HTL suggestions for m7040?
/ HTL suggestions for m7040? #1
4105deere
Member
middle ga
JD 4105
Already starting to look at hyd top link for m7040.Tractor should be here by noon. Best suggestions?
/ HTL suggestions for m7040? #2
I am guessing this is a BIG tractor. CAT II 3PT hitch. I would check the owner's manual and see if it specs the minimum and maximum length for the top link. If not, take measurements from the actual top link.
For my JD 6415 the owner's manual states 20.9" to 28.5". Surplus Center has Swivel Ball End Cylinders with 1" pin holes. Correct size for CAT II. I plan to use a 3" bore cylinder. A 10" stroke will cover 18.25" to 28.25". A 12" stroke will cover 20.25" to 32.25" I am leaning towards the 12" stroke, thinking a little longer will be than a little shorter.
They use SAE 8 ports which I prefer over NPT.
They do not have POCVs which I do not need since my SCVs have built in checks.
/ HTL suggestions for m7040? #3
3" dia cylinder with a working length of 20"-30" cat 1-2. cat 1 end at the tractor and cat2 at the implement end.----------------------------$225
Hose kit with 3/8" hoses, 36" long with 1/2" male AG quick connect ends. -------------------------------------------------------------------$40
Hydraulic flow restrictor, this allows for precision adjustments to be made much easier. -----------------------------------------------------$10
shipping costs ??
If you are going to be doing much grading, you may want to consider a hydraulic side link also. ;)
/ HTL suggestions for m7040? #4
With the top link being longer than OEM, you may have transport problems. As in not being able to lift the tail end of the implement up high enough to clear rough terrain or loading onto a trailer. Always something to think about. Also be sure that the link that you get clears the mount on the tractor when it is installed. You don't want anything binding up.
Tractor has arrived but also raining. Will check asap on oem specs. Dealer mech said scv has built in checks. And may get hyd side link as suggested.
Measuring oem top link ie 20"-almost 30". If I get a htl the same, how will that cause a problem by being longer? Maybe Mtn view has an answer.
/ HTL suggestions for m7040? #7
If you can find one that starts out at 20" & extends out further than 30", go for it. No harm done, it's just may experience that if you want a 12" stroke, you are going to be looking at a working length of 22"-34" and IMO 22" is to long of a retracted length for your M7040.
Just my :2cents:
Mtnviewranch I understand what u mean now. I'll try hooking up tomorrow at shortest setting to confirm there are no issues. I'm thinking 20"-30". If that works its fine with me.
/ HTL suggestions for m7040? #9
It would only be longer at full extention. Retracted it would be .65" shorter than retracted length of factory top link.
The 10" stroke cylinder would be 2.65" shorter (fully retracted) than my factory top link fully retracted. I worry it would be possible to retract too much with this extra 2.65" and pull something into the tractor causing damage. Hence my reason for using a 12" stroke cylinder. :confused:
/ HTL suggestions for m7040? #10
Zebrafive, Do you have a link to the hydraulic that you want to use? The 20"-30" top link that I am talking about is built for the Kubota M7040. Your tractor is different, You only have a single hole to mount to. The M series have 3 holes to choose from. The top link mount on the tractor is completely different than yours. Where you can probably get away with the Surplus cylinder, 4105deere may very well have a problem with it.
/ HTL suggestions for m7040? #11
Ok mtnviewranch bear with me, Im still me just changed my handle (formerly 4105deere). Really ready to get htl and side link. The one you have for my new 7040 (gettn goosebumps) will be just what I need right?
/ HTL suggestions for m7040? #12
DWT, yes unless you are going to use Pat's quick hitch or something similar which most people with the lower extend-able ends do not go to. Email me at Fit Rite and I will get you an exact cost and everything that you would be getting. I just shipped a complete "TnT" kit last month to a dealer in New York for an M7040. By chance does one of your rear remotes have float position or are they both the self canceling detent type?
Just wondering. :confused3:
/ HTL suggestions for m7040? #14
Self canceling.
Bummer, would have been nice to have at least one with float for the side link, oh well. :( See if they will exchange one for one with float, or add the 3rd remote, you are going to need the 3rd remote anyway. :cool:
/ HTL suggestions for m7040? #15
Surplus Center item number 9-7261-12
Yes my tractor only has one postion for the tractor end of the link.
So in your post #4, were you refering to me or 4105deere? I was trying to understand why you thought being able to extend longer than std link would be a problem? Just retract it too long :confused:
/ HTL suggestions for m7040? #16
No, post # 4 was for you. When you can't retract far enough, there are many times when the implement will hit the dirt when you don't want it to and you can't use the hydraulic top link to pick the tail end up any higher because the top link is collapsed all the way. This is common when in rough terrain or when loading onto a trailer. I think that the ideal configuration is to have the hydraulic at mid stroke when the implement is parallel with the ground that the tractor is on. In most cases it seems to work out best to match as close as possible to the OEM top link. If item # 9-7261-12 allows you to be collapsed as short or shorter than your OEM top link, then you would be good to go.
/ HTL suggestions for m7040? #17
I hope to have the 3rd function installed in march. Its on back order.
/ HTL suggestions for m7040? #18
OK, that clears it up! :) Thanks :thumbsup: That cylinder will collapse shorter than the OEM top link. I plan to use 1/4" hose. Then if too fast add resrictors.
Size and weight of my tractor means I will not be trailering it. I would need a bigger truck and trailer :D
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2008 International 8600 Day Cab (A62613)
2008 International...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
