Bending Thick Metal
/ Bending Thick Metal #41
Maybe everyone one has one close by, but one trip to their shop or worse still, one house visit and you could have paid for a used Lincoln buzzbox. That is not to mention that you wouldnt have to wait for them to get to your place OR take it to them (30min. travel, gas and wear and tear on your automobile + what ever the charge was @ likely $100 per hour + your wait for them to get to it or worse, have to come back later if they were busy) I much prefer to be prepared to do it myself on anything that I can do at home, this even includes haircuts.
/ Bending Thick Metal #42
I generally agree that it is worth having a welder at home to fix stuff but for a novice welder to attempt a repair on a critical high strength part the best solution may be to call in the pros. In my area they charge about $70/hr with two hour minimum to show up in your driveway. Not too many welding/cutting jobs will last more than 2 hours so it is not a bad deal if you don't have either the equipment, skill, confidence or time/desire to do it yourself. With the construction industry in the doldrums it probably isn't hard to get a decent welder to come at a time convenient to you either.
/ Bending Thick Metal #43
I agree with critical stuff, you need to have good welding skills to fix them, however, most farm breaks are like that Bush Hog tail wheel, it isnt that critical, if it breaks just remove the old welds and weld it again. That is about the only way to get proficient is to keep trying. Welding on his chain hooks, he should get that done later after his skills improve as a break on that has the potential to cause a serious accident or even death. That being said, it wont take very much good weld to hold all that the average tractor will lift on a straight pull. I had a fitter once try to break one of my 1/4" tacks on a piece of angle right in the corner pulling straight down with a 5 ton come-a-long and he couldnt pull it off, but I could push it sideways with one finger and break it off once he removed his comealong. When you have 60-70K psi weld strength it doesnt take much weld metal to hold a couple thousand pounds. I just feel safer with a good weld rather than a poor one especially when I may be getting under or around something that is hanging off my FEL chain hooks.
/ Bending Thick Metal #45
Danno1 said:
According to the "real" blacksmiths, that's an ASO (pronounced asso). Anvil Shaped Object. :laughing:
Anvil shaped object is the truth!!!! If people knew how to truly use an anvil and what there real worth is they would not be cutting them up to fit in a corner of their garage or be giving them away because theyre tired of walking around it.
/ Bending Thick Metal #46
I have to agree with the good anvil. I used to have a 10 lb cast iron anvil that was useless. I have since made quite a nice 50lb anvil out of some rr track. For a home made anvil, it is good, and works well. But it is still not nearly as good as the old 400lb anvil in perfect condition in the blacksmith shop I often work in. If your going to be using a sledge hammer, you need a big, real anvil.
/ Bending Thick Metal #47
Yeah, and I'm sure "real" farmers think any tractor under about 80hp is just a toy too.
No pro blacksmith is going to HF for an anvil. And no pro welder or mechanic would use anything from HF either. On the other side of the equation, if a $44 ASO can help shape some sheet metal using a $12 set of HF ball peen hammers then why spend $1500 for the "real" thing?
/ Bending Thick Metal #48
Because a cast iron anvil can snap with very light work. Sheet metal is about all you can do with it. If you try real forging, you will have a pile of iron chunks. (more likely pot metal)
/ Bending Thick Metal #49
Years ago I was on a large concrete bridge project. They were using traveler forms like in this picture. Before the next section is poured the opposite side has to be loaded with counterweight blocks. Another contractor was loading the cantilevered section with counterweight blocks getting ready for the next concrete pour. They had a weldor that I had worked around before welding padeyes on these concrete counterweight blocks. The rigging crew was always waiting on this guy. I wasn't paying a whole lot of attention to what was going on, until I heard this very loud thud! One of the padeyes broke off the counterweight block while it was in the air being flown into place!:eek: Can you spell unemployment?:laughing:
/ Bending Thick Metal #50
Heres an anvil I made for my friends 15yr old son whos just getting his feet wet with the trade. He was estatic when I gave it to him. Cost
me $0, and an hours elbow grease. So for minimal money, even if you spent a couple bucks for the rail, you can avoid a sliver of cast iron stuck in yourself and possibility of someone else getting hurt watching you when that $44 harbor freighter starts coming apart
/ Bending Thick Metal #51
Your warning is appreciated. I always wear safety glasses but do understand your point.
I'd love a railroad track anvil but after looking for a month or so didn't find any before cruising HF one day.
Your friend's anvil is great!
/ Bending Thick Metal #52
Buddies have told me that rail anvils are nice cheap, but not advisable. As the rail road cars roll over the rails, the steel rails become work-hardened. That seems good until you realize that also makes the steel brittle and liable to chip with hammer blows and fly off bits of it- face etc.,
Usually a want ad booklet is a place to buy an old anvil- used to be a dollar a pound, more now. There is nothing wrong with an old anvil I have a 189 ib anvil from about 1840 and a Peter Wright 98lb anvil from 1880 or so. Both are excellent. The top face can always be refinished - milled slowly or ground very carefully and kept cool so as not to lose the temper.
Mechanic's garages often have anvils they beat on. Old barns, auctions, and Ebay are also places to look. I would never use a sledge hammer on an anvil. Maybe a 6 lb hammer with a drop stroke- but never the over the shoulder stoke like you use driving fence posts or splitting wood. -Substitute a rock in the ground or a hard old stump.
