Oil & Fuel TO 30 fluids
/ TO 30 fluids #1
bigtbassman
massey fergusion to30
1950's Ferguson 30, can someone tell me what type of fluids goes into the tractor, trans, rear end, engine etc. What type of hydraulic fluid goes into the Wagner loader? Thanks, T
/ TO 30 fluids #2
The engine uses SAE 30W HD , 10W30, 10W40, or 15W40 dependent on the operating ambient temperatures. The multi weight 10W30 and 10W40can be used in over the widest ranges of temperatures, but I have found 15W40 s a little too viscous for our Montana winters so I use 10W40 in my '54 TO-30.
The tranny, rear axle and hydraulics are designed for use with GL-1 mineral oil. It's also used in the steering box. NAPA carries it or can get it. You can also use UTF(Universal Tractor Fluid),however it's has a lower viscosity and in a leaky three point hydraulic system it can leak down quickly. Do not use gear oil or hydraulic fluid.
Your Wagner loader has a separate reservior and it most likely uses regular hydralic fluid (AW 32, AW 46, etc).
/ TO 30 fluids
Thank you for the reply. I have no idea what is in the rear end and transmission. I guess the best option would be to drain and refill. T
/ TO 30 fluids #4
Drain it warm from all three sump plugs and let it drip over night before you refill. Pull the side plate off and see if thwere's a lot of sludge in the sump. If there iss , you may want to clean it out. A refill will take 6 gallons of GL-1 or UTF and you pour it in at the big plug on top the tranny.
