Recommendation for MAPP gas torch head
/ Recommendation for MAPP gas torch head #1
Blast Chamber
Member
Wisconsin
JD 332
Hi guys,
I've been buying the Berzomatic trigger start torch heads (under $50) for when I use MAPP gas, but I've been through 3 of them now and they keep going bad. Not only do the self ignitors stop working, but the gas regulator goes bad as well and I can't get decent flow no matter what brand of cylinder I try.
I want to get a high quality unit that will last and am not opposed to paying more. I already have a large quantity MAPP cylinders in inventory so whatever I buy has to fit those. Anyone have a suggestion? The only brands I see on google are Bernzomatic (Lenox), Firepower, and TurboTorch. I like Lenox tools in general but they look the same as Bernzomatic (which I won't buy again).
Thanks.
/ Recommendation for MAPP gas torch head #2
Hi guys,
Thanks.
well from what I hear, turbotorch is the industry standard, one of those might be worth a try.
/ Recommendation for MAPP gas torch head #3
I use an old school conventional head and a striker to ignite. Dead simple and cheap.
/ Recommendation for MAPP gas torch head #4
Thats the way to go. you will find they use less gas also.
/ Recommendation for MAPP gas torch head #5
Turbo torch for me also. Had the first one 20 years and replaced it with same.
/ Recommendation for MAPP gas torch head #6
I have used both. The Turbo Torch is the only one that has " blown up" in my hand. I am gun shy of them. I go through several of the Bmatics a year. I just figure the cost of doing business.
/ Recommendation for MAPP gas torch head #7
If you mean for a small, like 14" or so tall tank, I usually go thru 1 small mapp torch a year. I have used many. I now use
a Turbo Torch STK-99 :thumbsup:
I will not be going back to this style;
/ Recommendation for MAPP gas torch head #8
I vote Turbo. Have a problem, They will work it out or replace.
/ Recommendation for MAPP gas torch head #9
I was under the impression that MAPP was out of vogue and not being used much anymore in favor of the small portable oxy/acet torches. You guys plumbers?
Ian
/ Recommendation for MAPP gas torch head #10
Ian
Depends. I use mapp for soft solder and oxy - acet for sil-phos work.
(not a plumber, but an HVAC guy).
Thanks everyone for the feedback. I'll try a TurboTorch and see how it performs.
I'm not a plumber, I mainly use the MAPP gas for heating up stubbornly seized fasteners. A few years back I scored a dozen bottles of MAPP gas at a garage sale for $1-each, which is like a 10-year gas supply for me. :)
/ Recommendation for MAPP gas torch head #12
I was trying to braze something a few years ago and tried one of those Bernzomatic Mapp/Oxy torches. I wasn't too impressed, but it was probably me and not the torch.
Ian
/ Recommendation for MAPP gas torch head #13
Ian
No its the torch. I tried one, it sucked, The o2 lasted about 5 mins, seemed to have less btu output then a normal propane torch. (hotter though) Sucked so bad we got a proper O/A torch, now that puts out the heat.
/ Recommendation for MAPP gas torch head #14
Yes I am a plumbing contractor and nope, a MAPP tank would be ill advised to try to braze IMO. It's prob possible on a small fitting, in the summers heat, with no wind. I carry an acetylene tank w/ a large tip for silver soldering.
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
Deere 482C (A64911)
Deere 482C (A64911)
Metal Peacock Lawn Art Statue (A66738)
Metal Peacock Lawn...
WHEEL LOADER FORK ATTACHMENT (A67714)
WHEEL LOADER FORK...
2020 Ford F-53 Thor A.C.E 32.3 33.5ft Class A Mobile Home (A66738)
2020 Ford F-53...
