300 CX hose supports
/ 300 CX hose supports #1
KennedyDiesel
Central WI
I have one of the first 3720's built. I added the remote function lines on the loader for running grapple ordered in new. My hydraulic hoses have always rubbed the crap out of my hood and the front tires bounce them all over when steering. Seeing pics in another thread showing a hoop to guide the hoses away from the tire got me started researching what I could do to help this. My dealer sent me a parts drawing showing a hoop that pinned into the stationary loader frame to guide the hoses. My tractor has the hole to which this mounts, but no hoop. Essentially the only thing supporting the hoses is the steel lines which are clipped into holders on the loader boom.
Yesterday I stopped and looked at a used 3720 to check out the hose retainers in person. It looks ike I may be missing yet another stay clip. The boom pivot (upper rear of frame)appears to have a small bracket on it and a nylon cable tie retaining the hoses to this bracket.
So now I have to wonder if:
A) My tractor was so early that these parts were not used
B) They got left off at the factoiry
C) They don't fit with the remote line kit added
D) They were removed and left off when the dealer added the lines
/ 300 CX hose supports #2
Or
E) just order the parts
F) fabricate something that is even better than what Deere has.
I need to do something for my snowplow hyd. lines too. Do you have a pic ot rhe 3720 you checked out?
/ 300 CX hose supports #3
I actually had noticed that some 3000 series loaders did not have the support you speak of. I didn't and mentioned it to my dealer, he ran in the back and grabbed one and told me they must've forgot. I installed it and it's made a world of difference. At the time I was buying a 448 hoe for around 8k so that's probably why he was so generous.
Matt
/ 300 CX hose supports #4
Yeah, these are absent on my 300CX as well. Not sure if this was an early model loader or not but I am guessing that's the case. I've been meaning to pick up the additional parts as well.
/ 300 CX hose supports #5
Does mine have everything it should?
This is on a 4310
JB
/ 300 CX hose supports #6
It looks like you have the bracket/tiewrap mentioned in the second paragraph of the first post.
Can't tell if you have the metal loop or not.
/ 300 CX hose supports #7
Yeah, looks like you have everything. Hard to tell about the loop, but if you have the tie wrap you probably have the loop as well.
/ 300 CX hose supports #8
Where is the loop?
I've never had an issue with the lines that's for sure.
This is one of the early 300 cx's, my tractor came with the 430 loader, the new model tractor and loader just came out after I bought mine. I have no problem with the 4310 model but I wanted the better specs of the 300cx so I upgraded to the new loader. Actually cost me very little cause the dealer said they had plenty of people that needed/wanted the 430 loader, and gave me a very generous trade in value. They even delivered it from out of state and installed it in my yard.
JB
/ 300 CX hose supports #9
Actually, the wire bracket he might be talking about that I am thinking of attaches to the tractor frame IIRC. I think it might be on my 4300 actually, but do not believe it ever came on the newer 3x20 series tractors because of the hose "holders" built into the 300 series loaders. There is a wire loop thing on the 200 series loaders... (look right by the "ST" in HST below)
Here is a good photo of the 2 300 series loader "holders" along with pictorial index and part numbers. I don't have either of these on my loader :(
(and because I do not have these, you can see where the boom pin has started to rub into the hydraulic hose, and I also had the scratching that KennedyDiesel mentioned)
26 J16931 PIN 0.37$
27 W34703 PIN FASTENER 2.84$
28 W33923 SUPPORT 3.42$
29 N189220 TIE BAND 1.79$
MOUNTING FRAMES, MASTS AND BOOM > MASTS
18 N189220 TIE BAND 1.79$
20 W50298 HOSE SUPPORT 28.09$ (This price is just outrageous! I will be attempting to make my own for sure.)
21 24M3527 WASHER (17 X 24 X 2 MM) 0.37$
HYDRAULICS > HYDRAULIC HOSES AND OIL TUBES
/ 300 CX hose supports #10
I believe the wire bracket would bolt to the tractor frame, and would go near where the tie wraps are on this tractor. However, I can't seem to find any pics of 4x00's or 4x10's with the bracket so dunno.
/ 300 CX hose supports #11
The hose routing on the 3320 has bugged me for 3 years. Why did engineering come up with 59 inch long hoses to travel 30 inches. Add some inches to make a loop at the mast and loader boom 'joint', maybe 10-15 inches and run the lines vertically up the left side of the mast...No interference with body work, solonoid on the injection pump, blocking dipstick and oil filter access, extra heat from the engine, and lines dragging on the right front tire.
Anyway, here's my latest attempt at controlling hose movement. If this doesn't work out my last option will be to make shorter hoses and go vertical.
Here's some points you will see in the pix.
1. Shimmed out the midmount pin by 3/8s thus pulling the hose bundle as tight as possible to the support bracket.
2. Added a tie wrap to the bundle to move it away from the injection pump solenoid.
Other guys have given the part numbers, I just supplied some pix.
/ 300 CX hose supports #12
My 3520 didn't have the hose support on the loader mast itself. I just made one myself by copying one on the dealers lot. It's just 3/16" x 2" with a 3/4" hole drilled through the short leg of the 90* bend. So it pivots with the loader arms just use a couple of washers that fit the hole, the flanged nut will hold it on and still keep everything tight. It really took the strain off of the hoses in that area. I think the original went into the dealers "extra parts" bin.:D The reason the hoses are so long is so you can hook the hoses up and have a little wiggle room when the loader is parked and you are rehooking.
/ 300 CX hose supports #13
Mopar, thanks for reminding me about the disconnecting of the loader from the tractor. I never intended to take the loader off, so that's my excuse for not seeing the need.
/ 300 CX hose supports #14
Another plus for TBN. I noticed the second picture from the OP and after reading your comment, I had the same thing missing on my 2 year old loader. I called the dealer I bought it from within a couple minutes and he ordered one out. Now I am a happy camper, at least with my hoses.
Mine is missing the bracket and tie band at the upper pivot as pictured by others here. It's also missing 26-29 the u bolt clamp in the picture. There is essentially NOTHING to control the hoses other than the clips that the steel lines lock into and the mesh bag.
This is really starting to tick me off that stuff like this would be missing from a machine purchased new.
/ 300 CX hose supports #16
These things come knocked down on a pallet, so someone at the dealers has to assembly them I believe. must be a case where there's a few parts left over after the majority is assembled. and they just leave them off?
JB
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2020 MACK P164T DAYCAB (A63569)
2020 MACK P164T...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
11R22.5 ALUMINUM WHEELS AND TIRES (A63569)
11R22.5 ALUMINUM...
IRMC High-End Massage Chair (A64047)
IRMC High-End...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
