pharmvet
- Joined
- Sep 28, 2008
- Messages
- 535
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have cut up several large dead trees and am planning to split them with my hydraulic 3 pt. splitter. Many of them are large and in order to try to save my back, I thought I might use some of those 2 man log carriers (long handle with tongs in the middle) to pick up the chunks and place them on the splitter. I figured having someone else split the wt as well as putting a handle on those bulky trunk pieces would make life a bit easier. Problem is, I have found that most of the 2 man log carriers have tongs that will only open to about 16 inches max. Do any of you know if there are any that open wider? I thought about using skidding tongs hanging from the middle of a steel pipe?? Has anyone else used tongs for this use? thanks
