This is how I would do it.
Anderson Powerpole & SB Multipole Series Sets: Bags of housings and contacts in different sizes
James K0UA
/ Electric Inverter Run off Tractor #15
Excellent suggestions IMO ^
You will get a lot more power through a disconnect than through a pair of clips. No messing with trying to get the clamps on right either.
Aaron Z
/ Electric Inverter Run off Tractor #16
My concern would be the prolong draw... it should work for a few minutes just fine.
Since 1990 I have run a 1500w statpower inverter... cost about a $1000 back then in my truck... even runs my small air compressor... I have a group 29 RV battery and upgraded to a 120-30 watt alternator... the biggest I can run with a single belt.
Mine is hardwired but I have also used old stick welding cables and the plug in ends to make another one portable...
/ Electric Inverter Run off Tractor #17
James beat me to what I was going to suggest, which was electric forklift charging connections. I have the charging end, but not the battery end. (48v).
When I was running over the road as a truckdriver, I used several different inverters. The one incident that came to mind was a 500 watt inverter that would trip out when I plugged my laptop in if it was almost completely discharged. If it was 1/2 way discharged, no problem but fully discharged was a problem. Turned out the cigarette plug I was using was not carrying the load needed to give the inverter full capacity. A change to hardwire immediately solved the problem. Later a connector similar to what James suggested was procured from a used source and that eliminated the problem completely. My 2000 watt inverter REQUIRES hardwiring but it has reverse capabilites which allows it to charge a battery in addition to deplete it. (Exide brand, no longer made)
David from jax
/ Electric Inverter Run off Tractor #18
your tractor has what is called a permanent magnet alternaor the rating of 20 amps pretty well will max out the output as someone has already suggested going to a higher out amp rotor stator activated alternator would solve that end of the problem as stated many times on this forum 10/12si delco is the most common one to use if you get a true 12si it will be a 94amp unit. they are a couple of small denso units that can be used also. my personal thought from past experience is if you dont bump up the amp output your ongoing life of the charging system is going to be very limited but what you are trying to do can be done. also as someone mentioned the lawnmower/generator is somewhat simple to build google 'converting lawnmower into generator' this will tell you all you need to know in building this set up and most of the stuff required you probably have or can be gotten very reasonable in fact i have a 10hp briggs that i am planning on doing later
/ Electric Inverter Run off Tractor #19
A big alternator is not necessary unless your electric drain is a high duty cycle. We run a 1000W inverter on the BX1500 for limbing and occasional big cuts. The battery takes care of it. It does fine with a 10A alternator. No problem in 9yrs.
larry
/ Electric Inverter Run off Tractor #20
larry
My thoughts exactly. Didn't the OP say he was going to run for about 2 minutes? I ASSumed that to mean the inverter would be unused for many minutes in between while he was chipping. I am thinking he is good to go as is. I still think my Anderson powerpole connectors are a good idea for good connections and quick removal.
James K0UA
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
