Pulling well pump
   / Pulling well pump #31
I agree completely. The schedule 80 PVC, threaded sections is the right material for the job. It is much lighter than the galvanized pipe, so the total weight will not be anywhere near the 1500 lb of the existing pipe.
Now, my suggestion would be to use either galvanized or stainless for the very top 21' section of the pipe. The reason for this is that if something happens to hit the Tee at the top of the well casing plastic pipe can be broken off and the pump will fall to the bottom of the well. If the top section is metal pipe, it will not break and will protect the rest of the pipe string.
If the pipe string and pump falls to the bottom of the well, it can cost many thou$ to recover the pump. Do not ask how I know this...
And this is why we use a safety rope tied to the pump:thumbsup:
   / Pulling well pump #32
Around here there's no tee to break off. Since the ground freezes they use a pitless adapter, some a light weight brass ones but most well companies use a nice heavy one. I know mine is about 5 feet down below grade in the casing. It has a stainless cable with a clip that hooks onto the top of the casing that doubles as a release for the latch that locks when slid into place.
The drillers have found the safety ropes to be more of a pain than help. Usually they are not strong enough to retrieve the pump if it get caught on the jagged sides of the well and if it falls into the well (they actually have this problem quite often) the rope gets sucked into the impeller of the pump and now needs to be removed.
They also use a heavy duty barbed fitting that's thicker and has a longer than normal section where the plastic pipe slides on.
   / Pulling well pump #33
And why the pump has a tasb for attachment. Ill admit I havent use the rope to pull a pump out I alwasy considered it an added safety against loosing it down the shaft.Knowing now it is supposed to be used to pull the pump up I then imagined something like the piost with the car wheel and then a cheap winck on it to drive the wheel and you would just wind the rope onto the wheel.Im not sure how much rope would hold..
   / Pulling well pump #34
I've been told to hook the rope to a ATV/Truck/Tractor and pull it over a large tractor rim (with no tire on it), but I think that will only work if its a single piece of plastic pipe.
Note I've never done it, but I'm planing for it since I don't know how old my well pump is.
   / Pulling well pump #35
I have never done a pump, my neck of the woods has few, BUT SOME HOWEVER, common sense seems to me, to dictate a safety wire / rope. I woukld offer this for X dollars and it would be clear in my recomendations to install it, recomendations not preformed at YOUR risk.
1500' of SS .125 wire is CHEAP compared to loosing anything down a hole that deep. Pumps do come w/ tabs to tie off too yes? Just seems like a no brainer to me.
   / Pulling well pump #37
Poor drawing of a puller my friend and I built to pull hi 400+' well.
Took maybe 2 hours to pull with this. Breaking some of the couplings loose was the bigger PITA.
The square in the top held the pipe upright as it came up, the 2 chain hoist worked great. Pull half with the 1st chain then pull the rest with the second hoist. When we got the coupling a foot or so out of the well head we put both the "pipe grabbers" we made below the coupling to hold it while we broke the upper joint free, then we just pulled in down and away from the platform.
We used 2-3/8ths" pipe for the legs and pinned them to the ground with metal stakes through the base plates.
The pullers we made from 1/2 steel plate and unlike my drawing they only had around a 3/8" clearance from the pipe, so we could get a good "bite" angle. Also had an "offset" cut out opening, so they wouldn't fall off, (1st ones we made fell off:thumbsup:
I wasn't there to help him put it back in, but he said it was a "snap" with his grandson. He did use some kind of anti-seize on the threads.
He built a deer feeder out of it when he was done:D
   / Pulling well pump #38
when I had to pull mine when the safety rope broke I had ~200ft of sch 120 pvc pipe on the bottom and 200+ poly pipe on top.
I took a 6' piece of 3/8 chain and put about 5 or 6 turns around the pipe and brought the end back up to the hauling end put a grade 8 3/8 nut bolt ans heavy washers through it. it sort of looked like a noose.
I used the back hoe to pull on one if these and used another below it to lock the pipe it was fastened to the steel case with a separate bolt lowering the backhoe the lower one would grab the pipe the upper one would slide down the pipe as I lowered the hoe and re tighten as soon as I lifted back up for the next cycle.
When I was ready to put it back in I put 1/2" poly rope on it instead of the 1/4 that was on it for safety. I did all this by my self with the backhoe's assistance and it took 2 good days to pull it and put it back in I used the tractor and the 1/2" rope to lower it back down.
tom
   / Pulling well pump #39
I have a 2" black Plastic pipe attached to an old well pump. I tried to remove the pipe and pump to replace it, however, the pipe cap slipped off the pipe, and the pipe and pump fell into the well. The pipe is approximately 50' down, and leaning against the 6" galvanized pipe. How in the world can I retrieve the pipe and pump? I have read a few threads, but it doesn't seem like there is anything I can just go to the local Tractor Supply and buy. Any suggestions would be appreciated.
   / Pulling well pump
How deep is the well ?
A well driller can try to fish the pump out by the wire.
You can also try to lift it out by drooping 1 in steel pipe to the bottom of the well and blow the pump out with a BIG air compressor.
E/S
2014 Chevrolet Equinox LS SUV (A48082)
2014 Chevrolet...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
1272 (A50490)
1272 (A50490)
