Taylor Way or Sicma Phoenix Tiller
   / Taylor Way or Sicma Phoenix Tiller #11
Thanks for all the help and the Tarter tiller certainly looks like a well built tiller.
Unfortunately for me, the Kubota owners manual for the BX 2360 lists the weight limitation for a rotary tiller at 375 lbs., even though it lists the lift capacity at well over 600 lbs. ???
I have read The King Kutter 48" and Taylor Way 48" are also over 500 lbs.
I am now deciding between a Bush Hog RTC 48" with 4 tines per flange or the Phoenix RT4 48" with 6 tines per flange. I understand both are made in Italy by Sicma. The Phoenix is approximately $200.00 more.
Maybe I can't go wrong with either since they are both under 400 lbs.
We are also a Phoenix dealer and can sell the T48 for $1625 within a 1000 mi radius of Wilson, NC. Ken Sweet
I appreciate your response Ken. The local dealer has the Bush Hog RTC 48" for $1425, which is 200 less than the RT4 48". Is the only difference between the Bush Hog and the Phoenix - the additional two tines per flange?
Thanks again,
Chuck
   / Taylor Way or Sicma Phoenix Tiller #13
Thanks again,
Chuck
You get the quality craftsmanship and latest technology from Phoenix/Sicma (Made in Italy) I honestly don't know much about Bush Hog since they split up and sold off their product lines. I suspect there is a lot of old inventory floating around?? Ken Sweet
Ken
If I order the tiller from you, what is the best price you can sell a 12" low profile single bottom plow, compatible for the BX2360? Hoping to get a Linebech or comperable plow.
   / Taylor Way or Sicma Phoenix Tiller #15
Ken
Our low-pro plows are on back order currently. Ken Sweet
Anybody have an opinion on Howse single bottom plows? Howse is what our local farm equipment dealer has to offer. I believe they
may come from India, but not sure.
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2014 Walker Compactor (A55787)
2014 Walker...
New Wolverine 84in 5way Skid Steer Scrap Blade (A59000)
New Wolverine 84in...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2020 PRAT TL (A55758)
