Firewood prosessor
/ Firewood prosessor #1
Tor Arne
Gold Member
Norway
Same Explorer 65, MF 135, MF 30, MF165, Volvo BM 55, Volvo BM 425, Volvo BM 2254, Terengmester skidder, Ford 3000, Fordson major, Derreng unknown model, IH B275, MAN 4R2, Gutbord sub compact.
Hello everyone. I'm pretty new to the forum, will apologize if anything I say makes no sense since I was not born English speaking. well I have quite a long time played with the idea of building a firewood processor.
Really liked the splitting wedge to this machine. But would rather go for a chainsaw bar and chain instead of blades, what do you think?:) Sending a picture of the parts I have gathered. Since I do not have a work place other than mother nature, Eeverything depends on Temperature if I get something done soon. I am planning what I need, ordering parts and scratching my head for now.
<iframe width="420" height="315" src="http://www.youtube.com/embed/M0FVh99ytIg" frameborder="0" allowfullscreen></iframe>
/ Firewood prosessor #2
welcome to tbn. you english was fine. looks like you have a start on some parts, hydrolic valves and motors, saw bar/chain. sounds like a very interesting project. i wouldn't mind having a firewood processor myself as i have a small firewood business over in the united states. compared to a firewood processor i do everything the hard way. good luck with your build and keep us updated and pictures are nice.
/ Firewood prosessor #3
Did you check the commericial manufactures sites? I see you have chosen a Husky chain bar. Is it the strongest grade that can be bought as the bar is going to be running for many hours. There is a grade of chain called ( Harvester ) that is used in forestery machines.
I bought a new Husky chain saw 2 years ago, maybe a 440?? model on a 16" bar and it is very nice.
What nick names do you call Husky saws in your country?
Your English is fine.
Craig Clayton
Craig Clayton
Hey thanks for the reply. Yes I have seen various commercial firewood processors and either; I do not like them, do not fit my use, not sold in my country or they are too expensive. I want a machine with cab, heater and its own diselmotor so I do not tie up a tractor. Thinking of something like Rapido Loco with the splitting wedge from the video link in first post.
Bar is 24 "bar and chain is the toughest quality I could find. Here in Norway the saws ar just called husqarna, and those who truly love them mostly call them with the woman name Erna. Had planned to make a clutch system, so chain only runs when necessary
/ Firewood prosessor #7
Welcome.
Perhaps you should try doing a search here on this forum. There are a number of threads on this.
Good luck!
/ Firewood prosessor #8
You mentioned clutch for the chainsaw, and if you are talking about a hyd chainsaw, then a solenoid valve motor spool will only run the chain saw when a switch is activated.
Surplus Center - 12 VDC 10 GPM OC MOTOR SPOOL SOLENOID VALVE
Hey thanks for the input:)
Thought I'd use a mechanical clutch and belt drive since hudraulik high RPM motors are expensive and I have a clutch from a suzuki samurai, was thinking of turning a thick-walled tube, which I mounted flywheel, bearings and pulley. Then a shaft with bearings, clutch disc and pulley to the saw. Or does anyone have any other ideas? All suggestions are appreciated:)
build some type of chain oiler as well,
Yes I have a small 12v fuel pump and a needle valve which is scheduled for the purpose
/ Firewood prosessor #12
[I watched the machine in operation and I observed the gentlemans many hand and foot movements. I myself would become mentally tired after running this machine after a few hours.
I would suggest a slight lose on production of wood but build in some automation on the advance, cross cut cycle.
There is a small electrical controller out for under $200 Canadian from siemens or Kloncker. These are known as micro PLC and are being used in many newer large machines to control them.
They are easy to program. It could control the solenoid valve for the crosscut saw count to 3secs to allow the wood to drop before the ram advances. If the wood jammed you could hit a stop button and the saws would retract to the HOME postion. That means start over when commanded.
[ame="http://http://www.youtube.com/watch?v=8T5PlDdItmo"]http://http://www.youtube.com/watch?v=8T5PlDdItmo[/ame]
I found this vid for an elevator which is very similiar to your cutting cycle.
I spent 2 years at night school writing programs for machines like the demo.
Craig Clayton
Craig Clayton
Hey, thanks for the idea I'm considering doing this, but will first build the machine and see how it is to operate with joystiks to make it as most fool-proof as possible. when I have tried and seen that everything works well mechanically I will consider it. I also learned how to program the these when I went to school, here they call the class electro-mechanical engineering. basicaly I lerned everything from welding, fabrication, hydraulics, penumatikk, electro both digital and analog to regular maintenance
/ Firewood prosessor #14
I've always been impressed by this operation:
[ame=http://www.youtube.com/watch?v=te3FBhdqgK8]Bobcat Log Splitter - YouTube[/ame]
/ Firewood prosessor #15
Craig Clayton
When you buy PLC make sure it comes with the programing software and has the input and outputs you need (in example relays). The software cost often several time more than the PLC. I used LG but there are many PLCs for less than 200 USD.
/ Firewood prosessor #17
i found one of those processors for $30 grand, 3 years old... used.
isnt' that pretty dear?
30k used must be $40-$50k new?
that's a lot of money for 1000# of steel.
one of those skid steer processors cost that much!!!!:confused2: how much does a trailer version cost? i thought the trailer versions were as low as $20,000. and there is a lot more on a trailer version. own engine, platform, just seems like $30k-$50k is way too much for an attachment. you are already supplying the power source (skid steer) and there is less materials to make the skid steer attachment as compared to the trailer version. i believe you that it could cost $40k-$50k new but that is OUTRAGEOUS! however if i had the machine to power it and could find one for a sensible price, the skid steer version is the one i would buy. i believe it is the easiest to use and a little less hassle.
/ Firewood prosessor #18
you might also want to check out "forestryforum.com" theres alot of processor builds on that site. Have fun!
Hey thanks for the many good suggestions so far.
Has been started on the frame and found most of the steel I need after standing 3-4 hours shoveling snow, has about 15 "of the white c#@% lying on the ground. I have also found a chip blower for the project. More pictures coming soon
Ok, have begun welding the frame but it's been slow progress since I had to get my dad to the hospital in a hurry.
He began to cough up blood and get a few shades bluer.:( Fortunately, it looks like he is out of danger now.:thumbsup: But back to the firewood processor, here are some pictures of the frame. Also sends a picture of the old firewood processor I replacing
