Starting a tree and brush shear build
/ Starting a tree and brush shear build #1
stuartmcraycattle
Case JX75
Well I am fairly new here but I would like to have the creative and practical minds help with my design ( hopefully cutting costs). My initial design I drew up tonight is below...The main frame I already possess is 4" square framework from a heavy duty hay fork setup that I have remove the forks...I plan on using mostly .25 sheet for reinforcing and .375 wall box tubing for everything else. the upper grey bar I figure would rest against taller trees to help push them forward away from my tractor... I know I will have to add some bracing at the cylinder mounting points but the drafting program was tough to draw them but I really would like the thoughts on any major points I may be missing...Plan on starting this weekend and I will keep you all up to date...
/ Starting a tree and brush shear build #2
Welcome to TBN.
Is this going on the 3PH or the loader?
Are you going to get some hardened cutting edge material for the shears?
Instead of cutting two 1/4" gussets for the fixed edge frame, how about using one 3/8" or 1/2" thick gusset welded in the middle of the tube?
How big of trees are you planning on shearing?
How much PSI does your tractor's hydraulic system put out?
I plan on building this to work on the front end loader of my CASE JX75 tractor, I will have to check to flow and pressure ratings to match my cylinder, it seems that most commercial sheers use a 4" bore 8" stroke cylinder so that is what I am planning on using since its a proven winner. I am going to try and find hardened blade material from a local land clearing company ( old blades that I can resharpen but maybe are too thin for their massive equipment ) Moving to a center rib gusset is probably a good idea since i can more easily weld both sides (THANKS FOR THAT IDEA)... I will mostly be cutting 1 to 6 inch cedar and hardwood no larger than 3 to 4 inches at best.. Light duty for this setup I would think... the reason I am building is I have over 100 acres and chainsaws under wild thorn rose and other thorned trees is not comfortable especially when there are probably over 400 to 500 to cut...
/ Starting a tree and brush shear build #4
Sounds like a really neat project Stuart. I've always been extremely interested in these tree shear like attachments. I've always thought of building one as well but my tractor is too small to handle that. I thought that if I ever built one I would like to make the push bar hydraulically extendable to "assist" in pushing over as it is sheared, also this would help in ensuring the tree to go the direction you would want it to go.
Have you thought about building it for the 3 pt hitch? I thought if I were to make it on the 3pt hitch, I would make the push bar more of a "V" shape.
The only thing I don't like about the tree shears is that they will tend to make the tree fall sideways to the direction your pointing, I don't know if this is an issue or not, but I like the idea of it falling away from me, although, then you have to be careful of bounceback caused by the compression of the branches as it falls. So I don't know which is best. Either way I'll be following and supporting your build. There is nothing better than making something yourself and getting the pride and enjoyment out of using it, and saving a whole lot of backache at the end of the day. :thumbsup:
/ Starting a tree and brush shear build #5
Stuart,
I actually built one similar to what you are thinking of. I only had a b1700 at the time. I dont remember who but someone told me the little kubota didnt have enough ommph for the job..... me being hardhead I built it anyway. The thing I found out was the little tractor had more than enough power to operate the shear and it worked great for........about 6 to 8 cuts. The scrap yard now owns a twisted pile of metal that resembles new age modern art than what it started out as......Long story endless ....(my opinion only) is that your better off using plate steel at least this what I am doing now. The pressure on these things are tremendous.
/ Starting a tree and brush shear build #6
By the way I am not saying your design wont work. Thats just my story for my tree shear.
/ Starting a tree and brush shear build #7
looks like an interesting build.:thumbsup:
hss is nice to work with, though you may need to build the cyl mount points to plate and then weld the assembly to the hss rather than directly to the hss.
one other thing... it might be handy to have a pushing hand of some sort, maybe 4'-5' above the shear, that would push forward on the tree as it was being sheared. obviously, you don't want trees coming over backwards on you and without a grapple to hold the tree you probably need something to help in that regard.
maybe, also some kind of hook attached to the shear, just above the shear height to help hold the bottom of the tree from kicking forward.
/ Starting a tree and brush shear build #8
.............. . I am going to try and find hardened blade material ..............
A suggestion;
I built a metal cutting shear and needed blades.
My local blacksmith/welder friend suggested going to a truck spring shop and getting lengths of unbent spring stock.
That was quite a while ago and my blades are still as sharp as when I installed them.
Just the nice temper and still drillable.
I can shear 3/16" stock with the setup.
Best, good price.
/ Starting a tree and brush shear build #9
A suggestion;
Best, good price.
