Allied blower not moving snow
   / Allied blower not moving snow #1
nstractor
Let me start off by saying I am new to tractors, bought a MF 231 and recently purchased a Allied blower model SB73. Hooked it up today to try it out and was disappointed to find it barely blows the snow. It just kind of lobs a foot or two out of the chute. Everything seems to be moving and turning as it should, any ideas of what is wrong or what I could do to improve its performance? Thanks in advance
   / Allied blower not moving snow #2
Was the snow wet or dry? Trying to blow wet snow is terrible. After you have cleared the chute several hundred times you will know what we all mean.
Please use a poker stick to clear the chute and turn off the blower.
Craig Clayton
Nice dry powdery snow, everytime I jumped out to look the auger and chute would be pretty clear. I even tried pushing more into the blower by backing up and all it did was kind of pile up?
   / Allied blower not moving snow #4
How much snow were you tring to throw? Was the impeller turning?
Not much snow, maybe 8-10", the impeller was turning, even when the tractor was off and I spin the auger by hand the impeller spins.
   / Allied blower not moving snow #6
That's weird.Did you have your rpms up to full 540 rpm pto speed?And also be sure you don't have a broken sheer pin i would visually inspect them to make sure they are both intact.How fast were you traveling when blowing the snow and could you hear the engine straining to the load?
   / Allied blower not moving snow #7
Could you be having trouble with the tractor PTO output shaft not spinning the blower fast enough underload?
Did you check to see if any shear pins are broken on the blower once again slipping underload.?
Craig Clayton
   / Allied blower not moving snow #8
There was a blowercaster from Allied.
Whose impeller was acting a bit fried.
It behaves like the shaft,
is going backwards, I laughed ?
No wonder it acts like it died.
The tractor was running in low range, at high rpm, the motor was straining (rpms not falling off). I will inspect the shear pins in the morning.
   / Allied blower not moving snow #10
Yeah sounds like you've got a broken sheer pin.
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2009 Ford F-150 Pickup Truck (A59230)
2009 Ford F-150...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
