using bucket tilt for plow angle
/ using bucket tilt for plow angle #1
CTMassey
Massey-Ferguson 1529
I know there has been some discussion on this, but If I disconnect the hoses used for the tilt function on the loader bucket and use them for the angle function on a snow plow can it harm the tractor hydraulics? Cant afford a 3rd function remote right now, or damages to the tractor.......
/ using bucket tilt for plow angle #2
Shouldn't hurt it. A cheap way to do it is to get a diverter type solenoid valve, then you just hit a switch and your tilt now controls your angle. One thing to check though, I think most plows used on trucks are lower pressure.
/ using bucket tilt for plow angle #3
Not knowing your skills, anything is possible... :) but at a high level, it should not cause damage to the tractor.
So without the curl/dump how are you going to keep the plow level with the driveway/road surface?
This reads like.... I know what the right way to do this is, but I'm choosing not to do it, and am going to jerry-rig something together, but I can't afford to fix it if I screw something up.
That should be warning enough not to do what ever your attempting. If, and admittedly its a small if, something goes badly, then you've likely disabled your tractor until you save enough to make the repair.
While not idea to plow/clear snow with a bucket alone, it is an option. The other thing to consider might be a low cost rear blade. Usually the local want-adds have them for reasonable price, or you can get a light-duty one from the local farm/implement store.
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
2014 Hyundai HL760-9A Articulated Wheel Loader (A61572)
2014 Hyundai...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
22in Mini Excavator Bucket Attachment (A61572)
22in Mini...
1063 (A64280)
1063 (A64280)
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
