Right fit for Disk Harrow?
/ Right fit for Disk Harrow? #1
AirForceIP
Brackettville, Tx
97 JD 770 FWD/Mahindra 5530 FWD
Plan on getting a disk harrow (along with some other stuff) on monday. Trying to decide if the 8 foot harrow would be too big. I have a 5530 FWD. Armstrong Ag recommends a minimum of 60 hp for the 8 footer, but I could easily work the 7. I'd probably rather have the bigger harrow, if just for the weight. Think the tractor would pull it ok?
http://www.armstrongag.com/Prodimages/HD.pdf?#view=Fit
/ Right fit for Disk Harrow? #2
I pull an old 6.5-ft Towner offset disc with my 2008 Mahindra 5525 (54 hp engine, 2WD, gear tranny 8F/2R, don't know what the drawbar hp is). I can get it up to 5-6 mph in my gravely loam soil when it's dry or damp. If it's really wet, that heavy disc will bog the 5525 down.
/ Right fit for Disk Harrow? #3
I don't know what the h*** you guys disc that is so hard to pull. When I was growing up on the farm we plowed the ground (Not the best ground, heavy clay soil) and then used the disc to break up the soil. We pulled a 8' disc with and Allis Chalmers WD 37 HP 2wd 4000 lbs. and pulled a 10' disc with a Massey 165 52 HP 2wd 5000 lbs.
/ Right fit for Disk Harrow? #4
That would mean I'm 20hp under rated with a 2wd tractor and no extra weight or water in the tires... Haha! But then again I've always said my little NH "is six pounds of potatoes in a three pound bag"
70's (ish) 8' IH Model 37 disc.
/ Right fit for Disk Harrow? #5
Airforce,
I have a 5530 4wd and easily pull a 8' disc through plowed ground, wish I had gone with a 10' set.
/ Right fit for Disk Harrow? #6
Sure, if I plowed the ground first, I'm sure my 5525 would pull my 8-ft wheel disc with no problem through my hayfield. But I don't plow because my good topsoil is thin and shallow. I use that Towner offset for primary tillage so I don't flip the poor soil on top of the good stuff.
/ Right fit for Disk Harrow? #7
Galen, I think the same thing, just the opposite. How in the world do you guys pull such big disks? :confused3: With our ground and terrain, I have had the tracks on our D6 slipping when pulling out 12' offset disk and I have almost run out of power pulling my 8' offset disk with the 7520. All our disks are old JD-Kielfer pull disks with 22" blades. Normal pull would be 8"-9" deep in damp soil. ;)
/ Right fit for Disk Harrow? #8
The discs I remember on the farm only had 16 to 18 " discs, and once in a while we would disc the corn stubble in with out plowing, and if you set the disc to a good angle you could only get a couple of inches of penetration the first time over. I stopped and watched a local farmer discing a couple of years ago and he was only getting 3 to 4 inches of penetration. The disc he was using was probably 20 to 25' wide you don't see much of anything smaller being used for farming in our area anymore. Actually I don't see discs being used much, in our area, anymore.
Brian,
Your pictures almost look like you are plowing.
/ Right fit for Disk Harrow? #9
Brian,
Out here in the West, they are still disking and the "REAL" farmers are using anything from 24"-42" disk pans from 14'-20'+ wide. So anywhere from 10"-18" deep. Of course it all depends on what they are growing. Just goes to show how different things are in different parts of the country. ;)
Honda Foreman Four Wheeler (A62177)
Honda Foreman Four...
2024 Husqvarna Xcite Z345 (A62177)
2024 Husqvarna...
UNUSED KUBOTA K7785-18" EXCAVATOR BKT (A62130)
UNUSED KUBOTA...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2019 F150 (A61306)
2019 F150 (A61306)
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
