dieselscout80
Elite Member
We have a block retaining wall (8"x8"x16" block) and we'd like to take the end of it and make a small circle to use as a planter. What is the smallest diameter circle that can be built with 8"x8"x16" block?
Ten 16" blocks will give an inside diameter of just over 48". Whether laying with mortar or dry stacking you'll have very large joints on the outside (i.e.4"), so if you cut 1" off each end of each block on the inside diameter you'd still have 2" joints on the outside with a slight reduction in diameter. You need blocks with ears (strechers) rather than square ended (jamb) blocks for this. You can go smaller understanding that the fewer blocks the less "round" it will be. MikeD74T
It looks to me that you have a curved wall to start with. Perhaps the answer lies within the wall. Purely an exercise in mathematics but you can just align the block you are using with the size of mortar joint you are comfortable with and then do the math.
Yes, but I want a tighter curve and in the opposite direction of the current curve.
The angle block are meant to be stacked to form a vertically straight corner. They willl work but will not be "round'. Half block are square ended & much more difficult to cut if it's desired to reduce joint size as well as there'll be less overlap of blocks but would be "rounder" than full block.
I'd take down 4 ' of the existing wall & go with a bigger radius. Filling the cells with grout/rebar will help with freezing/pushing concern but good drainage behind the wall is even better. The existing wall seems to have held up ok. My first post assumed 8" block but the wall looks to by 10" or 12"??? MikeD74t
Much better ideaWhat if I got a piece of concrete culvert and used that to make the planter?