I second the spring steel. That stuff is tough. I have used it for several knives, they all hold an edge very well. It is a favourite stock for blade smiths.
Thanks for all of the suggestions, there is a automotive spring manufacturer in Louisville so I will check that out for sure!!! I drew some of your suggestions up to spur more ideas from you guys... So far I moved the solid side to a center support gusset, started to add a what I could as far as bracing to the cylinder end... I removed the solid mount push at the top and replaced with a tube at the top that would contain a very stiff spring that as I approached the tree/shrub would push against it until seated fully but would add to the forward push of the tractor when shearing...
/ Starting a tree and brush shear build #11
The only thing I'm concerned with, is that you have the push bar pushing the tree forward, but the shear will be cutting the tree sideways, so as you start cutting the natural hinge will be left to direct the tree sideways, but the push bar will be pushing it forward?
However, it looks like this is how the standard shear's work anyways, so they must have thought about that too :laughing:
I suppose since your shearing the tree, your not leaving any holding wood so maybe it's a non issue.
The higher the push bar is the better, to an extent, as you'd have more leverage the higher up, and the spring would be more effective.
By the way I think the heavy duty spring is a great, simplistic, and cheap idea. Good work :thumbsup:
/ Starting a tree and brush shear build #12
I would make the pushbar with a V on the end. This may help to push the tree forward
/ Starting a tree and brush shear build #13
I will second the idea of the push bar being able to kind of capture the tree and keep it in place, "V" or better yet, a "C" shape. I am especially curious as to how this will work when it is finished. :thumbsup:
/ Starting a tree and brush shear build #14
I have a tree shear, once on my 33 HP tractor. The base plate I think is about 1 1/2 or 2 inches thick. I did not build a bypass valve in it and the pressure actually bowed/bent that plate. It still works OK but not sure how I would ever straighten it. I found it too slow for the thousands of trees I needed to take down. I should just sell it I guess.
Only posting this so my problem can be avoided in your build.
/ Starting a tree and brush shear build #15
Pictures of your shear showing the area where the plate bent would help everybody in their designs. Energy to bend a plate 1 and a half inches thick is a above my expectations and I usually overbuild things. A picture will shed some light on why.
David from jax
I would like to see the damage to the shear blade as well... as far as the pusher bar being "v" or "c" shaped I don't know if that is quite necessary as the tree will inherently fall towards the side due to the shearing action. The bar would only to be to prevent backwards tilt (common sense says to judge the wind and cut with my back to the wind) so the tree will fall away from and to the side of the tractor... I guess I should also clarify that nothing I am cutting will be over 15 to 20 foot or over 6 inch base diameter... there are just a lot of them.... My lack of knowledge really is in the hydraulic end but if the blade stops precisely at the stop block or within 1 or 2 mm shouldn't most trees be cut enough to fall and keep the cylinder from bending the blade?
/ Starting a tree and brush shear build #17
btw, are these trees really tight together?
i have used brush saws with very good results in that sort of situation.
also, if you have a long cable, and somebody to hook the trees, can you just pull them out roots and all so you could smooth the ground nicely afterward?
also, if the trees are too tight, then they wouldn't fall forward anyway... isn't that why feller/bunchers lean the tree to the side?
[ame]http://www.youtube.com/watch?v=ivatjLaYJU8[/ame]
The trees are scattered, not many bunched together. I considered making the blade bolt on so that i could also make a serrated grabber piece to attach and pull out the smaller sub 2" trees and bushes.. anything larger I think would tear up the field too much and we don't have a lot of good loose soil to fill holes or time to plant seed in the hundreds of bare spots that I would have LOL... any recommendations on specifications on hydraulic flow rates, bypass valves, pressures would be awesome from those knowledgeable in that area THANKS GUYS FOR ALL THE IDEAS
/ Starting a tree and brush shear build #19
Here is a thought. Put the shear on the back and put a grapple on the front. Then you can clean up as you go
/ Starting a tree and brush shear build #20
Having the shear on the 3pt would allow the ROPS to help protect the operator and still have a good view of the shearing.Heavy mesh screen mounted on the back of the ROPS would keep the limbs off him too. And a grapple or forks would be helpful in building piles of downed trees for pickup ,chipping ,etc.
I'm certainly interested in this project, keep going .
Just my $00.02 worth.
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
UNUSED WOLVERINE SB84-84" ROCK BKT (A62131)
UNUSED WOLVERINE...
2017 FORD F-550XL CREW CAB FLATBED SERVICE TRUCK (A62130)
2017 FORD F-550XL...
2018 Chevy Traverse 3rd Row Seating (A63118)
2018 Chevy...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
