At Home In The Woods
   / At Home In The Woods
ruralruss said:
As in the article you mentioned, whenever we start a fire or reload the fire we let it burn until real hot before we cut off the air.
We have a chimney sweep coming Tuesday to inspect and clean, if needed, the chimney. I'm now thinking we should build at least one real hot fire each day. However, we are playing it safe and getting our chimney inspected before building a real hot fire.
Obed
patrick_g said:
Note to guys using boards for ramps: Making the boards wider by 3-4 inches or more is NOT an efficient approach. Better to add a 2x4 or 2x6 at right angles to board ramp (a little shorter than ramp for clearance at the ends) on the underside of the ramps near midline of ramp. Adding the same amount of wood here is far better than adding width.
Patrick
Patrick,
We just bought the hardware today for creating the board ramps. I might install them and try them out this weekend.
Obed
   / At Home In The Woods #3,713
Back in the early 80's, I worked at a fireplace / wood stove retail store in Colorado. The proprietor was an immigrant stone mason who had built hundreds of chimneys during his career, plus several masonry chimneys in his sprawling store. In addition to the masonry chimneys, there were several metal insulated chimneys.
We heated the store using only wood heat. Every section of the store had either a wood stove, fireplace insert or a decorator fireplace.
I asked him one day how often he cleaned his flu's. He replied - never. (parts of his store had been constructed for 25 years). He said that on all the chimneys with the air tight stoves - he purposely starts a flu fire (raging fire in the fire box with the doors open), and as soon as he hears the flu catch fire (kinda sounds like a jet roar) he would shut the doors / turn the air control off, and in 30 seconds the combustion air was totally consumed, all flames extinguished. Then he would crack open the air control to put the stove on low heat and head to the next stove to repeat.
He went on to say, that if done often enough it keeps the flu clean as a whistle.
(On the decorative fireplaces, those were never burned enough to worry about. Plus he would rotate stoves all of the time - so those chimneys were "cleaned by fire" when an air tight stove was installed. )
They actually had two retail locations. After I was trained, they sent me to manage the other store, and I was instructed to do the same. I must say, it is a scary feeling to let the fire rage to the point you here the chimney catch, but a fire does need oxygen to burn. After a while it became second nature.
DISCLAIMER: He was a professional who knew exactly what type of chimney he had, and had either personally installed or supervised the installation of every chimney (and stove). Plus, he maintained the stoves, replacing gaskets, etc and knew if he turned the air dampers off, it would completely shut off the oxygen supply. DO NOT TRY THIS.
I will say that I do the same with my stove in my building. Oh, not every time I use the stove, but maybe every 10th time. My flue (insulated metal) is clean as a whistle.
One key point, the flu / chimney systems were inspected yearly to make sure no cracks, obstructions or other hazards were present.
And one other tidbit, you can clean the glass with easy off oven cleaner to get rid of the soot build up.
This sounds absolutly crazy!! They throw burning hunks of crosote out sometimes.
Whatever, i will just buy the cleaning brushes and sweep my chimney once a year.
To Obed..
I cant use a cat litter scoop 95% of the time as the ashes are hot, and there so hot that the scoop will turn to mush as soon as i put it in or if its cooler the colas will melt through real fast. Once cooled i will take it all out except for the big ones i can hand pick out. After all i want as much out as i can get and im starting a new fire so i dont care about the few coals that may be left.
If i could find a metal scoop like that with twice the handle on it that would work.
   / At Home In The Woods #3,714
Obed
Flaky crosote at the bottom of the chimney not a big deal, thick crust on teh top and along the chimney , yes.
Can you get on the roof and look in?
Yes you should run a hot fire getting flue temps in the 400F range (just aboute stove or fireplace) each day to burn or cook off a buch of that stuff before it gets into the danger range.
clemsonfor,
I may try to go look at the chimney today. I can get on the roof by climbing out an attic window that overlooks our back porch shed roof; no ladder is even needed. We got snow here Thursday night which left snow on the roof. I'm hoping the snow is all gone because l don't want to be up there otherwise.
