Loader clamp on forks
/ clamp on forks #1
kubota L3200; john deere lt190
has anyone used the clamp on style of of forks??are they worth spending the money on or do they move around to much??
/ clamp on forks #2
I have the ones that slip over the edge of lip of the bucket and then the chain wraps around the bucket and hooks into the top of the fork with a ratchet tightener. They are usable but the tips will move if you bump the ends and are somewhat aggravating but beat nothing and considerably cheaper than dedicated forks. I'm well satisfied with mine for my uses and the price. Would buy again.
/ clamp on forks #3
I have a set for my BX25. They work well for what they are. They do tend to move so you have to reset and tighten clams often. They will not lift weight equal to bucket capacity as they stick out that much further. I use them all the time for loading/unloading stuff from the truck. You will need good ballast on the 3PT to counter the leverage way out front. I gave up on lifting pallets of wood and use a universal carrier on the 3PT. I added a third one to move brush onto burn piles, works good for that also for now. Plan to make a hook on set of brush forks before summer to handle brush. Will post pictures after I get it made.
Ron
/ clamp on forks
sounds like id be better off fabbing up some that bolt on to the bucket wanting to use mainly for debris and brush removel
but would like them to be adjustable for the occasional pallet
/ clamp on forks #5
If your a "fabber" that has the metal working tools, the metal and a bit of time then for sure go for making your own.
/ clamp on forks #6
Another option to pick-up some clamp-on forks on the cheap is to keep an eye on the want ads. In this area they tend to show up on Craigslist pretty regularly but you have to be patient. After about a month of looking I found a set of Payne's medium duty forks in good shape for $125. I didn't want to spend much more than that given their limitations and my uses and I can't justify the $$$ for converting to a QA pallet fork setup so this worked out well.
They work great for brush, limbs, and lighter pallets. It is also nice to be able to move stuff on a pallet rather than chaining/slinging it up. But they are definitely not a replacement for a proper pallet fork setup (IMHO).
/ clamp on forks #8
I bought a set on e-bay for like 169 bucks i think. I use them for moving logs around my sawmill and for firewood. They do tend to move a-lot when trying to move brush around but like someone mentioned before for the price you can't beat um compared to the actual attachment.
/ clamp on forks #9
Forgot to mention. If you through a ratchet strap or chain around them it helps quite a bit with the movement. The ones I have have the spot for a chain to connect to both sides. If you are going to use them for brush I wouldn't recommend them but for moving logs or pallets they work great IMO.
/ clamp on forks #12
It would depend on if you mean the type that clamp on to the bottom lip of the bucket OR the kind that clamp and hang from the top lip of the bucket. Since I have the kind that clamp on the top lip of the bucket I can comment on those, because I cannot see how the other type could work. Since the forks are "L" shaped, the short leg of the "L" is attached to the clamp at the top lip of the bucket, and the right angle of the "L" is at and just below the bottom lip of the bucket, protruding forward to lift whatever you're moving. That part should be able to fit between the teeth on the lower lip. Check out the forks at BXPanded.com. Harry is great to work with, and can help you further.:thumbsup:
/ clamp on forks #13
Are clamp on forks still suitable on loader buckets fitted with tooth bar teeth? Anyone care to comment?
I have a land pride set. 1,000lb capacity rating. They do work with my tooth bar. As others have stated they are "OK" for certain things. Have to be careful with heavy loads way out on the end. While a 1,000lbs might seem like a decent weight rating, gotta keep in mind the possibility the bottom of the bucket bending.
/ clamp on forks #14
Spend the extra money and get a quick attach set. The problem with the clap on forks is that they reduce a lot of the lifting power of the loader by moving the weight further forward. Secondly the bucket blocks your view, not that the QA system allows a great view of the forks.
I have a 3500 lb set for my full size backhoe and while they work they are far from ideal. It doesn't have a QA system so the clamp on style forks were a cheap option. They do the job and because the lift capacity of my BH is a lot more than a cut lack of lifting force hasn't been too much of an issue. But I've already decided to just spend the extra money and get the QA style for my Kubota.
/ clamp on forks #15
I know that no one likes to do this, but the search function can be your friend. This is a subject that has been posted upon thousands of times over the years.
I usually try a search first for a question that I may have. If I don't find answers specific enough, then I post a new topic.
However, it is really easy to miss something that someone else may have posted about your specific question because there's such a volume of information here.
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
2017 Dodge Grand Caravan Van (A66738)
2017 Dodge Grand...
CAT 345CL Track Adjusters (A68134)
CAT 345CL Track...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
CAT D6R Straight Blade (A68134)
CAT D6R Straight...
1999 Johnson 25hp Boat Motor 225hp 2-stroke Boat Moter (A66738)
1999 Johnson 25hp...
