Firewood prosessor
   / Firewood prosessor #1
Tor Arne
Gold Member
Norway
Same Explorer 65, MF 135, MF 30, MF165, Volvo BM 55, Volvo BM 425, Volvo BM 2254, Terengmester skidder, Ford 3000, Fordson major, Derreng unknown model, IH B275, MAN 4R2, Gutbord sub compact.
Hello everyone. I'm pretty new to the forum, will apologize if anything I say makes no sense since I was not born English speaking. well I have quite a long time played with the idea of building a firewood processor.
Really liked the splitting wedge to this machine. But would rather go for a chainsaw bar and chain instead of blades, what do you think?:) Sending a picture of the parts I have gathered. Since I do not have a work place other than mother nature, Eeverything depends on Temperature if I get something done soon. I am planning what I need, ordering parts and scratching my head for now.
<iframe width="420" height="315" src="http://www.youtube.com/embed/M0FVh99ytIg" frameborder="0" allowfullscreen></iframe>
   / Firewood prosessor #2
welcome to tbn. you english was fine. looks like you have a start on some parts, hydrolic valves and motors, saw bar/chain. sounds like a very interesting project. i wouldn't mind having a firewood processor myself as i have a small firewood business over in the united states. compared to a firewood processor i do everything the hard way. good luck with your build and keep us updated and pictures are nice.
   / Firewood prosessor #3
Did you check the commericial manufactures sites? I see you have chosen a Husky chain bar. Is it the strongest grade that can be bought as the bar is going to be running for many hours. There is a grade of chain called ( Harvester ) that is used in forestery machines.
I bought a new Husky chain saw 2 years ago, maybe a 440?? model on a 16" bar and it is very nice.
What nick names do you call Husky saws in your country?
Your English is fine.
Craig Clayton
Craig Clayton
Hey thanks for the reply. Yes I have seen various commercial firewood processors and either; I do not like them, do not fit my use, not sold in my country or they are too expensive. I want a machine with cab, heater and its own diselmotor so I do not tie up a tractor. Thinking of something like Rapido Loco with the splitting wedge from the video link in first post.
Bar is 24 "bar and chain is the toughest quality I could find. Here in Norway the saws ar just called husqarna, and those who truly love them mostly call them with the woman name Erna. Had planned to make a clutch system, so chain only runs when necessary
   / Firewood prosessor #7
Welcome.
Perhaps you should try doing a search here on this forum. There are a number of threads on this.
Good luck!
   / Firewood prosessor #8
You mentioned clutch for the chainsaw, and if you are talking about a hyd chainsaw, then a solenoid valve motor spool will only run the chain saw when a switch is activated.
Surplus Center - 12 VDC 10 GPM OC MOTOR SPOOL SOLENOID VALVE
Hey thanks for the input:)
Thought I'd use a mechanical clutch and belt drive since hudraulik high RPM motors are expensive and I have a clutch from a suzuki samurai, was thinking of turning a thick-walled tube, which I mounted flywheel, bearings and pulley. Then a shaft with bearings, clutch disc and pulley to the saw. Or does anyone have any other ideas? All suggestions are appreciated:)
   / Firewood prosessor #10
build some type of chain oiler as well,
Informational Lot - Financing (A52128)
Informational Lot...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52128)
Marliss Industries...
Swamp Buggy (A49346)
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
