Hydraulics on JD 5105
/ Hydraulics on JD 5105 #1
jbwrangler
New to the forum.
I have a JD5105 (2000 model) that had 2 rear SCV's controlled by two levers beside the seat. The tractor has a 553 loader that is plumbed into the rear remotes.
Is there a way to convert this to a joystick and or mid-hydraulic set up? Can I keep the rear outlets?
Not sure what my options are for adding hydraulics on this tractor.
Thanks in advance.
/ Hydraulics on JD 5105 #2
You can add a mid scv as shown. It does not interfere with your rear hydraulics.
Thanks. Exactly what i was looking for. Any idea what something like that would cost?
/ Hydraulics on JD 5105 #4
Would this configuration be an option for a 4520 for a grapple or other FEL mounted hydraulics? Learning about SVC's and options.
Thanks
/ Hydraulics on JD 5105 #5
Thanks
4520 comes standard with the mid scv ( two of them) operated by the joystick. For a grapple you can install a diverter on your existing to switch one function back and forth or install a separate 3 rd rear and the fel third hard line kit and run it to the front. If your 4520 is 2011 or newer the 3 rd is electro hydraulic and is controlled by a thumb switch on the joystick. If older it is a lever that fits in the slot next to the 3 pt lever.
/ Hydraulics on JD 5105 #6
Okay, that makes sense now. My 4520 is a 2008 and has the joy stick for the FEL. I am learning about hydraulics and how best to expand its use. Thanks for the feedback.
/ Hydraulics on JD 5105 #7
Thinking about this further, what are the options for a 3rd function to the FEL for this optional use? Are there just the two options that you mention, a diverter on the mid SCV or a 3rd function on the rear running up to the front?
2011 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A63569)
2011 ORTEQ ENERGY...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2021 John Deere Z960M Zero Turn (A63116)
2021 John Deere...
2015 John Deere X320 Lawn Mower (A63116)
2015 John Deere...
