Taping to fieldstone foundation?
/ Taping to fieldstone foundation? #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
I'm trying to think of the best way to tape to a fieldstone foundation that will stay as long as I want it to, and then come off.
Some background: I have a house built circa 1870 with a fieldstone foundation. Since I bought it the basement has had a moisture problem, and periodically (every few years) the water table rises and it floods.
About a ago I rented a concrete cutting saw and cut a trench around the inside perimeter and installed drains and a sump pump. That was a job! The sump pump runs fairly often and the basement hasn't flooded since then, but I'm not sure if it's just because the water table hasn't risen or if what I did really works.
It is still quite damp down there -- typically 85-90% humidity. The next step would be to seal everything. However, I want to make sure that the drains are sufficient before I do that, because otherwise sealing would trap water behind the wall and make things worse. In the meantime I want to do a temporary sealing using plastic sheeting. I figure that will stay up for at least another year, maybe longer.
So far I haven't been able to get anything to hold sheeting to the walls. I have an idea that I think will work, which is to put a layer of 4" flexible flashing (i.e. Vycor) along the wall above grade, and then tape the plastic to it with Tyvek tape. I'm pretty sure that will hold, Vycor sticks to anything and Tyvek tape sticks to Vycor. The one concern I have is that eventually I'm going to want to take it off, and I worry that the Vycor won't come off my beautiful antique walls.
Any thoughts on alternatives?
Thanks.
/ Taping to fieldstone foundation? #2
Can you wrap the first foot or so of plastic around pieces of wood and temporarily screw those to your sill?
Ken
/ Taping to fieldstone foundation? #3
Sounds like a lot of work to try to tape on plastic. I can't imagine it cutting down on humidity. A few questions if you don't mind.
Where was the water coming from in the first place, from the stone in the walls, up through the floor, or where? Do you know the thickness of the walls? When you cut the concrete around the perimeter did you remove the concrete from against the walls and then repour directly against the stone?
The water was coming in through cracks in the floor. I would go down there with a shop-vac and vacuum it up and I could see it coming in as fast as I could suck it up.
The walls are approximately 24" at the top. I suspect they get wider as they go down.
When I cut the concrete I could only get the saw blade within about 6" of the wall so my trenches are 6" from the walls. I have not repoured concrete yet because I'm not positive that my drains are adequate so the trenches are just filled with gravel.
I have another house of similar construction on the same property, but at higher elevation. In this house the basement was pointed and sealed with some sort of paint. Both are unheated right now. Current outdoor weather is 53F, 71% relative humidity. The "wet" house basement is at 46F, 92% RH. The "dry" house basement is 48F, 66% RH. I think the difference is that one is sealed against dampness in the soil.
/ Taping to fieldstone foundation? #5
A huge amount of moisture can come through unsealed basement walls. The construction/heating system of the rest of the house determines whether that is a problem or not. Half of our old house's "basement" was equivalent to a crawl space because the dirt was less than 12" from the floor joists. Covering it and the walls with plastic made a big difference in moisture levels. To see if it is worth it, you can always tape up a small piece and see if you get condensation, how much and how quickly.
Ken
Ken
My concern is that humidity will cause rot in the framing, so I'm trying to keep the moisture away from the wood. I worry that if the plastic touches the wood it will create spots where the moisture is trapped. The sills are about 24" above grade, so ideally what I want is for the plastic to end above grade but well below the framing.
/ Taping to fieldstone foundation? #7
So,the walls are covered in plastic. Moisture is coming through the walls. Where will it go?:)
Silicon or some of contractor type adhesives may work to hold the plastic?:)
If the moisture is just vapor then a vapor barrier will hold it. If there is liquid water behind the wall I need to give it some place to go or the hydrostatic pressure will build and something will give. The point of this exercise is to see if what I did with the drains and sump pump was enough to eliminate liquid water behind the wall, or whether I need to do more.
