counter sinking screws
/ counter sinking screws #1
rayclar
prince township , ontario, canada
kubota 4310hstc
Hi all, noob here as far as allunium goes. I have to countersink some flat head screws in 1/4 inch allunium and would like to know the easiest way of doing it. I have limited metal working tools but lots of wood working tools. Any help would be appreciated. thanks ray
/ counter sinking screws #2
If you don't want to spring for a countersink bit you can use a drill bit the same diameter as the head of the screw. The taper won't be exactly right, but it'll get the job done as long as your material isn't too thin. Test on scrap first of course.
Ian
/ counter sinking screws #3
A 7 flute rose counter sink would be my choice but they are more difficult to find than lesser 3 fluted. As mentioned, a twist drill can be used and to give a better fit it can be ground to the correct angle. In either case, if possible, use a drill press with a depth stop and the work clamped to the drill press table.
All good wood workers have a counter sink don't they?:D
yes i have wood counter sinks 5 flute, just did'nt realize i could use them on aluminum. What speed should i set the drill press at ? thanks all
/ counter sinking screws #5
Somewhere less than a speed for hickory like maybe try around 500 to see how that works. By the seat of the pants guessing here.
/ counter sinking screws #6
Shouldn't be a problem using the wood CS. Aluminum transfers heat so fast you'd really have to lean on that drill at high speed to over heat it. Like Sandbur says, using a drill press rather than a hand drill will give you much better results - less chance of "pentalobbulating" with the 5 flute CS.
/ counter sinking screws #7
I suggest a countersink. They aren't that expensive. A countersink stop would be nice, but only if you have a lot of usage for one.
Most flush screws use an 82 degree countersink...but not all. Some are 90 degrees (these are included angles, BTW). A typical drill bit has a 119 degree included angle.
I wouldn't countersink aluminum sheet less the .06" thick and definitely never countersink if .04" or less. That thin sheet should be dimpled.
/ counter sinking screws #8
If you happen to have a little kerosene, dip the countersink in it before cutting the aluminum. ;)
/ counter sinking screws #12
If it's a one time job just go buy an 82 degree bit from the hardware store. If you think you are going to be doing more of this type work, consider getting a decent set. Cost more. I have a set of 82" Uni-bits that work awesome but they were pretty spendy.
/ counter sinking screws #13
Oh I don't know, never tried it. Might work, give it a try, can't see where it would hurt anything.
/ counter sinking screws #14
Whatever method, watch your eyes! Aluminum won't come out with a magnet at the eye doctor's. I guess if I fear anything when working, its getting a piece of aluminum in my eye.
/ counter sinking screws #15
On of the few things besides cleaning decal glue that WD40 is actually good for is lube for machining aluminum.
/ counter sinking screws #16
Good point Mark. Have you ever used a match form the cardboard foldable book of matches to remove small pieces of steel from your eye?
/ counter sinking screws #17
You'll shoot your eye out! :laughing:
/ counter sinking screws #19
My choice would be a weldon countersink from Weldon Tool.
There are others who seel this style countersink. Try Enco or
McMaster-Carr to name just two of them.
They will give you the cleanest countersink and work on wood equally well.
You should be able to find a set of 4 for less than $40
www.weldontool.com
http://www.weldontool.com/catalogs/weldon/Weldon1998-R.pdf
/ counter sinking screws #20
The Weldon countersink set is a great thing to have, but since we don't know just what angle the original poster needs, maybe he should match a countersink to the fastener before sinking a lot of money into something. I have always found that the single flute, high speed steel countersink, like Morse, work well in metal. Aluminum, as someone mentioned, draws heat away nicely, so other than chattering, it's easy to machine. Just take a fastener to your tool store, Harbour Freight or Sears or whereever, and match the angle to the countersink. Done.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A67714)
2015 VANTAGE...
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
PORTAPOTTY TRAILER (A68842)
PORTAPOTTY TRAILER...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
