Ferguson TO30 Steering BOx
/ Ferguson TO30 Steering BOx #1
Bob Senti
Ferguson TO30
How full and what kind of lube do I need to throw into a Ferguson TO-30 steering box?
I heard somebody pumped it full of grease. Any reason why not?
BOb
/ Ferguson TO30 Steering BOx #2
G'day Bob there is no reason that you can't fill your box with grease it just stops the oil from leaking out:thumbsup:. If you were to fill with grease i would prob thin it down a little with some gear oil so it can run into the bearing surfaces a bit easier.
Jon
/ Ferguson TO30 Steering BOx #3
BOb
The spec calls fro GL-1 oil( same as the transhydraulic oil use in the tranny/rearaxle/hydraulics on the tractor. The fill is 2 quarts and the level, per the TO-30 Owners Manual is "...at the center of the steering arms." I think tht means at the center line of the transverse part of the steering shafts that come out of the sector gears.
Some people fill it with corn head grease when the seals are shot and it won't hold fluid. That's a temporary fix until you can fix it correctly. It's really not designed for a grease pack.
/ Ferguson TO30 Steering BOx #4
may not be designed for it.. but even ford recognised that some lube on a bearing was better than no lube.,
I have a ford service bulletin dated oct 62 advising ford dealer service departments to retro fit steering boxes with 0ep grease to combat leaky sector seals / dry bearings.
nowadays I think I would use a 00ep grease for improved flowing.
that's what I put in all my steering boxes.. 00ep stens grease.
soundguy
