stihl. will double your warrantee
/ stihl. will double your warrantee #1
escavader
western maine
bx-23 ,
My1987 028 finally gave up due to lack of compression.I may rebuild some day.for now I bought a new ms. 290. Stihl extended my warrantee from 1year to 2 for buying a 6 pack of their synthetic oil good deal I needed oil anyhow.hopethe 290 last as long as the O28 did
ALAN
/ stihl. will double your warrantee #2
How much is the 6 pak?
I dont use their oil but I am getting ready to get some stihl stuff pretty soon. 200T, mini tiller and backpack blower maybe.
/ stihl. will double your warrantee #3
Please don't say you bought a 290 farm boss. All these chainsaw experts will let you know what a piece of sh*t it is. It's too heavy, its not powerful enough, it's not a professional saw, on and on......
/ stihl. will double your warrantee #4
Are you f***ing serious? :confused:
/ stihl. will double your warrantee #5
The MS-290 Farm Boss is OK for a homeowner saw, and it's Stihl's most popular model. But there are better choices in Stihl's lineup for pro use -- for example, you can get the same power, better construction, lighter weight, lower fuel use, and better emissions in the MS-261. But it's also another $200!
/ stihl. will double your warrantee #6
I bought a Stihl weed eater last year and the dealer extended the warranty by doubling it also when I bought their oil.
/ stihl. will double your warrantee #7
You really cannot go by "what experts say" because everyone comes from a different set of use criteria. The 290 can be a dandy saw for a home owner especially at its price point. Does Stihl make a better saw? sure they do. Will this saw more than suffice for the average guy? of course it will. Because of its use point, it does not make this saw a pos in any sense of the word.
/ stihl. will double your warrantee #10
I have noticed, however, that the modern Stihl products do not have the longevity of the old Stihls (in the smaller sized models). I've switched to Echo for small sized chainsaws.
My 026 runs and runs. Never a problem. I had a Stihl 180 for light work. It always had a flooding problem and then one summer, it wouldn't start. Took it in, and they informed me the cylinder was bad. It was a 3 year old chainsaw with only a half dozen or so tanksful of fuel through it. I went back to my old (as in 12 year old) Echo CS3000 and tuned it up. Same thing happened with a Stihl weed trimmer.
I run the same mix in all my 2 strokes (all within the manual specs) and have to think that the smaller Stihls don't have the engineering and manufacturing that the older models (and likely the larger models still have).
/ stihl. will double your warrantee #11
Who you calling sarcastic? The 290 is a sissy saw and a real man wouldn't own one.
/ stihl. will double your warrantee #12
Good try . Had me fooled the first time but now your gig is up (or maybe not to the uninformed)
/ stihl. will double your warrantee #13
The 290 is fine. This is a picture of a morning worth of felling, delimbing, and bucking a stand of dead and diseased mature Loblolly pines. Sure it's a bit heavy and could be a bit more powerful but I'll keep the extra $200. Thanks.
/ stihl. will double your warrantee #14
IIRC I think the 6 pack of HP Ultra oil is about $20 or so.. well worth the cost to get the double warranty considering you need the oil anyway..
REMEMBER - the oil has to be shown on the same receipt as the equipment to get the double warranty
brian
/ stihl. will double your warrantee #15
I'm just thinking on a leaf blower, tiller 2 year warranty = 4 years :D
200T Chainsaw 1 year goes to 2 years. :thumbsup:
Trimmers and Brushcutters, Clearing Saws, Edgers, Blowers and Sprayers, Hedge Trimmers, Pole Pruners, KM Series, Wet/Dry Vacuums and MM Series
2 years
I will just use the stihl oil for testing stuff after I work on them. I buy Klotz Original TechniPlate 100% synthetic by the qt or gal cases.
/ stihl. will double your warrantee #17
Now I find out. Just got a replacement MS460 and a gallon of Ultra oil. I guess that does not qualify. Wish the dealer had told me.:mad:
/ stihl. will double your warrantee #18
The STIHL Ultra Limited Warranty Double Your Warranty Protection
Double limited warranty protection applies to STIHL gasoline-powered products purchased for personal non-income producing, family and household purposes only. At the time of your equipment purchase, simply purchase a six-pack of STIHL HP Ultra engine oil or six 32 ounce containers of STIHL MotoMixョ premixed fuel to qualify for double the limited warranty coverage. STIHL HP Ultra provides the best engine oil for improved engine longevity. Restrictions may apply.
Effective date: January 1, 2012.
Purchase STIHL HP Ultra 2-Cycle Engine Oil & Double Your Warranty | STIHL USA
/ stihl. will double your warrantee #19
sounds like you are basing your opinion on just one example...and that from an example that had hardly any use. Scored cylinder after that little use is an almost sure example of 'straight gasing'.
Harry K
/ stihl. will double your warrantee #20
For some reason a lot of dealers dont tell you around the double warranty for some reason.. That is based on what ppl have posted (like you) on here and a few other forums
Brian
2014 Toyota Tundra Single Cab Pickup Truck (A60352)
2014 Toyota Tundra...
2013 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2013 Peterbilt 567...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
iDrive TDS-2010H...
