Tree Planter - Tree Spacing Timer
/ Tree Planter - Tree Spacing Timer #1
Canada_CT230
Nowhere
1878 Ford 65N
I recently bought a Detco 101 tree planter (Detco, Inc. Tree Planters, Spades, and Tongs) and I need a way to equally space the trees while planting.
I have seen the trailing chain method and that is a possibility but I saw this video on YouTube. The chain method would be more of a nuissance as you have to look backwards.
[ame=http://www.youtube.com/watch?v=SnZYayWEvJc]Planting Christmas Trees - YouTube[/ame]
They have some kind of timer or measurment device that beeps when a certain distance is driven.
I have done some searching but haven't found anything. I don't know what it is called so that makes it harder to find.
Any help would be appreciated.
/ Tree Planter - Tree Spacing Timer #2
hmm how about a metronome app installed on your phone and wear headphones?
Can't install apps, don't have a smart phone. Only cell phone we have has a number pad and send/end buttons. Just the way I like it.
I measured the circumference of my rear tire and it is aproximately 11 feet around. Since I want a 10ft spacing that is real close to one revolution of the rear tire.
I wonder if I could rig up some kind of contact switch on the rear tire so that every rotation makes momentary contact and trips a horn.
Not sure how to engineer that...any ideas?
/ Tree Planter - Tree Spacing Timer #6
How many acres or rows are you planning to plant?
I have some ideas but the design will change with the size of the job.
I planted with a 3 pth auger trees by the chain method about 5 acres for this phase of a 10 acre plant.
Craig Clayton
We only plant 750 - 1000 trees per year. The chain method would work but I think it would literally be a pain in the neck to be turned around watching that chain. About 10' spacing.
/ Tree Planter - Tree Spacing Timer #8
Add a second seat to your planter, and have the wife ride along with you. I am SURE that she will tell you when and where to plant them...... [ :) ]
It has a seat for the wife...that is who is inserting the trees into the planter at the interval. I'll be driving the tractor.
I want to go with a distance based beeper. Timing can be too easily screwed up if you slow down , speed up or have to stop.
I've tried to find a beeper distance measuring wheel but had little success.
/ Tree Planter - Tree Spacing Timer #12
Maybe something as simple as painting a white line across one of your rear tires to look at... 11 feet is probably close enough. I hand plant hundreds of trees each spring and fall..just pace off to get my spacing. My wifey is from northern Alabama, and is part Italian and Cherokee... I could see her maybe put in a few trees, before she would be driving and I would be plopping the trees into the trench back in the dusty rear. Either that, or I might want to eat out for a few years... Those Canadian women must be a tamer breed.... :)
/ Tree Planter - Tree Spacing Timer #13
As you are using a 10' spacing and appear to have no need to alter the spacing then I believe a simple mechanical system would work.
I will give you a brief layout for a adjustable electrical spacing method ( I have taken several night schools courses in this field )
automobile brakes use ABS which has a none contact magnetic pickup in behind the hub, this counts at very high speeds the toothed wheel and when there is a predetermined difference the ABS operates your brakes
If you bought a 120 VAC micro PLC by Siemens or Klnockler and used a 12 V to 120VAc inverter to produce the power to run it
on the tractor wheel place maybe 6 magnetic brackets and 1 magnetic proximity switch on the tractor.
In the PLC you make a UP counter each time the prox is made and when the counts equal the distance required the bit is set and the ouput contact sounds the horn.
If your tractor wheel was 12' circ div by 6 = 2' per count
1 count is 2' plant a tree
etc
12 count at 2' = 24' plant a tree.
when I was playing writing a counter program for a store turnstile a visiting electricial engineer looked at my program and said could I add another door counter and I did it quite easily he knew the program was mine and not copied.
Now for a simple mechanical fixed 10' spacing.
A rear trailing bicycle wheel with the chain sprocket driving another sprocket worked out when 10' of travel has happened a simple bracket clunks a tin cow bell.
Craig Clayton
Well she helped me hand plant 750 trees every year for the last 4 yrs. Now, I can't hand plant anymore due to a medical issue. Hence the planter. This DigiRoller measuring wheel looks promising.
I may not want 10 ft spacing... I put the last trees in at 6ft spacing as they are gonna come out sooner than huge mature tree size. Having the adjustability would be really nice and not a fixed setting.
/ Tree Planter - Tree Spacing Timer #15
The video showes the planter towing a white disc on the ground just behind the person planting. That might be a spacing wheel. Could it be something as simple as a wheel that has a pin mounted so that every revolution the pin would hit another metal "finger" and make a clink. Did you ever attach a baseball card to your bike so it rubbed on the spokes of your bicycle when your were a kid? Size the circumference of the wheel to the spacing you want.
/ Tree Planter - Tree Spacing Timer #16
If you want to plant 1 tree per revolution, tape a strong magnet to the rim and put a normally open magnetic switch like: https://www.inventables.com/technologies/magnetic-switch-with-wide-angle-sensing-zone-normally-open where it will pick it up.
Then hook that to a relay and fire whatever you want off of the relay (light, horn, buzzer, etc).
You said that you have an 11' circumference wheel, if you want to plant a tree every 5.5', you can put 2 magnets on 180 degrees apart.
This is similar in concept to a bike speedometer, but it would run a light/horn instead of registering another pulse to the speedo unit.
Aaron Z
/ Tree Planter - Tree Spacing Timer #17
Dont hate me for suggesting it BUT-
A Mingo Paint Marker used for spacing chain saw cuts on logs would be of some use OR an inexpensive walk behind measuring wheel with a quantity of sidewalk marking paint to space the plant settings mounting the Mingo on the front of the wheel.
I thought about the door alarm magnetic switches. I did think that I could put one or more magnets on the rim.
Solution #1:
Magnetic Switch on Rim...
Would the normally open magnetic switch handle the 12v power. The specs on the one I listed was 100mA @ 100v. I don't know how much power is drawn thru the tractors horn. Would I burn out this mag switch?
Solution #2:
Measuring Wheel...
I have found two measuring wheels. The first is a DigiRoller Plus II unit that beeps at a set distance. You can youtube the DigiRoller and see a video of the Auto Count feature. I am not sure if that beep will be loud enough to hear behind the tractor.
The second measuring wheel I found was just a cheap unit. I simply counts the distance. No fancy features. If it has a large LCD display you might be able to watch it count up...I don't think this is as efficient as a beep. Looking diverts your attention too much.
/ Tree Planter - Tree Spacing Timer #19
Solution #1:
Switch just runs a relay and the relay handles the load. Anything more and you will probbaly burn it up.
Aaron Z
Aaron Z
Now your talking stuff that I don't know anything about. Basic electrical is ok but relays, circuit boards, etc. are above my understanding.
I can however follow instructions very well.
2009 CATERPILLAR CS56 SMOOTH DRUM ROLLER (A65056)
2009 CATERPILLAR...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
