Exhaust Fluid
/ Exhaust Fluid #1
Mark Page
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
Anyone ever heard of exhaut fluid. I see it advertised in the farm paper and have no idea what it's for.
/ Exhaust Fluid #2
Watch this, and it will tell you more than you ever wanted to know about DEF (Diesel Exhaust Fluid)
[ame=http://www.youtube.com/watch?v=GF5Oggb7gUk]2011 Ford Super Duty Diesel Exhaust Fluid (DEF) Tutorial - YouTube[/ame]
James K0UA
/ Exhaust Fluid #3
It's that crap Ford and GM diesel trucks need to be as clean burning as a Cummins powered RAM! ;-)
/ Exhaust Fluid #4
I just got a new semi truck with a Pacar motor yesterday that burns that. Its urea and water. My semi holds 25 gallon and is supposed to last 4000 miles. Massey and Case Ih are using it on their farm tractors. I figure its just a matter of time before we see it on utility tractors.
/ Exhaust Fluid #5
Cummins will be joining them soon. Its also in lots of farm machinery now and heavy equipment.
Chris
/ Exhaust Fluid #7
Apparently some car engines require this and some don't, depending on their emissions output. The VW Passat diesel uses this but the Golf with the diesel does not. Hopefully the smaller CUTs will be exempted.
/ Exhaust Fluid #8
No, eventually they will all be required to mert Tier 4 final.
I'll take the SCR/DOC set up over cooled EGR any day.
/ Exhaust Fluid #9
Well my new truck is off to a good start with the DEF. I used a half a tank of the stuff in the first 80 miles this morning. I am in the shop now but they think it was stuck in the regen mode. I may be old fashion but I hate all this emission crap. Just more to go wrong with the truck.
/ Exhaust Fluid #10
Stupid me. When I first saw this thread, I thought it was going to be like exhaust bearings.
My daughter was sent to the autoparts store once to get new exhaust bearings by her boyfriend. She was shocked at the price the counter man quoted her, over $100 each and she needed two for her truck year model.:laughing:
/ Exhaust Fluid #11
There are presently two ways of meeting Tier IV emmision requirements for diesels; one requires a special exhaust particulate filter(JD) and the other requires DEF(NH/Case/IH). Supposedly the DEF allows optimum performance tuning that keeps the BSFC low(High fuel efficiency). If I recall correctly, the DEF reduce the NOx in the exhaust.
/ Exhaust Fluid #12
Whats the big deal, she just charged it to her BF account right? :laughing: :laughing:
/ Exhaust Fluid #13
Enhanced EGR that Dodge uses, puts more exhaust in the intake to control the pollution and to do a regeneration they add fuel in the exhaust stroke to get it to clean the particulate filter. They put a plug in the turbo Turbine housing, to add chemicals to get the carbon build up out.
Ford uses, DEF to control the Nitrogen Oxide, and injects the fuel in the exhaust stroke to clean the particulate filter. They run a reversed exhaust system, were the exhaust comes into the middle to keep the heat and the turbo clean.
GM used DEF to control the nitrogen oxide, and has an extra injector in the exhaust system used to heat the exhaust enough to clean the Particulate filter.
I have a 2008 duramax and the 2011's get more power from less fuel and they use the DEF.
Europe has used DEF for a while and there are no real problems with it.
Every time I hear all the blabber about the big problems that are going to happen I remember the BS that was spread when they took the Lead out of Gasoline.
/ Exhaust Fluid #14
You and me both! I was expecting something along the lines of muffler bearings, blinker fluid, or piston return springs.
Actually, you can get the muffler bearings much cheaper online. :thumbsup:
Muffler Bearing - $49.99 : KaleCoAuto, Hard to find automotive items!
/ Exhaust Fluid #15
The only reason Dodge has a Cummins is they can't sucessfully design their own diesel engine.......:laughing: Forgot, it's a Fiat......:D
Your RAM ain't exempt. You just need to pony up and buy a new one. It's there. It's there on every 2012 Diesel powered truck no matter what size.... and all Cummins engione company powerplants have it for on road use....
Thank Obama, the tree huggers and all the other know nothings.
4 more yoears of Obama.... Like it.
/ Exhaust Fluid #16
Wow, you couldn't be more wrong if you tried...
Where do I start?
Ram doesn't need to design a diesel but I have no doubt they could. All their other engines are bulletproof. What other manufacturer makes a good in-house diesel, Ford? Yeah, they're off to a great start...
A new RAM does NOT use DEF except in the cab-chassis trucks and that's only due to the significant cost savings over the special catalyst system the RAM trucks use.
http://m.ramtrucks.com/en/mobile/vehicles/index.html?year=2012&vehicle=ram_3500
Quote from page:
Meets 50-state emissions with no diesel exhaust fluid (DEF) required
4 more years of Obama? Wrong again...
/ Exhaust Fluid #17
Are you sure the DEF tank was FULL upon delivery? I'm assuming you have a new Ford, since there is no DEF gauge you don't know exactly how full it is. Message screen just says "OK", under half or count down to empty. Dealers have been known not to top off the DEF tank.
/ Exhaust Fluid #18
Where do I start?
Mobile | Vehicle Homepage
Quote from page:
which one had the killer dowel pin ?
/ Exhaust Fluid #19
[iQUOTE="Soundguy"]
which one had the killer dowel pin ?[/QUOTE]
First gen rams, i think all 12 valves. I know early second gens had them. If fiat would shove an iveco under that hood, they would not need cummins.
2015 Ford F-250 Ext. Cab Animal Control Service Truck (A66736)
2015 Ford F-250...
Unused 2025 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2025 USA...
2012 CHEVROLET CRUZE CAR (A66091)
2012 CHEVROLET...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
