Removing front wheel bushings
/ Removing front wheel bushings #1
phil401
john deere d110
I am trying to replace the front wheel bushings with roller bearings. I couldn't removed the bushings from the race. Does anyone have the trick to remove the bushings?
/ Removing front wheel bushings #2
If they are hardened, a press would be beneficial. If they aren't hardened a sawsall or hacksaw can be used to cut them in two halves. You can check for hardness with a file, center punch or cold chisel.
/ Removing front wheel bushings #3
:welcome:
There are two bushings, so should be able to reach through one and carefully punch the other out. Just in case you didn't know that they were two pressed in from each side. ;)
/ Removing front wheel bushings #4
Not sure of the setup so this might not apply.
If you run a bead of weld around the race, it'll fall out when it cools. I use that method constantly, it saves beating and smashing trying to get a race out. That's where tig comes in handy as you can just run a bead around it with no filler but stick will work just as good just a bit trickier.....Mike
/ Removing front wheel bushings #5
I pounded on my wheel for about an hour with no luck. Heated bushing surface 2 to 3 minutes with propane torch and they came out easily. Don't heat painted surfaces.
2024 Ford Explorer AWD SUV (A64557)
2024 Ford Explorer...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2021 CATERPILLAR 306CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
2014 Peterbilt 337 S/A 18ft. Cab and Chassis Truck (A64194)
2014 Peterbilt 337...
