First flat on new L3800
/ First flat on new L3800 #1
Rail Dawg
Was clearing some heavy yaupons and small oak here in Texas with my new L3800 when I saw the right front R4 tire had broken the bead and was flat.
Turns out it was a heavy duty branch maybe 1/2" diameter had punched through the tread. Used the bucket to lift front end up, put a log underneath and got the tire to a local shop.
I was surprised to see it flat... does this happen pretty often and is there anything I can do to lessen the chances of it happening?
Not disappointed but a flat is a show-stopper in the middle of a hectic day of clearing.
Any inputs/suggestions appreciated.
/ First flat on new L3800 #2
Maybe fill them with foam
/ First flat on new L3800 #4
R-4's are a very durable tire, most resistant to punctures. Whatever did it, have some respect for it because it isn't that easy to do. I'm not sure on the foam. Punctures happen, just takes something the right sharpness and angle to get it done.
/ First flat on new L3800 #5
Flats are pretty rare (at least for me).. I had several in some Tri Rib fronts on a 2wd tractor several years ago, but they are not as tough as R4 like on your L3800. the flats I had were caused by black thorns. Popping the bead by not having enough air pressure is more common. But obviously you ran into something pretty nasty. Yes foaming the tires works, it is expensive, and makes it ride a bit rougher. Foam is kind of a misnomer, it is more like just solid rubber. It has to be cut off of the wheel when the tires wear out or so I have been told. But if you do it, your flat days are over.
James K0UA
/ First flat on new L3800 #6
James K0UA
A friend of mine bought a ~100hp tractor that had foam in the REAR tires. It rides like a square wheeled wagon. The tires are bald now and he has to find new rims or figure out how to cut the foam out.
/ First flat on new L3800 #7
I've rode over some pretty nasty stobs,sticks,logs,ect with both the 3240 and 3200.. Both tractors have R4's and never had a flat..Like the others said you mustof hit a heck of a sticker to puncture those tires...
/ First flat on new L3800 #9
I have had several flats in my two years of R4 use. Luckily all flats have been on the front tires, and due to Locust tree thorns. For those not familiar with locust trees, you should consider yourselves lucky! I did also have issues over last few years with the two piece valve stem connections getting loose (that was a scare on one of my rear tires last year). Luckily all I had to do was tighten the valve stem and that tire had never leaked since. I do a lot of digging, and I learned my lesson about checking tires by having a low pressure front tire actually roll off of the rim while I was down in a hole with a full bucket. There are a lot of lessons to learn on these things. I check my fronts regularly now, and kep them up around 40 psi. The rears are easy now since I filled them with rim guard.
/ First flat on new L3800 #10
My B-I-L has a firewood business, is always in the woods and frequently had flat fronts (R-1 ag tires). He got his foam filled. Didn't do the rears due to the $$$ but he says they haven't been a problem.
/ First flat on new L3800 #11
I have a skid steer that would periodically have tires go flat. Most of the time it was leaking from around the bead. I can't ever remember a convenient time for a flat. I ended up getting them foamed, the ride did not change IMO. They now are always at the exact same PSI and wear has been slightly better. When it comes time for new tires, I have a saws all
/ First flat on new L3800 #12
Just part of living in the Texas hill country. Wait till you stick a mesquite thorn through a rear R-4. At least with Mesquite thorns you can get away with using Slime.
CARRYALL 1700 UTV (A64280)
CARRYALL 1700 UTV...
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A61572)
2021 Takeuchi TL6R...
2008 Big John 42' Log Trailer (A62613)
2008 Big John 42'...
(3) 3 1/2" X 36" HYD CYLINDERS (A64280)
(3) 3 1/2" X 36"...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
213324 (A64279)
213324 (A64279)
