Kubota L2900 hyd question
/ Kubota L2900 hyd question #1
fireemann
southeastern Ohio
I am wanting to tie into the hydraulics on my loader and install a 3rd function. I have found 12volt solenoid valves on surplus center.
Will these work?
if i remember right my system is like 8 gpm and 2200 psi. I know it has power beyond.
If the open center one wont work where can i find one that does. I thought about the selector valve and not sure thats the way I want to go.
Cool..Thanks. I have been looking and trying to find one and havent been able to find a solenoid valve that listed power beyond. This was the closest I could come up with.
/ Kubota L2900 hyd question #6
Solenoids valve sub plates don't use the term PB, because the IN and OUT ports can handle the high pressure, some up to 5000 psi.
that explains it.. its all starting to make some sence. Thanks for the expertise and insight.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Ford F-250 Pickup Truck, VIN # 1FT7W2B63HED67208 (A61165)
2017 Ford F-250...
2006 Freightliner M2 106 Terex Hi-Ranger HR46M 46ft. Insulated Bucket Truck (A60352)
2006 Freightliner...
2019 Freightliner M2 106 26ft. Box Truck (A61568)
2019 Freightliner...
2013 Ram 1500 Crew Cab Pickup Truck (A61568)
2013 Ram 1500 Crew...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
