Let's see your welds...
/ Let's see your welds... #21
As a current welding inspector in the power generation industry,I honestly could never tell you how to do your job and quite honestly only struck an arc 30 years ago in ag class. It is also against policy to tell anyone how to do their choosen trade,unless its a safety issue, so it important ya'll share the trade with ones coming up through the ranks. In the 25 years of inspecting I have seen the quality of this trade fallen off,mostly do to the lack of ongoing construction. There are still some fne welders out there, but many of the old hands have moved on mostly due to poor eye site aquired from burning rods.
As an inspector I can only tell you if is good or bad,many times if we are there throughout the process, we have the ability to correct issues before its incapsulated in the final product, those issues are only found thorugh volumetric means (Subsurface inspection techniques) either radiography (RT) or ultra sound (UT).
A class 1 weld goes through various holdpoints, typically there is the fit up, we check root gap opening, grove angles, etc..verify pull back if its a socket joint,then check the tacs for a s s h o l e s or pull out even on the ID of the tac with a mirror, verify its crack free and ensure the ends are feathered (Ground for the root pass tie ins),then we check the root,we must verify its crack free, with no excessive penetration (drop through) or excessive suckback and good fusion along the basemetal. Typically this is all visually performed and we must look at the inside the pipe when the butt joint is accessable. On the interpasses,we check for cleanliness,,fusion, undercut, laps,etc. most times we perform NDE on the interpasses either dye penetrant for stainless,or mag particle for carbon. Once accepted, we don't see it again till its capped.
Final visual we check for undercut,overlaps,excessice reinforcement,uniformity, cracking (Shrink or craters) excessive weld beads if its as welded, etc.. but most time its prepped for NDE,or flat topped with a smooth transition into the base metal, once the visual is accepted, we then perform a surface NDE exam dye or mag, if its good, we go volumetric, RT or/and UT. If the surface exam fails, the welder reworks,then another visual performed,then surface,then volumetric. (All this is for piping welds,not structual)
I could never tell ya'll the first thing about welding or set up,I can gives ideas on causes on the failure if asked.
Its been my experince the welder knows if he has had issues during the welding process. Its a very involved process,but we take no chances with the safety of the unit. I like what I do and always try to remain professional and friendly while performing my job. Sometimes its difficult but everyone knows everyone has a job to do.
I am an old UT hand, with ultrasound we can see the counterbore, any indications in the heat affected zone weld, or root, suckback, as well as dropthough, and slag. We can then map those indictions using trig within a fraction of an inch, to the second decimal place.
To qualify as a UT inspector in the nuclear world,the class has actual samples and you must identify, plot, and size all indications in the samples. The failure rate at the only school of its kind in the US is 80% failure rate, so its an honor and takes a unique breed to interpret indictaions of any kind. We are required to retest every 3 years.
I like what I do and have met some wonderful folks all over the country.
/ Let's see your welds... #22
Ok Shield Arc, here is some Lift start TIG on the Everlast PA160 stick welder.
The first bead on the front is not too good, so I welded the seam on the backside after taking the photo's . Had a little undercut etc. Then I Ran 2 more beads on top of the backside over and under the seam bead. They looked a little better. I should have run some practice beads before I started. The thing I am the most proud of is the 17V torch tungsten is not all gloobed up as it usually is.. I stayed out of the puddle for 4 beads:) No grinding for me WHOO HOO. Now if you will just let me do some grinding and a little fill in I could make that metal look smooth:laughing::laughing: You do know that is why they invented the grinder, for guys like me right?
James K0UA
/ Let's see your welds... #23
Jake what type of Mig welder do you have? Does it have an inductance control? Those welds look like they need to be wet out a little, or at least turn the voltage up some.
I have a Hobart Ironman 230. I don't really understand the voltage concept with mig, I set by the chart and go. When it doesn't seem right I fiddle with it, usually start with the wire speed, then the volts, but I'm basically clueless. From what I understand, w/s gives more amps, that's pretty obvious when I adjust it, voltage, not so obvious..
It does not have an inductance control. (..or I would screw that up too.. :D)
Koua, great pic of 'The Weldor'!
/ Let's see your welds... #24
James K0UA
Nice shop bud! Acoustic ceiling, stove, fridge, and a waiting room lounge for pushy customers! LOL!!! Keep practicing, coming along fine. My phone only showed last couple pics. Been doing that alot lately, dont know why. Some wont even open.
/ Let's see your welds... #25
To qualify as a UT inspector in the nuclear world,the class has actual samples and you must identify, plot, and size all indications in the samples. The failure rate at the only school of its kind in the US is 80% failure rate, so its an honor and takes a unique breed to interpret indictaions of any kind. We are required to retest every 3 years. I like what I do and have met some wonderful folks all over the country.
That is very interesting! We use to have a saying, UT inspection is only as good as the man behind the scope. A good UT man is really helpful for repair work, but only if his trigonometry is up to snuff. That way we don't go digging around all over god's creation.
James those are great! For full pin welds I'll tell you how I do it, not that I'm much of Tig hand!
I like a knife edge / 0 land. I use a 3/32-inch drill bit to set the gap. Use 1/8-inch filler rod. Lay the rod in the gap, and run over it with the torch while holding down pressure on the filler rod. I run about 85 to 90-amps with a really long 3/32-inch sharpened tungsten. For the next pass I won't turn the heat up anymore than 5-amps, and switch to 3/32-inch filler. This really helps with preventing suck back. Nothing more heart breaking than to run a perfect root pass then destroy it by running the hot pass too hot, or not use enough filler, and suck the root bead right back out!
