Taylor Way or Sicma Phoenix Tiller
   / Taylor Way or Sicma Phoenix Tiller #1
Chuck Eaton
Kubota BX 2360
I'm in the market for a new 48" tiller for my Kubota BX 2360. The sub-compact tractor has 23HP with 17.7HP to the PTO. I have been told by a dealer that Sicma-Phoenix, made in Italy, makes the best tillers. The Taylor Way looks identical to a King Kutter, is gear driven and is significanlty heaver than the Phoenix. Both tillers have six tines per flange. The Phoenix is approximately $200 more and is chain driven.
Also I have been told that the BX2360 is too low to the ground to use a low profile 12" single bottom plow, designed for sub-compact tractors.
Any suggestions on the tillers or experience with low profile plows with a BX tractor.
Chuck
   / Taylor Way or Sicma Phoenix Tiller #2
Welcome to TBN. :)
Thank You!
Thanks for the tip!
   / Taylor Way or Sicma Phoenix Tiller #6
Chuck
We sell the 48" Tarter made in the USA for $1595 and is geardrive, slip clutch, quick hitch compatible, 6 tines per rotor and powder coat finish. Link to our Ebay listing below. Ken Sweet
New Tarter 4 FT Roto Tiller with Slip Clutch, CAN SHIP CHEAPER THAN YOU THINK ! | eBay
How much does the Tarter 48"tiller weigh?
   / Taylor Way or Sicma Phoenix Tiller #9
Not to change your mind but check the king kutter at tsc. I think the 48" is $1400.
I have the jd 2320 and 2305. The KK 60" works great on them. Its an awesome tiller. Only $1500.
Thanks for all the help and the Tarter tiller certainly looks like a well built tiller.
Unfortunately for me, the Kubota owners manual for the BX 2360 lists the weight limitation for a rotary tiller at 375 lbs., even though it lists the lift capacity at well over 600 lbs. ???
I have read The King Kutter 48" and Taylor Way 48" are also over 500 lbs.
I am now deciding between a Bush Hog RTC 48" with 4 tines per flange or the Phoenix RT4 48" with 6 tines per flange. I understand both are made in Italy by Sicma. The Phoenix is approximately $200.00 more.
Maybe I can't go wrong with either since they are both under 400 lbs.
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
CAT Chassis Only (A59076)
CAT Chassis Only...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB46449, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