I tried silicon and liquid nails. They stick to the walls but not the poly sheeting. Tapes tend to stick to the sheeting but not the wall. I think I need two separate adhesives.
/ Taping to fieldstone foundation? #9
what about that aluminum tape, it might do the job.
/ Taping to fieldstone foundation? #10
If you have mositure coming in from the floor, sounds like the perimeter drain system is not catching all of it and there is too much water underneath due to the overall water table. The current home being renovated on This Old House had the same problem and they put a gravel french drain underneath the floor plus a perimeter drain. The center floor drain moved the majority of the water that the perimeter drain did not catch to another location, away from the home.
/ Taping to fieldstone foundation? #11
Thanks.
Can't you leave a dehumdifier on all the time, or at least use one to figure out how much water is coming in. If you get the RH down to where you want it and measure the water pulled out by the dehumidifier, you'll get an idea how big the problem is. I don't like capturing water behind plastic, then you'll have mold and mildew problems in that area between the plastic and wall. The only way to really solve it is probably waterproof from the outside, but that would be many $$$.
/ Taping to fieldstone foundation? #12
In an old house, the sills rest directly on the stone/grout and that is where they are picking up the most of their moisture so i would not be worried about a 1 x1 wrapped in plastic touching the bottom side of the sill.
Another option - tack the 1 x1 plywood strip to the sill and then tape to that.
Ken
/ Taping to fieldstone foundation? #13
Agree with SpringHollow. The moisture will move to the area of temperature difference, likely down near the floor. Plus gravity will carry down moisture that comes in through the stone work. If this is a temporary wall, and your sills are 24" above grade, go ahead and tack the poly to the sills and drape down the walls, ending in your french drain. Try that for a few months and see what happens. I doubt you'll get mildew behind the poly.
Dehumidifiers are spendy to run all the time. However a good 220v model is far cheaper to run than a consumer model.
Jim
Ken
This is basically what I'm up against.
I probably shouldn't have described what I have as a "basement," it's a cellar. Imagine that you dug a hole about four feet deep with a shovel, and as you went you collected rocks and stacked them along the edges and piled the dirt you dug out against the outside. That's what I have. Even if there is no water flowing in it is very damp because there is nothing keeping out the moisture in the soil.
It is possible to "damp-proof" such a cellar, by pouring a concrete floor, filling the gaps in the rocks with mortar, and sealing the whole thing with a masonry paint. However, if you damp-proof and there is flowing water the damp-proofing makes things worse because it causes the water to accumulate and potentially undermine the foundation. I believe that I have controlled the water problem with perimeter drains, but I'm not positive, so I want to do temporary damp-proofing as a test. If it turns out that I am wrong and I have not solved the water problem, the damp-proofing will hold the water and I'll see where the problem is. It might be a year or two before I know for sure. Once I'm sure I can move forward with permanent damp-proofing.
The problem I'm having is how to attach something semi-permanently to the stone walls, nothing really sticks.
/ Taping to fieldstone foundation? #15
Draft Stop caulking will stick to the wall and will be removable later . I would use 2 concrete nails and fasten a vertical piece of 1x2 wood to the wall using concrete nails. Put a 1/2 bead of Draft Stop caulking to the back of the 1x3 before fastening it to the wall. Put your plastic up and then nail another 1x3 tight over the one nailed to the wall to seal things. The Drafy Stop caulking will peel off later and only marks you will have are from the few nails in the 1x3.
/ Taping to fieldstone foundation? #16
Here in Maine we have a lot of older houses like you have and what I have seen contractors do is this. For the floor they put down a very tough plastic fabric then put stone on top of it. Then they point the rocks and spray foam the walls.. It seems to work very well..
If your rocks are clean you could try useing some spray foam as glue to hold your polly to the walls.. the stuff sticks to anything..
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2021 Case IH 540 Steieger (A66285)
2021 Case IH 540...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