If you have a good heat on the piece, you don't need to kill it to bend it. I have straightened the lift arm on my TC 30 with a sledge cold- - hitting it against the ground on a 2x6 with an over the shoulder blow- 5-6xs.
Check out Centaur Forge online- (see what it is, then find it used!).
Centaur Forge, your full service farrier & blacksmith supply company
It is not that hard to make a forge & blower. Plans are everywhere.
Don't buy new unless you like the convenience. Great way to visit tool barns!
You'll come to appreciate the "drop forged" parts on old machinery as you come to understand blacksmithing- (iron work) (farrier does horse).
HF carries junk for anvils.
/ Bending Thick Metal #53
I have done a bit of sledging on an anvil. You hold the hammer in kind of an odd way, and only swing it a foot or 2. I was using an 8lb sldge, but that was with a 400# anvil. Those jackhammer chisles are tough. Tomorrow I will put up a pic of what that jackhammer chisle is now.
/ Bending Thick Metal #54
Not true bud, worked on railroad for 15yrs as a welder. Do you ever see chipped up rails, specially around loose joint bars? Almost never, and thats alot of weight poundin on em. But better safe than sorry, use a new piece. Plus your usually striking a heated piece of steel, not the anvil itself
/ Bending Thick Metal #55
I liberated an anvil from an old barn that was condemned and in the process of being demolished. Carried that thing, which weighed more than I did, about 300 ft to my truck, close to 200 pounds. Not in perfect condition by any means but still useful.
I got a 20+ foot length of RR track I could make a bunch of those redneck anvils :laughing:
Picture may be deceiving, that is a monster vise and the table is 1/2" plate
JB
/ Bending Thick Metal #56
JB
Anvil weight is calculated by:
Rules:
First number is # of hundredweight (112 lb. ---- 1,2,3,etc
..........(Any position can be zero, and IF zero is marked with a zero character (0).)
The middle position equals quarters (1/4) of a hundred weight. The value cannot be more than 3. If it looks like a five then it is a two or a three.
The last (right hand) position is pounds and must be equal to 27 or less.
From your photo it looks like 112 + 28 + 21 = 161 lb.s
The shape looks like a Peter Wright (English made) anvil. I can't read it from the photo. Usually the name is on the side of the anvil. - just looked again- Peter Wright , Solid Wrought (hand made process by which horn and top plate are attached to the body. The top plate is a harder quality steel, while the body is a low carbon wrought iron. Great quality anvil, well respected. Can be cleaned up, but be careful of overheating the top plate- cool it as you grind- water etc. Don't ever hit the top plate dead on with a hammer- dents the plate- not so good for working steel then. You could easily resell this!
http://www.ebay.com/sch/i.html?_fro...=Peter+wright+anvil&_sacat=See-All-Categories
I am fond of anvils- great tool!
It looks like a nice anvil.
/ Bending Thick Metal #57
Rules:
That's a complicated formula, but sounds right, I think I weighs ~160 lbs
It does say wrights patent, so was it imported?
The top is heavily used, even the round part of the horn it heavily worn on one side. Maybe from making horse shoes??
JB
/ Bending Thick Metal #58
I can't speak to the HF ASO's as I don't own one, but I can describe the HF Vise I have. It is Red in color and gains its smoothness from liberal application of bondo applied over all of the irregularitys of the surface and then a lot of probably lead based paint slathered on it. It does work OK as a vise to hold small objects to weld them. However the back area of the vise has a 4" x 4" area to use as an anvil. Now I am not sure if that area is Jiff, Peter Pan, or Skippy, but it for sure is made of peanut butter. I have never seen "steel" so easily dented by a light peck from an 8 oz. ball peen hammer. When you try to weld the dents over, it acts very weirdly. The surface sort of melts, but holes develop around the puddle. It does not seem brittle, just soft and spongy like maybe old beer cans? or Pot metal? Anyway it is hopeless, I was thinking about covering it with a 1/2 inch piece of hot rolled. It would be much harder and more reliable to beat on.
James K0UA
/ Bending Thick Metal #59
JB
-Could be from making shoes. I'd say the guy was right handed and hung the bars/stock over the rounded edge of the anvil - (work rounded), The hammer is in his right hand and the tongs in the left hand. I figure he also beveled the rounded side of the anvil a bit so as to avoid a sharp crease when bending stock over the edge or curving the steel (sets up weak spots). Somebody put some hammer dings in the face. When you hammer hot steel on the face (top) of the anvil - it is soft. One side of the steel takes the hammer blow, the other side takes the dings from the anvil face! (you work around them!)
It looks like a Peter Wright anvil imported from England.
Peter Wright anvil - Practical Machinist - Largest Manufacturing Technology Forum on the Web
+ do a google search: "Peter Wright Anvils"
I hate to think of these anvils hitting the scrap yards!
/ Bending Thick Metal #60
James K0UA
Is that soft stuff babbit?
2014 Evinrude 2-G 225 HP Outboard Boat Motor (A66738)
2014 Evinrude 2-G...
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A68842)
PALLET OF 51 X 41...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2013 STEPHENS CRUDE PUP TRAILER (A67714)
2013 STEPHENS...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
