Evaluating a Deere X530 and X720 or X740. Am concerned about being able to lift the 54" deck from the X700 tractors because of the weight. I like to clean my deck and sharpen the blades frequently. Any advice? Thank you.
The liquid cooled X540 has captured my attention. Is the liquid worth the extra $900 (it sure is in snowmobiles!)
Still also tempted on the X720 or X740 and believe it or not, a Kubota BX. I tested the BX and it seems to ride rougher, requires more steering wheel turns and has a clunky powerflo. But it has an FEL and 3 pt. hitch. Hard to decide.
I will say the mower and FEL are super easy to put on and take off. First raise deck all the way up, pull pins and turn the mower deck wheels turn sideways( cool design), drop deck, pull 6 pins. raise the deck arms(no deck attached) pull back collar on driveshaft slide shaft back. roll deck out the side. poof done. more than 15 minutes.. your cokin and smokin! reverse procedure to put back on. maybe 20 minute to put back on to line it up.
Not to rain on the John Deere or anyones parade but I have an 07 TC22da New Holland 3 cyl diesel Hydro. I have a 60 inch deck, FEL, Hydro 3 point hitch. Awesome tractor. New model number is different this year. I will say the mower and FEL are super easy to put on and take off. First raise deck all the way up, pull pins and turn the mower deck wheels turn sideways( cool design), drop deck, pull 6 pins. raise the deck arms(no deck attached) pull back collar on driveshaft slide shaft back. roll deck out the side. poof done. more than 15 minutes.. your cokin and smokin! reverse procedure to put back on. maybe 20 minute to put back on to line it up.
Love my New Holland. I have no experience with Kubota at all and only with my sisters Deere but it has no mower only FEL.. So not knocking any others, just saying.
Same with the Massey Ferguson GC series.Similar procedure to drop the mower off my Kubota BX. If I just drag it out, 2 minutes and it's off. If I take the time to turn the wheels, maybe 4. Drop the FEL off in about 2 minutes too. Mounting the FEL is maybe 5 minutes (still a rookie at lining it up). Worst thing is mounting the mower. The drive shaft can be a pain, but still is less than 5 minutes.
