Hydraulics on JD 5105
/ Hydraulics on JD 5105 #1
jbwrangler
New to the forum.
I have a JD5105 (2000 model) that had 2 rear SCV's controlled by two levers beside the seat. The tractor has a 553 loader that is plumbed into the rear remotes.
Is there a way to convert this to a joystick and or mid-hydraulic set up? Can I keep the rear outlets?
Not sure what my options are for adding hydraulics on this tractor.
Thanks in advance.
/ Hydraulics on JD 5105 #2
You can add a mid scv as shown. It does not interfere with your rear hydraulics.
Thanks. Exactly what i was looking for. Any idea what something like that would cost?
/ Hydraulics on JD 5105 #4
Would this configuration be an option for a 4520 for a grapple or other FEL mounted hydraulics? Learning about SVC's and options.
Thanks
/ Hydraulics on JD 5105 #5
Thanks
4520 comes standard with the mid scv ( two of them) operated by the joystick. For a grapple you can install a diverter on your existing to switch one function back and forth or install a separate 3 rd rear and the fel third hard line kit and run it to the front. If your 4520 is 2011 or newer the 3 rd is electro hydraulic and is controlled by a thumb switch on the joystick. If older it is a lever that fits in the slot next to the 3 pt lever.
/ Hydraulics on JD 5105 #6
Okay, that makes sense now. My 4520 is a 2008 and has the joy stick for the FEL. I am learning about hydraulics and how best to expand its use. Thanks for the feedback.
/ Hydraulics on JD 5105 #7
Thinking about this further, what are the options for a 3rd function to the FEL for this optional use? Are there just the two options that you mention, a diverter on the mid SCV or a 3rd function on the rear running up to the front?
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
2020 International LT625 48" Sleeper (A62613)
2020 International...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
