Truck Electrical Woes
/ Truck Electrical Woes #1
crashz
Elite Member
NH
Kubota L2501, JD LT150, DR Field Mower
2004 GMC Sierra 1500, 4x4, 5.3L, automatic.
Yesterday afternoon my right directional stuck on while my foot was on the brake. I thought it was merely a burnt bulb. However the indicator kept lighting (solid) every time I stepped on the brakes. Once home, I put the directional on for left and then right. The left works fine, the right works but causes the brake lights (including the third brake light!) to flash in sequence. stepping on the brake causes the brake lights to work and lights the right side directional in the back only.
So, I tried to isolate a short that I assumed to be in the right side tail light by unplugging the back harness (next to the spare tire). I unplugged each plug that disconnects the tail lights, and bumper lights, however the right directional would still cause the third brake light to flash.
I then pull the fuses for the trailer hitch directionals, which can sometimes corrode at the hitch and cause problems. This changed nothing. I pulled the actual directional fuses next, and replaced them. All fuses were fine. nothing changed. Flicking the high beams on and off seemed to help, as all of a sudden the directional worked fine with out triggering the brake lights and vice versa.
The 4wd drive switch indicated that its in 4Lo, but when put into Drive, clearly is in 2wd (less torque as 4lo jerks the truck at idle ,even with the brakes applied).
I took the truck for a ride and the directional thing came back, but is inconsistent. This moring, the brakes inconsistently apply the directional, but the directional always applies the brake lights.
A unrelated electrical issue is that I have removed the heater blower resistor to replace it, but I'm awaiting the new part.
Anyone have an idea what I should do next? I'm at a loss on this. I just spent the weekend getting it ready for its yearly inspection and performing general maintenance. Now I have fix this before passing inspection, which is due by the end of this month.
Its been a great truck, but the electrical system has been getting worse for the last few years.
/ Truck Electrical Woes #2
You may think this is crazy, but do you have any problems with mice? They chewed some wiring in an old chevelle i am in the process of restoring and i had all types of lights and signals crossed. It sounds like a wiring problem.
/ Truck Electrical Woes #3
Also, check your main fuse box for corrosion or moisture. Moisture could be causing a short circuit or allowing juice to flow across circuits.
/ Truck Electrical Woes #4
My old honda did this to me.. Spent an entire weekend looking for shorted wires, when in fact the printed circuits in the fuse block were one corroded mass of green goo.
/ Truck Electrical Woes #5
I had a problem like that on an older car, and it was a problem with a wire in the steering column. It took a lot of work to find the problem.
/ Truck Electrical Woes #6
This might be unrelated to the turn signal issue. Call your dealer service dept and ask them to look for related TSBs on the transfer case. I wouldn't rush out to do the part swap if they say it applies to your vehicle, but if it is not an electrical problem with the dash indicators/controls, you will need a few hundred bucks fix that your dealer service dept will be very familiar with. :/
As to the turn signals and such, there should be a ~$20 relay that you don't have to take the whole dash apart to replace. I would do that before fooling with anything else, just in case it is simple. This probably will not fix it but taking apart the steering column is a PITA and once you start throwing parts at that you will be into much more expensive parts :(
/ Truck Electrical Woes #7
I had similar issues in a brand new 05 Dmax. It was in the steering column and in the fuse box under the hood.
Chris
Thanks guys.
The electrical gremlins are creeping up on me now and I'm trying to negotiate a new vehicle.
/ Truck Electrical Woes #9
That is why I traded my 99. Once I started throwing parts at electrical problems it quickly began to be more headache than the price of a newer truck. :/
/ Truck Electrical Woes #10
May not apply to newer trucks, I had a 81 ford and the lights went crazy like yours and it turned out to be the ground wire. It had nearly lost its ground. I took it loose and sanded a good spot and reattached , problem solved. May be your ground wire.
/ Truck Electrical Woes #11
Had one with similar problems and it turned out to be the combination switch.
I've torn the column apart and tried to diagnose it. I just don't have the time to try and fix my daily driver. And at 178K miles, I need to make a move to something more reliable.
My wife and I are shopping for a new truck now. The truck that we were negotiating was sold this morning. There is one more that I hop e to be posting about tomorrow!
/ Truck Electrical Woes #13
Check the condition of the back side of the 7 pin trailer plug (if you have one)...Had a similar issue with a 97 Chevy.
/ Truck Electrical Woes #14
If you think it is the 7 pin plug, try unplugging it where it comes out of the harness near the spare tire.
The 4 wheel drive indicators may be the button itself, I had to replace one on my '99 GMC. Although putting it in and out of gear makes me think that it is something else.
/ Truck Electrical Woes #15
In the GM trucks there is a black box called the body control module that is involved in just about everything like that. A scan tool that has the GM tests in it should be able to test that module. Unfortunately the normal troubleshooting that you would perform doesn't apply. In my GM truck it is located below and to the left of the steering column but mine is a 2000.
/ Truck Electrical Woes #16
It sounds like it could be your trailer plug has salt in it and when you step on the brakes the power going to the trailer is shorting out to your turn signal and energizing it as well. Just a guess though. I know I always have to replace the 7 pin connector every couple of years because salt gets into them and destroys them.
The trailer plug or ground wire was the first thoughts I had too, so I unplugged all wiring at the harness connections (a 4 plug port near the spare tire) to clean and check. With all unplugged and the indicator on for a right turn, it still blinks the third brake light. This eliminates the trailer plug, and wiring/grounding issues on either tail lamp.
Chasing this down further, I have to agree with glkingar. Directional controls and tranfer case commands pass through the body control module. It also explains why my gear selector display is dim and not responsive sometimes, and the occasional dead passenger side door. Grounds have recently been cleaned and checked.
If this was not my daily driver, I'd park it and fix the small stuff. This isn't the only issue, but most things are very minor and common on a near 200K mile truck. But I need to get to work and job sites without fail. So I bought a new truck.
Thanks for all the help guys. I'll post a new thread about the new truck with photos, once I take delivery on Tuesday.
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
King Kutter II Tiller for sale.
King Kutter II...
2017 Chevrolet Equinox SUV (A61574)
2017 Chevrolet...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
