The gully to pond project
/ The gully to pond project
Well, well, well, look what thread I dragged to the top of the forum.:D
Last summer it was so hot and dry that I just put the pond on hold. Then, last fall I started it up again, but I got out of the habit of posting to this thread, so I'll get started again and bring it up to speed.
Last June, I had just dug the core trench for the dam when I quit because of the heat, dry sand, and blowing wind that turned the whole area into a giant sand blasting machine for exposed skin. Pictures of the core trench are shown below.
After a bit of rain in November 2011, I got back to work with filling the core trench for the first dam. In the photo below, you can see the red clay filling the trench and I added some text to show the knob of land I'll remove to mine for more clay. The entire center of my dam will be pure clay with a mixture of clay and sand on the sides. The excavated caliche seems to pack very well when mixed with a little clay. The dam will be about 55' thick at the base and 15' wide at the top with a driving path across the dam.
By the first of February, I had excavated most of the clay and pond basin while building up the dam. Here are three progress shots. The first one shows the location of where the overflow will be. I plan to put in two plastic culverts at a level at least 3' below the level of the top of the pond. From what I've seen with my other ponds, that should leave plenty of freeboard. I can always add more fill if that proves to be wrong.
Earlier in the year, I felt really bad when we had 3" of rain and I had to let it all run away. Now, with the dam in place, even a small rain puts a little water into the pond. We had a pretty good downpour of around 1/2" and it put some muddy water into the pond. I pretty much danced a jig on the dam because all this work has been leading up to this moment (1st picture).
The second picture shows the surface of the dam and how the clay compacts by driving my 20k lb TLB back and forth over it. If I do it with a full bucket, the front tires really do some serious compaction.
The third picture shows the backside of the dam and some loose dirt before compacting. Yep, my New Holland CUT and my TLB can go up and down this steep incline due to 4WD. I can compact the loose material with the CUT and then the TLB does the final compacting. You can get a hint of what the backside of this dam will look like if you figure the water from the 2nd pond will only be down about 12' from the top. Of course, that's if I ever get enough rain to fill both ponds.:)
Here are some photos showing how the pond looks today after another 1" rain and some final excavation. I built a small temporary terrace to direct water flowing down my hillside to the pond. I'll rip-rap the area where it drops into the pond to eliminate erosion. Also, I'll widen the terrace later and get it seeded with grass.
I've run out of clay since I don't want to cut back the high-side hill around my pond any further. I went exploring and found a spot with enough clay to build all the dams I want. It's pure red clay and NO ROCKS.:D Unfortunately, it's a long way away from the area and I can't go the short route because of deep gullies (1st picture). I don't want to build a road through these gullies and cause more erosion. I decided to haul the clay out and along my road. The last photo shows the path in green. The black line is the shortest but not feasible. Also, I cannot get my dump trailer into this area because it would sink into wet soil. The same would be true of a dump truck. I can haul 1-1/2 yd with my TLB, and using the road makes the trip very quick. I can live with this for the last couple of feet of fill on the dam.
So that's where I am as of today. The challenge is keep building the dam until it is at a final height and wide enough on top for a road across that will allow someone to stop in the middle of the dam and get out without being uncomfortable because they are too close to the water. I think 16' wide on top is minimum. Probably, I need 20' wide if I want to add a decorative fence/guard rail on each side.
/ The gully to pond project #147
Thanks for the updates Jinman, I wonder if your redclay is like our blue. sticks to everything and holds water great.