Jake inductance control, controls the liquidity of the puddle. Pretty much the same as voltage. The more voltage you run the wetter the puddle, less voltage the dryer the puddle. With the welds you posted, I would have turned the wire speed / amps down, or most likely I would have turned the voltage up. Reason I say this, the beads have too high of a profile, need to have more flow to them.
I've never run a Mig machine with taps, the more I hear about them, I hope I never have to!
/ Let's see your welds... #26
I dont think to take a lot of photos of stuff I am working on, but I searched my camera chip and found these of a favor I did for my building contractor. He wanted some anti-skid and floation plates welded to his backhoe stabilizer pads. All cast material on the pads and welded with 1/8" 7018. Material welded on was some scrap rusty as he!!! angle and a piece of old disc axle to act as anti skid bar.
/ Let's see your welds... #27
That's a nice anvil you have there Gary! I inherited one that size, but it's well worn, and the tail is busted off where the attachment hole is. I only fired up grand-pappy's coal forge once, made a smoke hood out of an oil tank and hooked it to the wood stove chimney. Filled my whole shop with smoke in minutes... one of my great projects that never went anywhere. :laughing:
Shield Arc, thanks for the pointer, I'll try wetter rather than hotter next time.
/ Let's see your welds... #28
I was rather proud of the find and the cost for that anvil especially since a guy was advertizing them for 400 bucks. Mine is just like new, no breaks, chips etc. and it is hardened steel not cast iron like some of the new ones for sale now
/ Let's see your welds... #30
I have mixed feelings about ZTFab's Mig welds. I can surely appreciate the skill level to produce them. I'd really like to do some DT on them to see how much penetration he actually gets. The welds just look too cold to me. But that might be fine on sheet metal, maybe not so good for structural welding. If I remember correctly he uses a series of cursive "e" technique.
/ Let's see your welds... #31
I checked that link out shieldarc, and all I can say is, its a show, ill go toe to toe with anybody that just wants to make (pretty welds). Some of my strongest welds look like a butcher job, but safetey is more important than someones ego, I am a class 1 liscensed stuctural welder and kinda pride myself on being a safe and reliable person to work with. But like you said, you can play with the thinner stuff and be a pretty boy cause penetration is not an issue, but in the real world of a welder, you have a time frame, and your name on everything you weld. Put these guys in a real life, real work situation and lets see what they got. I was laughing thinkin to myself this morning welding vertical up, while looking down, lefty while im a righty from overhead. Pretty, **** No! But did anybody get hurt, no! while we maxed out a comealong with a six foot pipe on it and stretched out a pad eye till it was ready to come apart. Time and a place for pretty bud, this is what I do when I wanna be pretty. Moms birthday! Gotta take care of mom bud!
/ Let's see your welds... #32
I think a Mig welder in the wrong hands is dangerous, and those 120-volt machines are the worst! People are always trying to figure out how to weld thicker material than they are designed for. Or better yet, never welded a day in their life, run down to Home Depot buy a 120-volt Mig welder, post on a welding forum for advice on how to build a trailer hitch. Then watch the sparks fly!
I've failed two tests in my life:eek:. First test I failed was a 6-G open root pipe, with 6010 and 7018, (my first pipe test). The other was a boiler code Mig test, 1-inch 3-G vertical up with 1/16-inch wire. Beautiful welds, just ran it too cold:eek::eek:, when the coupons were bent, the imperfections were out of code. Luckily I'd been working there for years, so my job was not on the line, I just had to re-test. But we had to re-test every 3-months on all procedures anyway.
/ Let's see your welds... #33
Ditto on what you said about the 120v machines shield. Makes me sick, and with TV, everybodies a welder and fabricator. Outside of my real job makes me not wamna help anyone no more.
/ Let's see your welds... #34
Here's my idea of a Mig weld. .035 wire, 207-amps, 29-volts, on 1/4-inch flatbar. :D
/ Let's see your welds... #35
/ Let's see your welds... #38
What is spray mig?
I kinda understand it, but cant really explain it too well. I think weldingtipsandtricks did a video on it, search for it on youtube, he explains it well.
/ Let's see your welds... #39
Man you guys are rough on ZTFab. Yes the subject always comes down to strength. But you have to consider the simple heading of this thread and ZTFab fit in. You also have to consider what different people do for a living as welders. As a pipe welder it is all based on strength and integrity. But as a fabricator it is also important to have knoledge of many things more that welding.
The thread is "Lets see your welds" thats all.
Chris
/ Let's see your welds... #40
As I understand the MIG process difference between short circuit (globular transfer)and spray is more or less, you just keep cranking the amps till the wire no longer pulses. By pulses, I mean that this is where it contacts the weldment, melts the short wire section between the weldment and contact tip which turns to a molten globule that then transfer into the weld puddle due to polar attraction. In spray arc, the amps are so high that the wire becomes a constant arc and vaporizes into a spray that is transferred to the weld puddle which pretty much eliminates any possibility of cold lap and makes for a very smooth weld with very, very small ripples. Unfortunately, this is too many amps to run root passes with on open butt and without rolling it like a subarc, it is too hot to fill with. This then lead to the pulsed arc that can use higher current but still allow it to cool between pulses similar to the short circuit method (supposedly if you believe the hype from Miller and Lincoln)
(INOP) TIGERCAT 720E FELLER BUNCHER (A64280)
(INOP) TIGERCAT...
APPROX (20) 1" X 8" X 12"' & (30) 1" X 8" X 10' (A64281)
APPROX (20) 1" X...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A64280)
2006 FORD F-450...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
