For those with a Plasma cutter...
/ For those with a Plasma cutter... #1
Haywire
Central Kentucky
Tractorless :(
BUY A ROLLER GUIDE. Make it a priority. The ease of use is greatly improved with one over the wire standoff that comes with the torch. The stance is wider which makes it more stable side to side and that means less tendency to tilt the torch. My cuts in 1/2" plate are much cleaner and straighter with no dross at all. With the wire standoff, I was wobbling a bit side to side and that caused a lot of dross underneath.
I am really pleased with mine as you can tell. This is the one I got. It fits Trafimet S45 torches which come with the Everlast PP50 as well as the Harbor Freight and Eastwood cutters.
Ian
/ For those with a Plasma cutter... #2
Can you please measure the ID of the ring please?
/ For those with a Plasma cutter... #3
I've never used one of those, looks very interesting! I guess I'm just too old school, I generally use a burning bar. Do the wheels help keep the torch going in a straight line, so you wouldn't need a straight edge?
/ For those with a Plasma cutter... #4
you need to come into the 21st century.....HEHE
heres mine
/ For those with a Plasma cutter... #5
I got one of those too. ;)
/ For those with a Plasma cutter... #9
So why the burning bar????
I am guessing he uses it with the O/A torch. And for things that wont fit on the table. And for things it isnt worth setting up the table for.
/ For those with a Plasma cutter... #10
You must have a lot bigger CNC machine than I do. My machine will only cut 3-inches in height, so something like this won't fit under the torch.
/ For those with a Plasma cutter... #11
I cant tell how tall that thing is..i thought the top was removable and just on stands.
what the heck is that.
I have cut large objects by removing my 3/16" slats and placing objects up to 36" tall within my table.
/ For those with a Plasma cutter... #12
A grapple off a BobCat I converted to fit my little tractor. I use my plasma just like an O/A torch, being as I have it, it cost a lot less to use than the O/A. Anymore all I use the O/A for is heating, or heat shrinking objects back into shape.
/ For those with a Plasma cutter... #13
Holy crap... i would have NEVER thought thats what i was looking at in those pictures. So you were just lightening the load. Nice job by the way..that looks great
/ For those with a Plasma cutter... #14
That's because it was upside down.:laughing:
I had to cut the holy crap out of that thing so my little tractor could pick it up!:eek:
/ For those with a Plasma cutter... #15
A little off topic, but which deere do you have?
/ For those with a Plasma cutter... #16
/ For those with a Plasma cutter... #17
Thank you!
Would you believe me that I got this gooseneck under my table to burn these horse heads out?:D
It's a JD 4200, 26-HP.
Yeiks.... but its sure slick looking.
/ For those with a Plasma cutter... #18
It's a gooseneck adapter, converts a bumper pull into a gooseneck trailer. I've built a few of these so far.
/ For those with a Plasma cutter... #19
VERY cool..... i wouldnt mine doing that to my own gooseneck so i could fit my new larger tractor...but the axles are too light duty.
/ For those with a Plasma cutter... #20
The horse heads are a nice touch.
John Deere 5065E (A62180)
John Deere 5065E...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
10' PIN ON ROOT RAKE W/ BRACKETS (A63290)
10' PIN ON ROOT...
CASE INTERNATIONAL 1020 GRAIN HEAD (A63290)
CASE INTERNATIONAL...
J&R T/A GOOSENECK LIVESTOCK TRAILER (A63290)
J&R T/A GOOSENECK...