Does your blue clay stick inside the bucket in big globs that have to be chiseled out?:mad: If so, it is just like our red clay. It seems that our red clay is soft and sticky when wet and hard as a brick when dry. It's hard to find a happy medium. But like you said, if you made a bowl out of this clay, it would hold it until it evaporated. It's the perfect clay for making dams. Some materials places mix the clay with sand and come out with a fill dirt that spreads perfectly and sets up like a brick with compaction and a little moisture.:thumbsup:
/ The gully to pond project #149
Jinman, sounds like the same, when I use my baby mini excavator with the small bucket it is a real pain to keep it cleaned out. That stuff can pack in like brick. Its funny you mentioned about mixing it with sand. I mixed some of mine with sand and used it for a base on my drive, put #2 crushed rock over it and it is great. Not much will grow in it :D clover seems to do real good, which for me is good my bees they love clover
How did you do the sand/clay mix? I have about 250 yd of sand I took out of a sandbar at the mouth of a creek and have been thinking of mixing that with the clay. I'd put down a layer of each and then run over that repleatedly with my 6' wide KKII tiller. I'm thinking the clay would have to be pretty dry, but that should work for mixing. What do you think?
/ The gully to pond project #151
jinman;2725542 I pretty much danced a jig on the dam because all this work has been leading up to this moment (1st picture).QUOTE said:
Jim,
I couldn't resist making the little animation attached when you said you danced a jig. It plays fine locally on my IE-9 browser and depending on what TBN does to the code it should work if you open it full in your browser.
It should work on Firefox and Chrome although the colors may shift a bit.
I doubt if it will work on a MAC.
Will be a good test of what TBN does to images..
Ron
/ The gully to pond project #152
Jim,
Ron
It works on my Firefox :thumbsup: ... but that's not dancing on the dam!! :laughing: :D
That's one cool bird! My gig looked more like the chicken dance without an accordion accompaniment.:D
Works in Chrome just fine. . .
/ The gully to pond project #155
Gonna have a lot of Water for your Garden :D:thumbsup:
/ The gully to pond project #156
That be easier then what I did one scoop(mini ex) at a time, plus I tried to lay it in thin layers. Yes I did wait for it to dry much easier to work with.
I think the professional guys use big drum mixers, but those are not in my budget. All my money is going to culverts and rip-rap.:confused2:
/ The gully to pond project #158
Jim,
I don't know where you are buying culverts, but for the last 5 years, I have been buying black double wall culverts from Contech Construction Products. Yesterday I picked up 60 feet of 8 inch culverts for $3.17 a foot. Local guy wanted over $10 a foot. A few years ago, I was pricing 24 inch culverts and found them as cheapest. They are still the best priced.
hugs, Brandi
Brandi, TSC has 15" dia. x 20' long plastic culverts for $199 each. I don't know that one culvert would be enough in a heavy rain, but don't want to go to 24 because the culvert would need to be buried 11" deeper. I'm thinking two 15" culverts side-by-side with 18" of clay between them for a good seal. That will give me the flow I need and allow plenty of freeboard up to the dam level. One of my problems is that I sold my 18' utility trailer and only have my 12' dump trailer. I'll probably have to have the culverts delivered. I'm going to check with a couple of local lumber yards too. If I can buy local for nearly the price of TSC and give a local business my money, I'll do that, even if it's a few more dollars. One little lumber yard offers free delivery.:thumbsup:
/ The gully to pond project #160
Jim,
<sigh> Conroe TSC does not carry culverts. Our Lowes did, but do not now. That is where I bought my 15 inch culverts for the pond's overflow under the driveway. Contech Construction Products has a plant or yard here.........
Arlington Plant
2020 W Division St
Arlington, TX 76012
Phone: 817-265-2255
Fax: 817-265-2250
Houston Yard
12040 Tomball Pkwy.
Houston, TX 77086
Phone: 281-272-5655
Fax: 281-272-5653
Schulenburg Plant
232 Oakland Rd.
Schulenburg, TX 78956
Phone: 979-743-4123
Fax: 979-743-3120
Seymour Plant
1100 N. Main St.
Seymour, TX 76380
Phone: 940-888-3871
Fax: 940-888-5333
Sulpher Springs Plant
1009 S. Como St.
Sulpher Springs, TX 75483
Phone: 903-885-0673
Fax: 903-885-6978
Taylor Plant
220 Gym St.
Taylor, TX 76574
Phone: 512-352-8592
Fax: 512-352-2587
It might be worth your $$$ to check them out. I do know they deliver also, at least from the Houston yard.
hugs, Brandi
