Surge relief valve question
/ Surge relief valve question #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
There is a turn screw just visible in the upper portion of this picture that is situated on the surge relief valve of this 750 JD. Does anyone know how this screw regulates and what effects on the overall hydraulic system it may possibly have ?
/ Surge relief valve question #2
If it's the one I'm thinking about it's a rate of drop screw for the 3pt hitch.
Jim, the drop is controlled by the stop valve or the thing that looks like a spigot handle. What I am talking about is the set screw on the surge relief valve. They may very well do the same thing but I do not know.
It may be better if this question is moved to "hydraulics"
/ Surge relief valve question #5
Might also help if you would point to the particular "just visible" screw in question. Not clear from the pic or the description. ;)
Ok, let's have at it again. At the top of the picture there is the red knob visible of the shifter. To the left of the shifter knob, about 2.5" ( two dimensionally speaking) and at 8 o:clock is the slotted screw I am referring to. It resides on the surge relief valve. Don't know how to graphically put an arrow in there.
/ Surge relief valve question #7
That screw controls the amount of hyd psi applied to hyd functions such as 3pt or scv's.
/ Surge relief valve question #8
Thanks. This the one at the red arrow?
Jim, is this surge relief valve pressure increase only apply to the 3 pt and remotes?
I just put shims in to the main relief valve which to my understanding increases pressure all around.
/ Surge relief valve question #11
That's it. How is the arrow put in there?
Massaged your pic with a Photo shop program. "Paint" will do the same I'm sure.
With a handle "Arrow", then you better learn that technique. Hehehe :laughing:
You would think. My photo jobby has no provision for drawing on the photo except to enhance effects. (Apple)
/ Surge relief valve question #13
Arrow
IIRC that valve controls system pressure.
Be careful or you may split the hyd pump
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
John Deere Z960M Zero Turn Mower (A64047)
John Deere Z960M...
2008 New Holland T2420 (A60462)
2008 New Holland...
2018 Chevy Traverse 3rd Row Seating (A63118)
2018 Chevy...
2016 FREIGHTLINER CASCADIA (A63569)
2016 FREIGHTLINER...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
