L5740 smoke at start up
/ L5740 smoke at start up #1
kuboman
Canada
B3200, L5740,
Just a question for all L5740 owners. As I have only had mine a week and there are no more on any dealer lots I would like to know if they all act the same at start up when cold. Mine starts great with a puff of black smoke but then goes into a 5 second spell of expelling blue white smoke. Cleans up and runs clean an smooth after that. When it is warm it starts with just the usual black puff.
How about others, are they the same.:confused:
/ L5740 smoke at start up #2
Sounds normal for a diesel
Well not quite. The white smoke is not normal for a 70* day but it may be normal for this particular model.
/ L5740 smoke at start up #4
A small short black puff is normal with the L40 series but like kuboman said on
the white smoke. It is not present when we start our L3940 at warm temps.
/ L5740 smoke at start up #5
Sounds like my L5040. I find if I let the pre heat warm it up a few seconds there is much reduced smoke. In the summer the tendency is to turn the key like you would on your car but a short pause to let the pre heat work will help on the smoke. You might check the engine oil level. Mine came from the dealer just a tad too full and after my change at 40 hours I noticed reduced smoke also. I've got 65 hours on it now and there is much less smoke than when it was new.:confused: One cool morning I was quite alarmed by the smoke when it had about 5 hours on it but now its a non-issue.
My sounds like yours (was). Mine has 25hrs. I have thought that the preheat is maybe a little short. I always let it heat till the light goes out and then start and it makes very little difference to the smoke as the preheat is so short. I will have to wait for a cold morning to see if it will heat longer. On a 60-70* day it will only preheat for 3-4 seconds.:)
/ L5740 smoke at start up #7
The blue (unburned diesel) smoke is a characteristic of a pre-chamber, indirect injection engine and denotes nothing in the way of a problem.
if there ain't no smoke, there ain't no fire.:D
/ L5740 smoke at start up #8
I have a new L5740 that I just traded in (12/11) a L4740 for this new L5740 and the L4740 never smoked hardly at all, just your normal cold start smoke, but this new L5740 smokes really bad and also skips abit when the temp is cold, I have a block heater that was installed as an option and if I plug it in for awhile it does not hardly smoke at all. I called the dealer about the smoke and they are now telling me that they are all doing it. I don't know why they smoke so bad, but it does not seem right to me. And I also had a L3740 that did not smoke like this either.
/ L5740 smoke at start up #9
There is a video on youtube with the same tractor doing the exact things that yours and mine are doing. I had this same question. starts and runs real crappy coughing and puking smoke for about 3 seconds. Then starts to clear up and run good.
From what I have read this is normal. They have advanced the timing for emissions purposes and this is why it starts like this. I have started at -10 before and it really smokes. In the shop it is 50 and it smokes like all heck.
THis isnt normal of newer diesels. maybe the old powerstrokes or cummins
12 valves, but not the newer motors. My 07 truck never starts like this. My 06 L3130 never started like this. From what I have read and seen on here, this is normal for the turbo'd tractors in the L series. I heard also that the non turbo'd dont do this.
Also, when starting you are supposed to turn the rpm's up to 1500 right away. Seems wierd, but something with the oil pump when cold. Heck when its real cold outside, I cant get it to go to 1500 rpms for at least 10 seconds. It wont clean up even if I go to half throttle.
/ L5740 smoke at start up #10
That is completely normal - the black puff is first couple of inefficient cylinder firings, but the white stuff is the unburnt diesel that collected in the exhaust during the first couple of cranks before it catches.
You'll also probably get a black poof when you rev it up under load.
JayC
/ L5740 smoke at start up #11
I have 62 hrs on my 5740 and i took it it in at 35hrs or so because of the smoking and rough running when cold starting because i had a 4740 and it did none of this and they told me it is normal because of the EGR with the turbo.
Plug it in works the best.
/ L5740 smoke at start up #12
Mine does the same, but starts a lot smoother with less smoke if I plug it in. I don't understand how this is better for emissions. I can fog out my 36' x 44' pole barn if I don't plug it in first. I've never seen a newer diesel car or truck do this?
Subsequent research has told me that because of the emission crap (egr) etc the timing on these engines is retarded to the point to where they start like crap. As soon as warranty is off I plan to remove the EGR and advance the timing back to18* .:thumbsup:
/ L5740 smoke at start up #14
If one removes/plugs the line to the egr, does that take the place of physically removing it?
Also, what exactly is involved to "advance the timing back to18". (Being a Mr. Badwrench as it were.)
Yes although you still have the apparatus with antifreeze circulating through it.
You need to take off the injection module and remove a shim.
/ L5740 smoke at start up #16
Well I owned a GL4240 and now a GL5740 and I can tell you they are totally different when it comes to starting. The 4240 was smooth on cold starts but the 5740 smokes black when cold and idles rough for a few seconds. I've never noticed white smoke. Mine has 54 hours on it. Glad I put the exhaust stack on it :thumbsup:
/ L5740 smoke at start up #17
What the heck is the 'injection module'? You mean the pump???
I can't warm to these new mortors that don't smoke. I from the old school that.... If there is no smoke, there is no fire and no fire, no power................
My M9 smokes when it starts, when cold rattles a bit and smokes (I don't preheat it, ever...) and when I throttle it, blows a nice telltale stream of soot.... It better.... I like contributing to global waeming.....
So does my 105......
Yep the pump, that thingy with the injector lines attached. It comes out as a module.
I too am old school and think a diesel should smoke. Although I am amazed at how much these 'low emission' engines smoke.:thumbsup:
/ L5740 smoke at start up #19
Mine smokes at start up... I have just over 300 hours. I start it... let it rumble, for a couple minutes and go...
Don't worry about it.. Just let it warm up for a little bit before you work it hard.
/ L5740 smoke at start up #20
Started my L5740 yesterday @ 15 degrees cycled the plugs twice and it started with a mighty cough, blew black,greyish smoke then cleaned up and ran find. Hope it starts in 10 years the same way...
MAHINDRA 2538 TRACTOR (A65057)
MAHINDRA 2538...
2016 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2016 GENERAC...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
2025 Sickle Bar Mower Mini Excavator Attachment (A66734)
2025 Sickle Bar...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65056)
2019 CATERPILLAR...
