Taylor Way or Sicma Phoenix Tiller
   / Taylor Way or Sicma Phoenix Tiller #1
Chuck Eaton
Kubota BX 2360
I'm in the market for a new 48" tiller for my Kubota BX 2360. The sub-compact tractor has 23HP with 17.7HP to the PTO. I have been told by a dealer that Sicma-Phoenix, made in Italy, makes the best tillers. The Taylor Way looks identical to a King Kutter, is gear driven and is significanlty heaver than the Phoenix. Both tillers have six tines per flange. The Phoenix is approximately $200 more and is chain driven.
Also I have been told that the BX2360 is too low to the ground to use a low profile 12" single bottom plow, designed for sub-compact tractors.
Any suggestions on the tillers or experience with low profile plows with a BX tractor.
Chuck
   / Taylor Way or Sicma Phoenix Tiller #2
Welcome to TBN. :)
Thank You!
Thanks for the tip!
   / Taylor Way or Sicma Phoenix Tiller #6
Chuck
We sell the 48" Tarter made in the USA for $1595 and is geardrive, slip clutch, quick hitch compatible, 6 tines per rotor and powder coat finish. Link to our Ebay listing below. Ken Sweet
New Tarter 4 FT Roto Tiller with Slip Clutch, CAN SHIP CHEAPER THAN YOU THINK ! | eBay
How much does the Tarter 48"tiller weigh?
   / Taylor Way or Sicma Phoenix Tiller #9
Not to change your mind but check the king kutter at tsc. I think the 48" is $1400.
I have the jd 2320 and 2305. The KK 60" works great on them. Its an awesome tiller. Only $1500.
Thanks for all the help and the Tarter tiller certainly looks like a well built tiller.
Unfortunately for me, the Kubota owners manual for the BX 2360 lists the weight limitation for a rotary tiller at 375 lbs., even though it lists the lift capacity at well over 600 lbs. ???
I have read The King Kutter 48" and Taylor Way 48" are also over 500 lbs.
I am now deciding between a Bush Hog RTC 48" with 4 tines per flange or the Phoenix RT4 48" with 6 tines per flange. I understand both are made in Italy by Sicma. The Phoenix is approximately $200.00 more.
Maybe I can't go wrong with either since they are both under 400 lbs.
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
