Backhoe hydraulic hoses
/ hydraulic hoses #1
caserick
los lunas new mexico
Case 580B
I recently bought a Case 580B Backhoe that requires changing hydraulic hoses...would like for someone to give me a trick or two on the easiest way to loosen rusty hoses. I made an attempt on a few and had no luck as i was afraid to break something...
/ hydraulic hoses #4
I've used a grinder with a diamond wheel to cut the nut down to where you can see the threads, stay away from the end of the pipe where the seat is. Cut 2 sides and then try to turn it.
Do not cut all the way through the thread, half way will do.
I had an old Case hoe that had the same problem and this got them off.
Tip #2, stay far away from the Case dealer. Surpluscenter.com or Hydraullic Hose, Fittings, Adapters and More at www.HydraulicWarehouse.com
/ hydraulic hoses
I will attempt to put heat to them first and if that doesnt work I like this idea also...not sure if i trust myself though...my neighbor on the other hand...thanks! Case dealer? Did you have a bad experience with them?
/ hydraulic hoses #6
Point being dealer is very expensive.
I would run it unless the hoses keep breaking. If you just want all new hoses, remove them and take them to a full blown hydraulic hose and fitting shop and have them match all your hoses.
You will save a fortune over the dealer. In some cases(situation) you may want to add a swivel on each end for ease of installation.
APPROX (50)UNUSED CORRUGATED METAL SHEETS (A64281)
APPROX (50)UNUSED...
2025 JMR Tree Boom Skid Steer Attachment (A61572)
2025 JMR Tree Boom...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
KUBOTA 72" PIN ON BUCKET (A64280)
KUBOTA 72" PIN ON...