Obed
I've done it with 8' ramps (2x8's) on a friends JD riding lawnmower into my F250 (similar height to yours). Having some hill to work with helps a lot. I also have those steel ramp ends on the top of the ramps that helps a TON. Like these, only I just have the top brackets:
Insta-Ramp Steel Ramp Kit 8in., Tops & Feet, Model# RAMP1K | Ramp Kits | Northern Tool + Equipment
It's one of those things that looks so overpriced you tell yourself, "I could make that!" But then you don't get around to it for years and finally breakdown and buy them, and wish you had years ago... :)
I made some ramps using the Insta-Ramp tops that Dave suggested. These things are great. We got the 8" wide version of ramp tops. When I looked at my lumber stack, I had 2x10 boards. The instructions say to not use a wider board than the ramp tops. However, my board only protruded 1" on either side of the ramp top so I think I'm ok. I don't think I would want to use 2x12 boards with the 8" ramp tops. The 8" ramp tops were about $25 for the pair; the 12" ramp tops were about $48 per pair. I didn't understand why 50% wider resulted in almost double the cost.
My boards are 9' long. I removed some wood slats from one of the boards. That board was used as a gangway from the ground to the front door during the house construction.
After finishing bolting the ramp tops to the boards, we went to the small engine mechanic's place and picked up our lawnmower that just got serviced. When backed up against a small slope, the angle of the 9 foot long boards was not steep at all. As the small engine guy drove my lawnmower up the ramps into my pickup truck bed, the boards bent way more than I liked.
When I got home, I parked the truck uphill of our garage at a spot that provided a great spot for unloading the lawnmower. You can see in the picture that the slope of the ramps was not bad at all. I did not trust the boards to support my weight and the lawnmower's weight so I did what clemsonfor suggested. I backed the lawnmower down the ramps while standing on the ground beside the ramps. I steered with one hand while I used my other hand to operate the pedal for the hydrostatic transmission. That method worked like a charm; it was really easy and wasn't scary at all. I even stopped the mower and took a picture of it while it was on the ramps.
attachment.php
You can see there is a noticeable bend in the boards, even with nobody on the mower. The bend was MUCH more pronounced when the service guy road the mower up the ramps. After seeing the bend in the boards with the service guy on the mower, I decided that I would have to attach a perpendicular 2x4 to the underside each of the ramp boards. However, after seeing how easy it was to back the mower down the ramps while I stood on the ground made me decide to just live with the boards like they are. The ramps would be much bulkier with the 2x4s attached to them.
I hope that making these ramps won't cause my wife renege on the green light to buy the utility trailer. If that happens, Dave I'm going to regret your advice.
Obed
   / At Home In The Woods #3,717
:laughing: just doing my part, Obed!
Seriously, reinforce those ramps. Either a second layer of 2x10 or a 2x4 or 2x3 standing on edge on the underside (the lighter way). Just hold it back from the ends a few inches or more so they don't interfere with the ground or truck bed.
This is one of those things that looks like it costs way too much for what it is. I suspect that $15 of that price is the liability insurance they must have to carry... They are very handy and well worth the price IMHO.
   / At Home In The Woods #3,718
Stop by the metal shop and pickup 4 (at least 2) 1.5 inch wide strips of 3/32 or 1/8 flat steel. Drill holes every 8" centered. Attach to at least one side of each ramp. That will make it nice and solid without adding bulk (and not too much weight).
Depmandog,
Have you been talking to my wife? She suggested something very similar. Are all you guys trying to cheat me out of my getting a utility trailer? Right now I can tell my wife that those ramps are too dangerous, that we NEED a utility trailer. I already took Dave's advice and am now on shaky ground. If I go to the metal shop, I'll never have a utility trailer.
Obed
   / At Home In The Woods #3,720
Depmandog,
Obed
I can not understand why you would ever WANT a utility trailer.
If you get a lumber rack you can carry anything you want in your truck and not have to worry about a trailer.
Save your pennies and get a dump trailer when you can afford one. Now that is a very useful trailer. Think of it as a sort of an extra heavy duty utility trailer, with the added benefits of being able to accommodate large loads of junk which you can say "good bye" to with the push of a button.
And, if you need mulch, topsoil, soil amendments, manure, gravel, sand or anything for your garden you will get a much more reasonable price by buying in bulk and using your tractor to spread the heap.
If you have something that won't fit in the bed of the truck, a properly-sized dump trailer will haul it just a well as a utility trailer.
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
Honda utv cart (A56859)
Honda utv cart...
2020 Hino 195 20ft. Electric Box Truck (A56858)
2020 Hino 195...
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
