What oil to use?
   / What oil to use? #1
KenPauling
Northcentral PA
Now Holland TN 65D with Cab
We recently had a thread about the confusion on what oil filter to use in New Holland tractors. It seems getting a non-OEM filter to match the OEM filter was confusing. It was also told about the ever changing oil filter numbers for New Holland tractors. It is also now confusing about the correct oil to use. When I bought my TN65D new back in 2004 I was told that NH 15w40 was the oil to use in my tractor year around. I did so till this year. Now, Its impossible to buy a 5 gal bucket of NH 15w40 oil at my NH dealer. They only sell NH 5w30 in 5 gallon buckets and say it the oil for my tractor. What is the deal? PS they said they can still get NH 15w40 in quart containers, but its priced at 3x the cost of buying it by the 5 gal. bucket! Is this another NH way of maximizing profit for its OEM(outrageously expensive maintenance) products?
   / What oil to use? #2
Have you tried the internet, get yourself 45 galls and make a saving, I get bulk universal tractor oil and use it in everything, cant remember what grade it is off hand:)
   / What oil to use? #3
Just had a look and I can get 205 ltrs delivered free for 1.80 per litre:)
Dont know how that compares to oil in the states
   / What oil to use? #4
Not having 15W-40 available in 5 gallon pails has nothing to do with New Holland and everything to do with what your local New Holland dealer chooses to stock. Oil in small packages ALWAYS costs more per unit than the same product in larger packaging although frankly I doubt the difference is a factor of 3.
Read your operator's manual and buy engine oil meeting the viscosity and API specifications listed for your tractor. It really isn't all that difficult.
   / What oil to use?
RickB, I have to admit you must be right. It might not be a NH issue about the unavailability of the NH 15W40 oil in 5 gal. buckets at my local dealer. He has decided to not carry it in buckets. My major question is still why the change from 15w40 for all year around use to 5W30? Is it just my dealer that is changing the recommended oil? Has it been determined that the 5W30 works better in the NH TNs than the 15W40 oil? Checking the specs will not tell me why the change. Maybe you are right again! Its not that hard to figure out- the 5W30 must be cheaper to buy for the dealer!
   / What oil to use?
Anybody else have a TN series tractor? Do you use the 15w40 oil or the 5w30 for year around use? Has your dealer changed the recomendation or availablility of your engine oil? I have always used the NH fluids and filters simply because I don't want to take a chance of damaging my engine to save a couple of dollars. This changing of oil weight I don't see as much of a big deal except I'm just curious to see if its just my dealer or other dealers as well. Maybe NH or just my dealer determined it will allow the engine to start and warmup faster in cold weather? Thanks for everyones thoughts! Merry Christmas! Ken
   / What oil to use? #8
I hope you get input from others on this. I can tell you that we recommend 15W-40 for TN's and we do not stock 5W-30. Our climatic conditions are probably very similar.
   / What oil to use? #9
You need to get to know your local fuel/oil supplier. The jobber that delivers my diesel fuel also has Exxon/Mobil lubricants. I buy the 15w-40 Exxon XD-3 diesel oil by the drum. It costs about $7 per gallon. I use it in all three of my tractors, my two diesel pickups, and the Kenworth.
I also buy my tube grease, hydraulic oil, gear oil, anti-freeze, etc. from them. It's cheaper than any dealer or auto parts store, plus they have the larger containers. (gallon, 5 gallon, drum)
   / What oil to use? #10
With the heinz57 of tractors on our yard buying the dealer oil for each one would be impossible. Ford,JD,CAT,IH,Case,Valtra,MF,leyland,renault,fiat,same,komatsu etc so we've always gone for the best deal on 45 gal drums of decent 15-40 but recently i find our local NH can match anyone for price and better most ?
And castrol grease from wally mart if you want crates of it they will deal :)
   / What oil to use?
Here is what I am being offered by my former NH dealer I bought my New Holland tractor from: John Deere oil for $60.00 per 5 gallon bucket. He says its better oil than NH oil. He said the new New Holland tractors have too many problems and have cheapened them too much for him! He now only sells John Deere tractors! WOW!
   / What oil to use? #12
I use 15-40 Rotella-T yr round. Not pushing Rotella, thats just what I've always used. But changing to a 5-40? I don't see the need. I have thought about using a syn oil, but my tractor is usually inside a semi-heated garage(never below 25f) or it's plugged in 2 to 3 hours before starting. There have been times where it's been -40f, but i seldom run the tractor when it's that cold. Too cold too snow.:D
as far as filters go, i use OEM. I only do put on about 250 hours a yr. For me, i don't trust cross referenced filters. But thats just me.
   / What oil to use?
flyingcow; I think I am going to do like you and stay with 15w40 oil weight but might take my dealer up on the JD motor oil. He said it meets or exceeds the NH specs for my engine. I am going to stick with NH OEM oil filters for now. I just find it strange that the the OEM filter numbers keep changing. Since I am like you and only use my tractor about 80 hours per year, it isn't really a big expense to use NH filters.
   / What oil to use? #14
It says JD oil or NH oil....but it's not them that make it. As long as it meets or exceeds specs, i wouldn't think you could go wrong.
   / What oil to use? #15
i also use 15-40 year around and no it dont get as cold down here but that is what we have always used in everything diesel rotella-t
   / What oil to use? #16
Did he give you any specific reason why one oil was supposdly better than the other? I'm very skeptical of that claim. It sounds like he justifying the color change he made in his business!
My personal opinion is that as long as it meets the API classification and SAE viscosity grade in your owners manual, you can use it. I use Chevron Delo 400LE 15W40 in our diesel equipment because I can convenietly pick it up at Costco in Missoula. I wouldn't hesitate to use Exon/Mobil DelVac or Shell Rotella brands if they carried them as long as they met API and SAE standards specified by the OEM. All the rest of the brand stuff is just marketing hype, in my opinion. It's not like the refineries that blend these oils set up the production line a few days a month to make "cheap oil" that doesn't meet the OEM requirements. Most engine failures are caused by too long change intervals (both filter and oil), improper assembly of parts, wrong API or SAE grade, overheating, etc not the brand of oil.
   / What oil to use? #17
+1....
   / What oil to use? #18
i like the 'sae' saying.
same as everyone else
etc.
meet specs?
   / What oil to use? #19
I thought I would add that I "Amsoilized" (changed all lubricants to Amsoil) in the TC45D I purchased a few years ago and it's working out fine. I am using all NH filters though except for the engine since Amsoil makes a filter that is 98.7% efficient at 20 microns.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2007 Western Star 4900 (A56438)
2007 Western Star...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
