New Plow
/ New Plow #1
RockyNY
Gold Member
Western NY
Kioti NX6010CH
I snagged this plow today. Meyer 90" with power angle. Needs a paint job, but it's structurally sound, not rusted out and has a good cutting edge. Paid 2 & quarter for it, I think it was a decent deal. I'm planning a FEL mount, so now I need to order a QA plate and get to work.
attachment.php
attachment.php
/ New Plow #2
"Paid 2 & quarter"
You sure did good...heck you made enough so your QA plate almost free.
Share some pics of your project.
/ New Plow #4
Nice find.....especially if those cylinders are working (?). WTG :thumbsup:
There are quite a few threads on building a plow mount. Search: FEL Snow Plow for lots of ideas and solutions. Here's my 80" Meyer fitted to my loader.
/ New Plow
Yes, I have your build thread bookmarked as well as a few others.:)
/ New Plow #6
Funny thing about my build......it's un-tested. We have had "0" plowable snow days since I finished my build. I have not yet tried the plow, except on a little light dirt. :laughing:
Oh well......I'm ready if it ever does snow. :thumbsup::thumbsup:
/ New Plow #7
That explains it!!!!!!!!!!!!!!
Its all Foggy's fault as to why we have no snow to play in....uh, clean up I mean!:laughing:
/ New Plow #8
Nice find! I've been looking for one for about 4 months now without much luck. Seems the prices are still up there, but I expect to see them drop within the next couple of months.
If you don't mind, would you measure the height of that blade for me? :drink:
Thanks!
/ New Plow #9
Great find.
I bought a used 7.5 with Q/A plate on Craigslist last year for cheap money.
This year I managed to break one of the pivot pins. That repair cost me $300. I'm still way ahead though.
Check the pivot pins located at the bottom of the plow. Make sure they are well greased and still move freely. If not, replace them. Not too hard of a job if they haven't rusted solid in place.
Good luck.
/ New Plow #10
Great find.
Good luck.
These pins are one thing I did not replace. I figured I would attack these at another time....but.....How are you supposed to get them out?? :confused::confused::confused2:
/ New Plow #11
My pivot pins were pretty much rusted solid. Plow wouldn't move so I put some heat to it then penetrating oil thenpushed/pulled it against a tree and finally broke it loose. I plan on replacing them at the end of the season if I can get them out.
Jeff
/ New Plow #12
Replace them now, before it gets expensive.
When I broke mine, I tried a propane torch. NO way that was going to work.
I took the plow to a welder and they used am Oxy/Propane torch to cut everything out. Lots and lots of heat and a BFH finally got everything removed. Both pins were almost welded in because of the rust.
After welding replacement tubes on both the plow and frame, put the new pins (w/grease fittings) in. Pumped lots of grease into the new pins to hopefully prevent rust.
