rops bolt size for B3030?
/ rops bolt size for B3030? #1
fishhead
Gold Member
Howdy, hoping someone knows the diameter and thread pitch of the bolts that secure the folding rops in the up or down position
I am thinking of using the empty nut to mount a rear facing led worklight.
Many Thanks
bump hoping for answer
/ rops bolt size for B3030? #5
You could remove the bolt that is there and take it with you to get a match. The wire tether can be easily removed.
Thanks all for replying- sorry for my delay in reply, been really swamped.
PSDX- thats actually what i ended up doing after failing to get the size from a dealer and finding out the other bolts on the rops are actually smaller. The threads in question are 5/8-18. So I bought a bolt and lockwasher and just got in from my installation.
S219- that thread is actually what put it in my mind- my forward facing lights are mounted on the inside of the bends on the upper ROPS so they are high yet protected by the rops itself. The rear light did not need to be as high so the placement is perfect. I wired them all into the circuit for the rear worklight that came on the tractor from kubota- that light mount was too low and the lens actually cracked by coming in contact with the top of my rear blade when the top cylinder was retracted fully. I used the original light mount to mount the switch- its easy to reach back and pop them on.
If anyone is looking for a good source for tractor lighting try towmart.com -i got my forward lights from them last year and the rear this year - both times they seemed to have one of the better selections and the best pricing. They were helpful when i had a question and shipped promptly.
Thanks again
Bill
/ rops bolt size for B3030? #7
That's odd that these bolts aren't metric - I am surprised. Thanks for sharing.
/ rops bolt size for B3030? #8
A 5/8"-18 screw fits in most 16mm-1.5 nuts :) Some 16mm-1.5 screws don't fit some 5/8'-18 nuts so me thinks its metric. Can check my B2630 sometime but doubt there's anything threaded on it that ain't metric.
could be that its metric- when i used the bolt sizer a the hardware store there was a noticeable difference between the two, with the metric size being fairly loose- did not really matter as the 5/8 bolt fit well and the hardware sore did not have that metric size
funny - just did the math and 5/8 inch equals about 15.9 mm so it should have been tighter
also the 18 TPI equals 1.41 mm
213097 (A64276)
213097 (A64276)
2010 Chrysler Town and County Van (A61574)
2010 Chrysler Town...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
2012 JAYCO PINNACLE ALL-SEASONS 5TH WHEEL CAMPER (A64280)
2012 JAYCO...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2025 Tooth Bucket Mini Excavator Attachment (A61572)
2025 Tooth Bucket...
